zmNinja 1.2.27 - Problem with Alarm Frame Navigation
ZMBrian
Post by ZMBrian »
I'm experiencing a problem with Alarm Frame Navigation during Event Footage playback on zmNinja 1.2.27 for iOS and 1.2.26 for Windows.
Under Events > Footage, I click on the "Alarm" icon and expect to see the alarmed frames (which I presume can then be saved). zmNinja shows the correct "N" number of alarmed frames, but they are simply the first N frames of the recording, not the actual alarmed frames.
The frames generated by the Alarm icon do not correspond to the Alarm frames shown under Events > Alarms.
Not sure if I'm misinterpreting the intended function of this feature or not.
Thanks,
Brian
asker
Re: zmNinja 1.2.27 - Problem with Alarm Frame Navigation
Post by asker »
Yes, indeed. I'll fix it - thanks for reporting.
Please read before posting:
ES docs
zmNinja docs
