View Streaming Axis P3214-V
hyperlink2016
Post by hyperlink2016 »
Hi to everyone, first i apologize for my english, it is not very good. I want to ask for your help in a problem i'm having to add Axis P3214-V on the ZoneMinder.
I can't visualize the streaming, any kind of help is welcome...
Some data that may help
ZoneMinder Version 1.29.0 ( Pre-installed in Lubuntu 64bit)
Remote Protocol HTTP
Remote method Simple
Remote Host name (IP of the Camera)
Remote host port 80
Remote host path mjpg/1/video.mjpg
The camera was configure as Remote.
Thanks!!!
PacoLM
Re: View Streaming Axis P3214-V
Post by PacoLM »
Resolution?
hyperlink2016
PacoLM wrote:Resolution?
Te resolution is 1280x720 , another data that may hepl, is that de screen when i open for visualize de camera goes blue but in ther corner i can see date and time.
Thanks for your help!
PacoLM
Post by PacoLM »
Check that the path your are using is valid (i.e. in Chrome or other browser). Some system logs of Zoneminder will be useful too to help you debug your problem.
Also check that the PATH_ZMS (Options::Paths) is properly set to /zm/cgi-bin/nph-zms
Hope it helps,
PacoLM
