Enable and convert MySQL to innodb file per table for Zoneminder
Camera_Doc
Post by Camera_Doc »
https://wiki.zoneminder.com/Enable_and_ ... Zoneminder
I have tried to follow this wiki but get an error on the following command
Verify all InnoDB tables gone
SELECT table_name, table_schema, engine FROM information_schema.tables WHERE engine = 'InnoDB';
bash: SELECT: command not found
What am I doing wrong?
Re: Enable and convert MySQL to innodb file per table for Zoneminder
What flavor and version of Linux are you running?
Which version of MySQL? If you are running MySQL 5.6 or beyond you do not need to do this as innodb_file_per_table is the default.
It has been a while since I ran that procedure so I did it again. The message you got is not an error but what should be returned if you did things right.
m3lab
Post by m3lab »
Camera_Doc wrote:https://wiki.zoneminder.com/Enable_and_ ... Zoneminder
Nothing ...
SELECT is a MySql command so the correct line should be
mysql SELECT ...
My best,
m.
Camera_Doc
I run zoneminder on a Raspberry Pi 2
Uninstalled Zoneminder changed to innodb in my.cnf.
Installed zonminder again.
Zoneminder has not stopped after the change.
Perhaps adding to https://wiki.zoneminder.com/Raspbian
This is what my my.cnf looks like
  • [mysqld]
    innodb_buffer_pool_size = 512m
    query_cache_type = 1
    innodb_buffer_pool_instances = 1
    query_cache_limit = 2M
