linking monitor, no results?
tazar
Post by tazar »
hi everybody,
i'm trying to configure a small (and underpowered) 4 cam server, to mocord on 3 of the 1080p cameras.
the HW is not able to process the 3fps at full resolution, so following another forum user example, I created 3 low-res 320x240 streams, on which is performed the motion detection. Then linked the low-res (configured in modect mode) to the hi-res (in record mode). I tried both to link low-res to hi-res, and viceversa.
I was aiming to get the alarm frames on the hi-res cam as well, in order to allow me to see the events directly from the hires monitor.
But i can't get it; in montage review mode, i can see the events only in the low-res modect monitors, not in hi-res record ones.
Schermata 2016-12-10 alle 17.24.02.png (183.56 KiB) Viewed 1399 times
In the hi-res monitor feed, i can't see any alarm frames as well...
Schermata 2016-12-10 alle 17.27.05.png (163.05 KiB) Viewed 1399 times
Substantially, i can't see any effect from the monitor linking... what am I doing wrong?
