Socket sendto error...maybe
Posted: Wed Oct 26, 2016 3:25 pm
Greetings,
My first post and I've read a bit around this issue but can't seem to find a solid answer to it so figured I would ask. My apologies if it has been addressed and I overlooked.
Running ZM 1.30 on Lubuntu 15.10. Build works as expected. Used the easy Wiki guide on building it and everything works as expected with the exception of one minor issue.
Sometimes I leave the montage running on a browser where I have script refreshing the web page every 15 minutes. It seems that it will run fine this way for sometimes a day or more, but after a random interval I will start getting socket sendto errors which eventually causes ZM to stop. Is my running and refreshing in a browser causing these errors? I've read that there is an issue with browsers at times, and I've attempted clearing cookies, etc... and the problem seems to persist. If I don't leave the montage running, I don't have the issue. I had the same issue with ZM 1.29 as well and is the only issue I have with it.
Is there any workaround to avoid this altogether, or will repetitive refreshing in a browser always cause this type of behavior?
Thanks in advance for your help!
