zmNinja - Event Montage monitor disable?
ZMBrian
Post by ZMBrian »
I see there's been a lot of cool work done on Event Montage in recent zmNinja releases.
I'm hoping there will be a feature to disable, or at least not show/suppress, selected monitors (especially those in "Mocord" or "Record" mode).
I'd like to be able to suppress these feeds while still allowing "Modect" feeds. Perhaps "only" show monitors that are in "Modect" mode?
Thanks,
Brian
mspk7305
Re: zmNinja - Event Montage monitor disable?
Post by mspk7305 »
If you hit the eye icon at the top of zmninja while in montage view you can select which monitors to show. then hit the tripple dot icon to save the layout with the heart.
