pink stream after some time ( SOLVED )
littlej
Post by littlej »
Hi, i have some COTIER IPc-631/T13 ip camera all working with zm 1.30.x set like in this topic (viewtopic.php?f=10&t=22386&p=89691&hilit=littlej#p89691)
The problem is after a while the stream gets all pink and wont get back only if i disable the monitor and re-enable it.
Any of you have any suggestions? I have to mention that no errors are displayed on logs.
solved. check the other post.
