Installed ZM on sda 1TB
Mounted 1TB sdb1 on storage
Mounted 1TB sdc1 on storage2
Added 2 X Ip cams
1st one recording to storage
2nd one recording to storage2
Here are the logs
System Log
Updated: Tue 17th Jan, 4:48pm State: alarm Total: 111638 Available: 111638 Displaying: 200
Filter log - Component
Server PID Level File Line
Date/Time
Component Server PID Level Message File Line
2017-01-17 16:48:47.926560 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:47.888580 zma_m2 1681 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664527 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:47.693260 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:47.663163 zma_m1 1678 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664527 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:45.705678 zma_m2 1681 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:45.594490 zmdc 1681 INF 'zma -m 2' started at 17/01/17 16:48:45 zmdc.pl
2017-01-17 16:48:45.594140 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:48:45, pid = 1681 zmdc.pl
2017-01-17 16:48:45.448990 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:48:45.430474 zma_m1 1678 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:45.401100 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664525-1484664517) zmwatch.pl
2017-01-17 16:48:45.313310 zmdc 1678 INF 'zma -m 1' started at 17/01/17 16:48:45 zmdc.pl
2017-01-17 16:48:45.312950 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:48:45, pid = 1678 zmdc.pl
2017-01-17 16:48:45.140230 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:48:45.107020 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 9 seconds (1484664525-1484664516) zmwatch.pl
2017-01-17 16:48:37.339520 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:37.296025 zma_m2 1675 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664517 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:37.140620 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:37.084787 zma_m1 1672 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664517 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:35.148808 zma_m2 1675 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:35.020170 zmdc 1675 INF 'zma -m 2' started at 17/01/17 16:48:35 zmdc.pl
2017-01-17 16:48:35.019830 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:48:35, pid = 1675 zmdc.pl
2017-01-17 16:48:34.870150 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:48:34.862497 zma_m1 1672 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:34.830510 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664514-1484664506) zmwatch.pl
2017-01-17 16:48:34.742340 zmdc 1672 INF 'zma -m 1' started at 17/01/17 16:48:34 zmdc.pl
2017-01-17 16:48:34.741960 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:48:34, pid = 1672 zmdc.pl
2017-01-17 16:48:34.636390 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:48:34.591970 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664514-1484664506) zmwatch.pl
2017-01-17 16:48:27.125450 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:27.079867 zma_m2 1669 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664507 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:26.499970 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:26.469597 zma_m1 1666 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664506 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:24.634688 zma_m2 1669 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:24.504570 zmdc 1669 INF 'zma -m 2' started at 17/01/17 16:48:24 zmdc.pl
2017-01-17 16:48:24.504050 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:48:24, pid = 1669 zmdc.pl
2017-01-17 16:48:24.355800 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:48:24.348648 zma_m1 1666 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:24.316620 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664503-1484664495) zmwatch.pl
2017-01-17 16:48:24.233400 zmdc 1666 INF 'zma -m 1' started at 17/01/17 16:48:24 zmdc.pl
2017-01-17 16:48:24.233040 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:48:24, pid = 1666 zmdc.pl
2017-01-17 16:48:24.130470 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:48:23.921480 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664503-1484664495) zmwatch.pl
2017-01-17 16:48:16.112680 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:16.068153 zma_m2 1663 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664496 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:15.904120 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:15.876778 zma_m1 1660 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664495 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:13.950339 zma_m2 1663 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:13.838910 zmdc 1663 INF 'zma -m 2' started at 17/01/17 16:48:13 zmdc.pl
2017-01-17 16:48:13.838520 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:48:13, pid = 1663 zmdc.pl
2017-01-17 16:48:13.693220 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:48:13.689114 zma_m1 1660 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:13.653510 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664493-1484664485) zmwatch.pl
2017-01-17 16:48:13.568270 zmdc 1660 INF 'zma -m 1' started at 17/01/17 16:48:13 zmdc.pl
2017-01-17 16:48:13.567890 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:48:13, pid = 1660 zmdc.pl
2017-01-17 16:48:13.451140 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:48:13.407790 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664493-1484664485) zmwatch.pl
2017-01-17 16:48:08.088626 zmc_m1 1514 INF Dahua on Storage 1: 1000 - Capturing at 4.95 fps zm_monitor.cpp 2955
2017-01-17 16:48:08.087276 zmc_m2 1515 INF Dahua on Storage 2: 1000 - Capturing at 4.95 fps zm_monitor.cpp 2955
2017-01-17 16:48:05.724600 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:05.686398 zma_m2 1657 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664485 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:05.358930 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:48:05.319099 zma_m1 1654 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664485 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:48:03.437139 zma_m2 1657 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:03.326990 zmdc 1657 INF 'zma -m 2' started at 17/01/17 16:48:03 zmdc.pl
2017-01-17 16:48:03.326600 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:48:03, pid = 1657 zmdc.pl
2017-01-17 16:48:03.171540 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:48:03.161997 zma_m1 1654 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:48:03.131820 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664482-1484664474) zmwatch.pl
2017-01-17 16:48:03.050090 zmdc 1654 INF 'zma -m 1' started at 17/01/17 16:48:03 zmdc.pl
2017-01-17 16:48:03.049770 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:48:03, pid = 1654 zmdc.pl
2017-01-17 16:48:02.946070 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:48:02.895360 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664482-1484664474) zmwatch.pl
2017-01-17 16:47:55.111610 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:55.073554 zma_m2 1651 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664475 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:54.946280 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:54.914308 zma_m1 1648 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664474 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:52.929598 zma_m2 1651 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:52.813880 zmdc 1651 INF 'zma -m 2' started at 17/01/17 16:47:52 zmdc.pl
2017-01-17 16:47:52.813540 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:47:52, pid = 1651 zmdc.pl
2017-01-17 16:47:52.666420 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:47:52.656739 zma_m1 1648 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:52.627200 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664472-1484664464) zmwatch.pl
2017-01-17 16:47:52.545710 zmdc 1648 INF 'zma -m 1' started at 17/01/17 16:47:52 zmdc.pl
2017-01-17 16:47:52.545400 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:47:52, pid = 1648 zmdc.pl
2017-01-17 16:47:52.432710 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:47:52.382800 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664472-1484664464) zmwatch.pl
2017-01-17 16:47:44.540380 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:44.501612 zma_m2 1644 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664464 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:44.331580 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:44.301130 zma_m1 1641 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664464 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:42.425875 zma_m2 1644 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:42.298310 zmdc 1644 INF 'zma -m 2' started at 17/01/17 16:47:42 zmdc.pl
2017-01-17 16:47:42.297960 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:47:42, pid = 1644 zmdc.pl
2017-01-17 16:47:42.180262 zma_m1 1641 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:42.179050 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:47:42.139740 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664461-1484664453) zmwatch.pl
2017-01-17 16:47:42.058580 zmdc 1641 INF 'zma -m 1' started at 17/01/17 16:47:42 zmdc.pl
2017-01-17 16:47:42.058210 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:47:42, pid = 1641 zmdc.pl
2017-01-17 16:47:41.953680 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:47:41.828240 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664461-1484664453) zmwatch.pl
2017-01-17 16:47:34.144420 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:34.084182 zma_m2 1638 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664454 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:33.919670 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:33.889171 zma_m1 1635 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664453 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:31.869068 zma_m2 1638 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:31.746560 zmdc 1638 INF 'zma -m 2' started at 17/01/17 16:47:31 zmdc.pl
2017-01-17 16:47:31.746030 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:47:31, pid = 1638 zmdc.pl
2017-01-17 16:47:31.635477 zma_m1 1635 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:31.633340 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:47:31.594430 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664451-1484664443) zmwatch.pl
2017-01-17 16:47:31.506310 zmdc 1635 INF 'zma -m 1' started at 17/01/17 16:47:31 zmdc.pl
2017-01-17 16:47:31.504990 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:47:31, pid = 1635 zmdc.pl
2017-01-17 16:47:31.382790 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:47:31.331950 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664451-1484664443) zmwatch.pl
2017-01-17 16:47:23.548590 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:23.509966 zma_m2 1632 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664443 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:23.356760 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:23.318406 zma_m1 1629 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664443 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:22.793072 web_js 1372 ERR TypeError: $(...).overlayShow is not a function http://192.165.10.250/zm/skins/classic/views/js/log.js 191
2017-01-17 16:47:21.360467 zma_m2 1632 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:21.248730 zmdc 1632 INF 'zma -m 2' started at 17/01/17 16:47:21 zmdc.pl
2017-01-17 16:47:21.248390 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:47:21, pid = 1632 zmdc.pl
2017-01-17 16:47:21.103990 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:47:21.102114 zma_m1 1629 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:21.064590 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664440-1484664432) zmwatch.pl
2017-01-17 16:47:20.977500 zmdc 1629 INF 'zma -m 1' started at 17/01/17 16:47:20 zmdc.pl
2017-01-17 16:47:20.977160 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:47:20, pid = 1629 zmdc.pl
2017-01-17 16:47:20.870270 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:47:20.819240 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664440-1484664432) zmwatch.pl
2017-01-17 16:47:13.144180 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:13.106211 zma_m2 1626 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664433 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:12.727320 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:12.691084 zma_m1 1623 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664432 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:10.860009 zma_m2 1626 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:10.730750 zmdc 1626 INF 'zma -m 2' started at 17/01/17 16:47:10 zmdc.pl
2017-01-17 16:47:10.730360 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:47:10, pid = 1626 zmdc.pl
2017-01-17 16:47:10.574380 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:47:10.564908 zma_m1 1623 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:10.535330 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664430-1484664422) zmwatch.pl
2017-01-17 16:47:10.453500 zmdc 1623 INF 'zma -m 1' started at 17/01/17 16:47:10 zmdc.pl
2017-01-17 16:47:10.452950 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:47:10, pid = 1623 zmdc.pl
2017-01-17 16:47:10.348870 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:47:10.299330 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664430-1484664422) zmwatch.pl
2017-01-17 16:47:02.531560 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:02.493533 zma_m2 1620 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664422 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:02.339490 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:47:02.297477 zma_m1 1617 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664422 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:47:00.343686 zma_m2 1620 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:00.206910 zmdc 1620 INF 'zma -m 2' started at 17/01/17 16:47:00 zmdc.pl
2017-01-17 16:47:00.206580 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:47:00, pid = 1620 zmdc.pl
2017-01-17 16:47:00.105561 zma_m1 1617 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:47:00.103520 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:47:00.063760 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664419-1484664411) zmwatch.pl
2017-01-17 16:46:59.973110 zmdc 1617 INF 'zma -m 1' started at 17/01/17 16:46:59 zmdc.pl
2017-01-17 16:46:59.972770 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:46:59, pid = 1617 zmdc.pl
2017-01-17 16:46:59.861450 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:46:59.836210 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664419-1484664411) zmwatch.pl
2017-01-17 16:46:52.161060 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:46:52.114283 zma_m2 1613 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664412 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:46:51.735310 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:46:51.688388 zma_m1 1610 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664411 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:46:49.865199 zma_m2 1613 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:46:49.754020 zmdc 1613 INF 'zma -m 2' started at 17/01/17 16:46:49 zmdc.pl
2017-01-17 16:46:49.753590 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:46:49, pid = 1613 zmdc.pl
2017-01-17 16:46:49.608030 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:46:49.581519 zma_m1 1610 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:46:49.551850 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664409-1484664401) zmwatch.pl
2017-01-17 16:46:49.466070 zmdc 1610 INF 'zma -m 1' started at 17/01/17 16:46:49 zmdc.pl
2017-01-17 16:46:49.465720 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:46:49, pid = 1610 zmdc.pl
2017-01-17 16:46:49.357590 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:46:49.308240 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664409-1484664401) zmwatch.pl
2017-01-17 16:46:41.557150 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:46:41.518576 zma_m2 1607 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664401 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:46:41.374250 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:46:41.326848 zma_m1 1604 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664401 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:46:39.338812 zma_m2 1607 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:46:39.224590 zmdc 1607 INF 'zma -m 2' started at 17/01/17 16:46:39 zmdc.pl
2017-01-17 16:46:39.224160 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:46:39, pid = 1607 zmdc.pl
2017-01-17 16:46:39.079350 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:46:39.068956 zma_m1 1604 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:46:39.039540 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664398-1484664390) zmwatch.pl
2017-01-17 16:46:38.956690 zmdc 1604 INF 'zma -m 1' started at 17/01/17 16:46:38 zmdc.pl
2017-01-17 16:46:38.956290 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:46:38, pid = 1604 zmdc.pl
2017-01-17 16:46:38.845640 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:46:38.794900 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 8 seconds (1484664398-1484664390) zmwatch.pl
2017-01-17 16:46:30.952910 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:46:30.914390 zma_m2 1597 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 2, 2, 'New Event', from_unixtime( 1484664390 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:46:30.736080 zmdc 1416 ERR 'zma -m 1' exited abnormally, exit status 112 zmdc.pl
2017-01-17 16:46:30.705660 zma_m1 1594 ERR Can't insert event: Column count doesn't match value count at row 1. sql was (insert into Events ( MonitorId, StorageId, Name, StartTime, Width, Height, Cause, Notes, StateId, Orientation, Videoed ) values ( 1, 1, 'New Event', from_unixtime( 1484664390 ), 2048, 1536, 'Continuous', '', 1, 1 )) zm_event.cpp 105
2017-01-17 16:46:28.836454 zma_m2 1597 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:46:28.709690 zmdc 1597 INF 'zma -m 2' started at 17/01/17 16:46:28 zmdc.pl
2017-01-17 16:46:28.709220 zmdc 1416 INF 'zma -m 2' starting at 17/01/17 16:46:28, pid = 1597 zmdc.pl
2017-01-17 16:46:28.558770 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 2 zmwatch.pl
2017-01-17 16:46:28.548284 zma_m1 1594 INF In mode 4/1, warming up zma.cpp 142
2017-01-17 16:46:28.519080 zmwatch 1488 INF Analysis daemon for Dahua on Storage 2 needs restarting, time since last analysis 8 seconds (1484664388-1484664380) zmwatch.pl
2017-01-17 16:46:28.438140 zmdc 1594 INF 'zma -m 1' started at 17/01/17 16:46:28 zmdc.pl
2017-01-17 16:46:28.437700 zmdc 1416 INF 'zma -m 1' starting at 17/01/17 16:46:28, pid = 1594 zmdc.pl
2017-01-17 16:46:28.300420 zmwatch 1488 INF Restarting analysis daemon for Dahua on Storage 1 zmwatch.pl
2017-01-17 16:46:28.250520 zmwatch 1488 INF Analysis daemon for Dahua on Storage 1 needs restarting, time since last analysis 9 seconds (1484664388-1484664379) zmwatch.pl
2017-01-17 16:46:20.575200 zmdc 1416 ERR 'zma -m 2' exited abnormally, exit status 112 zmdc.pl
