Page 1 of 1
No Log
Posted: Sun Dec 04, 2016 9:52 am
by Dalius
Hi there
Log window is empty:-(
Couldn't find any decent suggestion on the board - so am asking for a help here again;-)
Distro: Ubuntu 14.04.1
Any ideas?
Cheers,
D.
Re: No Log
Posted: Sun Dec 04, 2016 2:55 pm
by PacoLM
Is the logging enabled?
LOG_LEVEL_SYSLOG, LOG_LEVEL_FILE, LOG_LEVEL_WEBLOG and LOG_LEVEL_DATABASE are set to something different than None?
Re: No Log
Posted: Sun Dec 04, 2016 3:31 pm
by Dalius
LOG_LEVEL_SYSLOG - Info
LOG_LEVEL_FILE- none
LOG_LEVEL_WEBLOG - none
LOG_LEVEL_DATABASE - info
Re: No Log
Posted: Sun Dec 04, 2016 3:52 pm
by bbunge
Check these install instructions to see if you missed something:
Re: No Log
Posted: Sun Dec 04, 2016 4:30 pm
by Dalius
thanks a lot but...
double checked - all was there, except the delay... entered that, restarted zoneminder service manually - still no LOG entries appear:-(
Re: No Log
Posted: Fri Dec 16, 2016 6:41 pm
by Dalius
No more ideas? Would like to sort this out cause I have a much bigger problem: video stream disappears / becomes blue after a while... Can't figure out what's there happening because have no log:-(
Re: No Log
Posted: Sat Dec 17, 2016 12:15 am
by DanCoco
I resolved this by going into the logs table of the database and clearing it. The logs returned shortly afterward. Try a reboot after clearing.
