ZoneMinder won't automatically start on boot
Posted: Mon Dec 19, 2016 12:23 am
I was able to install and manually start ZoneMinder 1.29 on Debian 8 following
https://media.readthedocs.org/pdf/zonem ... minder.pdf
However I'm unable to get it to start automatically on boot. For reasons I won't get into, Apache is running as admin, not www-data, so I've adjusted ZoneMinder's configuration and set permissions on a few files appropriately to get it to run.
Here's a typical log during boot startup:
One possible clue is the user/group on the /run/zm directory is NOT set to admin/admin, like it normally is when ZoneMinder is running correctly:
But I don't see any obvious way to control the way /run/zm gets created during boot.
Any idea why ZoneMinder isn't automatically starting on boot and how to fix?
Thanks,
Greg
2016-12-18 14:17:11.638670 zmpkg 3742 ERR Unable to run "/usr/bin/zmdc.pl startup", output is "Starting server" zmpkg.pl
2016-12-18 14:17:11.599610 zmdc 3970 FAT Can't connect: No such file or directory zmdc.pl
2016-12-18 14:17:05.010480 zmdc 3992 FAT Can't bind: Permission denied zmdc.pl
2016-12-18 14:17:01.440610 zmdc 3992 INF Server starting at 16/12/18 14:17:01 zmdc.pl
2016-12-18 14:16:56.358400 zmpkg 3742 INF Command: start zmpkg.pl
2016-12-18 14:16:56.148500 zmpkg 3742 INF Sanity checking States table... zmpkg.pl
# ls -al /run
drwxr-xr-x 2 www-data www-data 40 Dec 18 14:16 zm
Thanks,
Greg
