New installation problems
Posted: Sat Oct 15, 2016 7:35 pm
Hi guys,
I am new to ZM and am having trouble with the cameras. Here some info:
- I am running Ubuntu Desktop 16.04.1 (clean install right before ZM installation)
- ZM V. 1.30.0
- installed using the installation guide from the ZM homepage
- seems fine working
- set up two cameras:
- Panasonic BL-C10A
- GW Secure Model GW-5037IP
I cannot see the camera pictures if I click on the camera names.
Here is an excerpt from the ZM Log:
Thank you guys!
esprit
- ZM V. 1.30.0
- Panasonic BL-C10A
Any help would be welcome.2016-10-15 12:27:05.657129 zmc_m1 2524 INF Bobs Toys: 20000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:23:45.653192 zmc_m1 2524 INF Bobs Toys: 19000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:22:53.738819 zmc_m2 2525 INF Testing Center: 9000 - Capturing at 1.94 fps zm_monitor.cpp 3116
2016-10-15 12:20:25.663044 zmc_m1 2524 INF Bobs Toys: 18000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:17:46.809507 web_php 2368 ERR socket_sendto( /var/run/zm/zms-289869s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-10-15 12:17:05.647750 zmc_m1 2524 INF Bobs Toys: 17000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:14:17.830319 zmc_m2 2525 INF Testing Center: 8000 - Capturing at 1.94 fps zm_monitor.cpp 3116
2016-10-15 12:13:45.656631 zmc_m1 2524 INF Bobs Toys: 16000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:10:25.623843 zmc_m1 2524 INF Bobs Toys: 15000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:07:05.642553 zmc_m1 2524 INF Bobs Toys: 14000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:05:41.750524 zmc_m2 2525 INF Testing Center: 7000 - Capturing at 2.31 fps zm_monitor.cpp 3116
2016-10-15 12:03:45.630732 zmc_m1 2524 INF Bobs Toys: 13000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 12:00:25.615083 zmc_m1 2524 INF Bobs Toys: 12000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:58:28.994052 zmc_m2 2525 INF Testing Center: 6000 - Capturing at 2.63 fps zm_monitor.cpp 3116
2016-10-15 11:57:05.611083 zmc_m1 2524 INF Bobs Toys: 11000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:53:45.595914 zmc_m1 2524 INF Bobs Toys: 10000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:52:08.189638 zmc_m2 2525 INF Testing Center: 5000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:50:25.601693 zmc_m1 2524 INF Bobs Toys: 9000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:47:05.580424 zmc_m1 2524 INF Bobs Toys: 8000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:45:47.211130 zmc_m2 2525 INF Testing Center: 4000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:43:45.576438 zmc_m1 2524 INF Bobs Toys: 7000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:40:25.575688 zmc_m1 2524 INF Bobs Toys: 6000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:39:26.337545 zmc_m2 2525 INF Testing Center: 3000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:37:05.559626 zmc_m1 2524 INF Bobs Toys: 5000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:36:35.079049 web_php 2371 ERR socket_sendto( /var/run/zm/zms-277302s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2016-10-15 11:33:45.546901 zmc_m1 2524 INF Bobs Toys: 4000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:33:05.534613 zmc_m2 2525 INF Testing Center: 2000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:30:25.537060 zmc_m1 2524 INF Bobs Toys: 3000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:27:05.541094 zmc_m1 2524 INF Bobs Toys: 2000 - Capturing at 5.00 fps zm_monitor.cpp 3116
2016-10-15 11:26:44.866922 zmc_m2 2525 INF Testing Center: 1000 - Capturing at 2.62 fps zm_monitor.cpp 3116
2016-10-15 11:23:45.535202 zmc_m1 2524 INF Bobs Toys: 1000 - Capturing at 4.95 fps zm_monitor.cpp 3116
2016-10-15 11:20:24.498220 zmdc 2550 INF 'zmtelemetry.pl' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.498190 zmdc 2490 INF 'zmtelemetry.pl' starting at 16/10/15 11:20:24, pid = 2550 zmdc.pl
2016-10-15 11:20:24.332630 zmdc 2490 INF 'zmupdate.pl -c' starting at 16/10/15 11:20:24, pid = 2546 zmdc.pl
2016-10-15 11:20:24.332630 zmdc 2546 INF 'zmupdate.pl -c' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.326370 zmwatch 2538 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-10-15 11:20:24.282310 zmwatch 2538 INF Watchdog starting zmwatch.pl
2016-10-15 11:20:24.178050 zmdc 2490 INF 'zmwatch.pl' starting at 16/10/15 11:20:24, pid = 2538 zmdc.pl
2016-10-15 11:20:24.178050 zmdc 2538 INF 'zmwatch.pl' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.134098 zmc_m1 2524 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-10-15 11:20:24.085220 zmfilter 2526 INF Scanning for events zmfilter.pl
2016-10-15 11:20:24.050612 zmc_m1 2524 INF Priming capture from rtsp://192.168.1.211:554/mpeg4?username=admin&password=A3E17F3B36EED680B815F02976AEE758 zm_ffmpeg_camera.cpp 104
2016-10-15 11:20:24.042910 zmdc 2531 INF 'zmaudit.pl -c' started at 16/10/15 11:20:24 zmdc.pl
2016-10-15 11:20:24.042780 zmdc 2490 INF 'zmaudit.pl -c' starting at 16/10/15 11:20:24, pid = 2531 zmdc.pl
2016-10-15 11:20:23.962538 zmc_m1 2524 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:20:23.943086 zmc_m2 2525 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:20:23.860070 zmdc 2526 INF 'zmfilter.pl' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.860070 zmdc 2490 INF 'zmfilter.pl' starting at 16/10/15 11:20:23, pid = 2526 zmdc.pl
2016-10-15 11:20:23.809700 zmdc 2525 INF 'zmc -m 2' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.809690 zmdc 2490 INF 'zmc -m 2' starting at 16/10/15 11:20:23, pid = 2525 zmdc.pl
2016-10-15 11:20:23.708350 zmdc 2490 INF Starting pending process, zmc -m 2 zmdc.pl
2016-10-15 11:20:23.659250 zmdc 2524 INF 'zmc -m 1' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.659240 zmdc 2490 INF 'zmc -m 1' starting at 16/10/15 11:20:23, pid = 2524 zmdc.pl
2016-10-15 11:20:23.608170 zmdc 2490 INF Starting pending process, zmc -m 1 zmdc.pl
2016-10-15 11:20:23.559560 zmdc 2490 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:20:23.445070 zmdc 2520 INF 'zmc -m 2' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.445070 zmdc 2490 INF 'zmc -m 2' starting at 16/10/15 11:20:23, pid = 2520 zmdc.pl
2016-10-15 11:20:23.332830 zmdc 2490 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:20:23.249210 zmdc 2490 INF 'zmc -m 1' starting at 16/10/15 11:20:23, pid = 2516 zmdc.pl
2016-10-15 11:20:23.249210 zmdc 2516 INF 'zmc -m 1' started at 16/10/15 11:20:23 zmdc.pl
2016-10-15 11:20:23.114340 zmpkg 2474 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-10-15 11:20:20.106750 zmdc 2490 INF Server starting at 16/10/15 11:20:20 zmdc.pl
2016-10-15 11:20:19.915080 zmpkg 2474 INF Command: start zmpkg.pl
2016-10-15 11:20:19.872440 zmpkg 2474 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:20:19.717690 zmdc 2190 INF Server shutdown at 16/10/15 11:20:19 zmdc.pl
2016-10-15 11:20:09.586520 zmdc 2190 INF 'zmc -m 1' exited normally zmdc.pl
2016-10-15 11:20:09.546180 zmdc 2190 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:20:09.503090 zmdc 2190 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:20:09.419530 zmdc 2190 INF 'zmupdate.pl -c' sending stop to pid 2245 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.419489 zmc_m1 2220 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:20:09.377707 zmc_m2 2388 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:20:09.327660 zmdc 2190 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-10-15 11:20:09.285778 zmc_m2 2388 ERR Unable to read content zm_remote_camera_http.cpp 1026
2016-10-15 11:20:09.244130 zmdc 2190 INF 'zmc -m 1' sending stop to pid 2220 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.202337 zmc_m2 2388 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:20:09.160660 zmdc 2190 INF 'zmtelemetry.pl' sending stop to pid 2251 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.160615 zmc_m2 2388 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:20:09.118910 zmdc 2190 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:20:09.077120 zmdc 2190 INF 'zmc -m 2' sending stop to pid 2388 at 16/10/15 11:20:09 zmdc.pl
2016-10-15 11:20:09.035350 zmdc 2190 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-10-15 11:20:08.984750 zmdc 2190 INF 'zmaudit.pl -c' sending stop to pid 2231 at 16/10/15 11:20:08 zmdc.pl
2016-10-15 11:20:08.943000 zmdc 2190 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-10-15 11:20:08.901190 zmdc 2190 INF 'zmfilter.pl' sending stop to pid 2226 at 16/10/15 11:20:08 zmdc.pl
2016-10-15 11:20:08.864300 zmdc 2190 INF 'zmwatch.pl' sending stop to pid 2238 at 16/10/15 11:20:08 zmdc.pl
2016-10-15 11:20:08.659630 zmpkg 2433 INF Command: stop zmpkg.pl
2016-10-15 11:20:08.619320 zmpkg 2433 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:20:08.482580 zmsystemctl 2421 INF Redirecting command through systemctl zmsystemctl.pl
2016-10-15 11:20:08.317690 zmpkg 2415 INF Command: restart zmpkg.pl
2016-10-15 11:20:08.255120 zmpkg 2415 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:19:51.994510 zmdc 2190 WAR Can't find process with command of 'zma -m 2' zmdc.pl
2016-10-15 11:19:51.940652 zmc_m2 2388 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:19:51.814710 zmdc 2388 INF 'zmc -m 2' started at 16/10/15 11:19:51 zmdc.pl
2016-10-15 11:19:51.814710 zmdc 2190 INF 'zmc -m 2' starting at 16/10/15 11:19:51, pid = 2388 zmdc.pl
2016-10-15 11:19:51.697590 zmdc 2190 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:19:51.643616 zmc_m2 2225 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:19:51.601807 zmc_m2 2225 ERR Unable to read subheader zm_remote_camera_http.cpp 977
2016-10-15 11:19:51.560070 zmc_m2 2225 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:19:51.518247 zmc_m2 2225 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:19:51.477290 zmdc 2190 INF 'zmc -m 2' sending stop to pid 2225 at 16/10/15 11:19:51 zmdc.pl
2016-10-15 11:19:51.252200 zmdc 2190 WAR Can't find process with command of 'zma -m 2' zmdc.pl
2016-10-15 11:19:26.159371 web_js 1709 ERR TypeError: e[c] is undefined zm/tools/mootools/mootools-more.js 1
2016-10-15 11:18:56.718846 zmc_m1 2220 INF Bobs Toys: 1000 - Capturing at 4.98 fps zm_monitor.cpp 3116
2016-10-15 11:15:35.700230 zmdc 2251 INF 'zmtelemetry.pl' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.700190 zmdc 2190 INF 'zmtelemetry.pl' starting at 16/10/15 11:15:35, pid = 2251 zmdc.pl
2016-10-15 11:15:35.560750 zmwatch 2238 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-10-15 11:15:35.528640 zmdc 2245 INF 'zmupdate.pl -c' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.528630 zmdc 2190 INF 'zmupdate.pl -c' starting at 16/10/15 11:15:35, pid = 2245 zmdc.pl
2016-10-15 11:15:35.519930 zmwatch 2238 INF Watchdog starting zmwatch.pl
2016-10-15 11:15:35.349830 zmdc 2238 INF 'zmwatch.pl' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.349830 zmdc 2190 INF 'zmwatch.pl' starting at 16/10/15 11:15:35, pid = 2238 zmdc.pl
2016-10-15 11:15:35.274490 zmfilter 2226 INF Scanning for events zmfilter.pl
2016-10-15 11:15:35.228690 zmdc 2190 INF 'zmaudit.pl -c' starting at 16/10/15 11:15:35, pid = 2231 zmdc.pl
2016-10-15 11:15:35.228690 zmdc 2231 INF 'zmaudit.pl -c' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.185123 zmc_m1 2220 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-10-15 11:15:35.144802 zmc_m2 2225 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:15:35.101649 zmc_m1 2220 INF Priming capture from rtsp://192.168.1.211:554/mpeg4?username=admin&password=A3E17F3B36EED680B815F02976AEE758 zm_ffmpeg_camera.cpp 104
2016-10-15 11:15:35.060900 zmdc 2190 INF 'zmfilter.pl' starting at 16/10/15 11:15:35, pid = 2226 zmdc.pl
2016-10-15 11:15:35.060900 zmdc 2226 INF 'zmfilter.pl' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.049438 zmc_m1 2220 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:15:35.010860 zmdc 2225 INF 'zmc -m 2' started at 16/10/15 11:15:35 zmdc.pl
2016-10-15 11:15:35.010850 zmdc 2190 INF 'zmc -m 2' starting at 16/10/15 11:15:35, pid = 2225 zmdc.pl
2016-10-15 11:15:34.967990 zmdc 2190 INF Starting pending process, zmc -m 2 zmdc.pl
2016-10-15 11:15:34.925810 zmdc 2190 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:15:34.810420 zmdc 2221 INF 'zmc -m 2' started at 16/10/15 11:15:34 zmdc.pl
2016-10-15 11:15:34.810420 zmdc 2190 INF 'zmc -m 2' starting at 16/10/15 11:15:34, pid = 2221 zmdc.pl
2016-10-15 11:15:34.768740 zmdc 2220 INF 'zmc -m 1' started at 16/10/15 11:15:34 zmdc.pl
2016-10-15 11:15:34.768730 zmdc 2190 INF 'zmc -m 1' starting at 16/10/15 11:15:34, pid = 2220 zmdc.pl
2016-10-15 11:15:34.725870 zmdc 2190 INF Starting pending process, zmc -m 1 zmdc.pl
2016-10-15 11:15:34.686000 zmdc 2190 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:15:34.577050 zmdc 2216 INF 'zmc -m 1' started at 16/10/15 11:15:34 zmdc.pl
2016-10-15 11:15:34.576620 zmdc 2190 INF 'zmc -m 1' starting at 16/10/15 11:15:34, pid = 2216 zmdc.pl
2016-10-15 11:15:34.469710 zmpkg 2174 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-10-15 11:15:31.467460 zmdc 2190 INF Server starting at 16/10/15 11:15:31 zmdc.pl
2016-10-15 11:15:31.274140 zmpkg 2174 INF Command: start zmpkg.pl
2016-10-15 11:15:31.232570 zmpkg 2174 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:15:31.044750 zmdc 1219 INF Server shutdown at 16/10/15 11:15:31 zmdc.pl
2016-10-15 11:15:20.849750 zmdc 1219 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:15:20.762279 zmc_m2 1765 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:15:20.745060 zmdc 1219 INF 'zmc -m 1' exited normally zmdc.pl
2016-10-15 11:15:20.712386 zmc_m2 1765 ERR Unable to read content zm_remote_camera_http.cpp 1026
2016-10-15 11:15:20.670431 zmc_m2 1765 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:15:20.628710 zmc_m2 1765 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:15:20.545250 zmdc 1219 INF 'zmc -m 2' sending stop to pid 1765 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.545225 zmc_m1 1774 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-10-15 11:15:20.486770 zmdc 1219 INF 'zmupdate.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.428440 zmdc 1219 INF 'zmc -m 1' sending stop to pid 1774 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.386590 zmdc 1219 INF 'zmtelemetry.pl' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.344890 zmdc 1219 INF 'zmupdate.pl -c' sending stop to pid 1628 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.303060 zmdc 1219 INF 'zmwatch.pl' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.261340 zmdc 1219 INF 'zmtelemetry.pl' sending stop to pid 1639 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.219580 zmdc 1219 INF 'zmfilter.pl' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.177850 zmdc 1219 INF 'zmwatch.pl' sending stop to pid 1610 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.127730 zmdc 1219 INF 'zmaudit.pl -c' exited, signal 14 zmdc.pl
2016-10-15 11:15:20.077650 zmdc 1219 INF 'zmfilter.pl' sending stop to pid 1584 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:20.032230 zmdc 1219 INF 'zmaudit.pl -c' sending stop to pid 1597 at 16/10/15 11:15:20 zmdc.pl
2016-10-15 11:15:19.811120 zmpkg 2130 INF Command: stop zmpkg.pl
2016-10-15 11:15:19.783400 zmpkg 2130 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:15:19.646610 zmsystemctl 2124 INF Redirecting command through systemctl zmsystemctl.pl
2016-10-15 11:15:19.452430 zmpkg 2116 INF Command: restart zmpkg.pl
2016-10-15 11:15:19.402690 zmpkg 2116 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:12:36.698567 zmc_m1 1774 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2016-10-15 11:12:36.426404 zmc_m1 1774 INF Priming capture from rtsp://192.168.1.211:554/mpeg4?username=admin&password=A3E17F3B36EED680B815F02976AEE758 zm_ffmpeg_camera.cpp 104
2016-10-15 11:12:36.197167 zmc_m1 1774 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:12:35.821811 zmc_m2 1765 INF Starting Capture version 1.30.0 zmc.cpp 250
2016-10-15 11:12:35.582010 zmdc 1774 INF 'zmc -m 1' started at 16/10/15 11:12:35 zmdc.pl
2016-10-15 11:12:35.581550 zmdc 1219 INF 'zmc -m 1' starting at 16/10/15 11:12:35, pid = 1774 zmdc.pl
2016-10-15 11:12:35.321930 zmdc 1219 INF Starting pending process, zmc -m 1 zmdc.pl
2016-10-15 11:12:35.248310 zmdc 1765 INF 'zmc -m 2' started at 16/10/15 11:12:35 zmdc.pl
2016-10-15 11:12:35.247900 zmdc 1219 INF 'zmc -m 2' starting at 16/10/15 11:12:35, pid = 1765 zmdc.pl
2016-10-15 11:12:35.138350 zmdc 1219 INF Starting pending process, zmc -m 2 zmdc.pl
2016-10-15 11:12:35.022560 zmdc 1219 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:12:34.855700 zmdc 1219 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2016-10-15 11:12:30.709120 zmdc 1639 INF 'zmtelemetry.pl' started at 16/10/15 11:12:30 zmdc.pl
2016-10-15 11:12:30.705160 zmdc 1219 INF 'zmtelemetry.pl' starting at 16/10/15 11:12:30, pid = 1639 zmdc.pl
2016-10-15 11:12:30.455390 zmwatch 1610 INF Watchdog pausing for 30 seconds zmwatch.pl
2016-10-15 11:12:30.306910 zmfilter 1584 INF Scanning for events zmfilter.pl
2016-10-15 11:12:30.161750 zmdc 1219 INF 'zmupdate.pl -c' starting at 16/10/15 11:12:30, pid = 1628 zmdc.pl
2016-10-15 11:12:30.161750 zmdc 1628 INF 'zmupdate.pl -c' started at 16/10/15 11:12:30 zmdc.pl
2016-10-15 11:12:29.777470 zmwatch 1610 INF Watchdog starting zmwatch.pl
2016-10-15 11:12:29.408380 zmdc 1610 INF 'zmwatch.pl' started at 16/10/15 11:12:29 zmdc.pl
2016-10-15 11:12:29.408370 zmdc 1219 INF 'zmwatch.pl' starting at 16/10/15 11:12:29, pid = 1610 zmdc.pl
2016-10-15 11:12:28.930240 zmdc 1597 INF 'zmaudit.pl -c' started at 16/10/15 11:12:28 zmdc.pl
2016-10-15 11:12:28.930230 zmdc 1219 INF 'zmaudit.pl -c' starting at 16/10/15 11:12:28, pid = 1597 zmdc.pl
2016-10-15 11:12:28.468360 zmdc 1584 INF 'zmfilter.pl' started at 16/10/15 11:12:28 zmdc.pl
2016-10-15 11:12:28.468160 zmdc 1219 INF 'zmfilter.pl' starting at 16/10/15 11:12:28, pid = 1584 zmdc.pl
2016-10-15 11:12:27.966190 zmdc 1572 INF 'zmc -m 2' started at 16/10/15 11:12:27 zmdc.pl
2016-10-15 11:12:27.966180 zmdc 1219 INF 'zmc -m 2' starting at 16/10/15 11:12:27, pid = 1572 zmdc.pl
2016-10-15 11:12:27.507510 zmdc 1524 INF 'zmc -m 1' started at 16/10/15 11:12:27 zmdc.pl
2016-10-15 11:12:27.506660 zmdc 1219 INF 'zmc -m 1' starting at 16/10/15 11:12:27, pid = 1524 zmdc.pl
2016-10-15 11:12:26.988350 zmpkg 1158 INF Single server configuration detected. Starting up services. zmpkg.pl
2016-10-15 11:12:23.986440 zmdc 1219 INF Server starting at 16/10/15 11:12:23 zmdc.pl
2016-10-15 11:12:23.610100 zmpkg 1158 INF Command: start zmpkg.pl
2016-10-15 11:12:23.323660 zmpkg 1158 INF Sanity checking States table... zmpkg.pl
2016-10-15 11:06:46.687330 zmdc 1368 INF Server shutdown at 16/10/15 11:06:46 zmdc.pl
2016-10-15 11:06:36.542900 zmdc 1368 INF 'zmc -m 2' exited normally zmdc.pl
2016-10-15 11:06:36.496911 zmc_m2 1844 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2016-10-15 11:06:36.455177 zmc_m2 1844 ERR Unable to read content zm_remote_camera_http.cpp 1026
2016-10-15 11:06:36.371673 zmc_m2 1844 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2016-10-15 11:06:36.341270 zmdc 1368 INF 'zmc -m 1' exited normally zmdc.pl
2016-10-15 11:06:36.321596 zmc_m2 1844 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
Thank you guys!
esprit
