Monitor Shows no image in ZM
amerdsp
Post by amerdsp »
I have a video source that can be accessed via an api: http://192.168.10.100/api/image/current
So if I use curl I get an image dump.
Using chrome, I am able to get an image (640x480)
However, when I configure ZM I don't get an image.
Source Type: Remote
Remote protocol: HTTP
Remote Method: Simple
Remote Host Name: 192.168.10.100
Remote Port: 80
Remote Host Path: /api/image/current
I get two different error message:
Invalid response status 404: Not Found
Unable to get response, disconnecting
What am I missing?
Thank you for your time and help.
amerdsp
Re: Monitor Shows no image in ZM
Post by amerdsp »
I just figured out the problem. I have two conflicting IPs on the network. All works now.
