zmninja question
Posted: Sun Jan 01, 2017 8:18 pm
I have Zmninja set up an working when my android phone is connected to my local home network. My internal ZM server is 192.168.1.110. I want to be able to access this via the internet - but I don't want to use 443 - since it a well known port and easily scanned. So I confiugred my SSL port to be - say 50000 - and set up a port forwarding statement on my router for 50000. On my zmninja client I went into setup and AFTER the host name I added ":50000" for the portal, cgi, and api url. That all works - from my internet connected phone I can bring up ZM and see my cameras - but the API now fails. I have a TCPDUMP capture going on my local router - internet facing interface. I see all TCP50000 traffic coming in - but NOT any TCP9000. In ZMninja log I see what I THINK may be the issue: wss://192.168.1.110:9000 is being pushed down. If my phone is using that link than that is not going to work. If I bring up my OpenVPN client on my phone than ZMninja works perfectly. I have the VPN client confiugred to use my home router DNS - so the address that is pushed down for my ZM host is the 192.168.1.110 (so the traffic going to/from 192.168.1.x travels over the vpn tunnel). If the VPN is not running the ZM URL resolves via DDNS - my ISP IP address assigned to my router. Hoping "asker" can give me some pointers on how to get around this issue. I would prefer not to use OpenVPN - it adds another level of complexity. Thanks for any tips...
