ONVIF Control Script for Reolink Cameras With Authentication
Posted: Fri Jan 20, 2017 1:47 am
Hello all,
After looking at the work on the Netcat script, I decided I wanted to make it work with my Reolink RLC-423 and RLC-411 cameras. One of the first challenges was that the Reolink cameras required authentication. The second was that I didn't actually know Perl......
After spending some time with Wireshark, and some documentation on the ONVIF authentication protocol, I was able to get something working.
Inspiration was also taken from viewtopic.php?f=9&t=25442 for the control address parsing.
A couple items of note:
1. I had to include MIME::Base64, Digest::SHA, and DateTime as dependencies for making authentication work
2. Reolink seems to like their presets in 3 digit form
Like I mentioned before, I didn't know Perl before embarking on this quest (still don't really
), so rookie mistakes are probably abound. I welcome any suggestions for improving the script. I haven't tested it out on my RLC-420, but it should work for the features it does support.
# ZoneMinder Reolink IP Control Protocol Module, Date: 2016-01-19
# Converted for use with Reolink IP Camera by Chris Swertfeger
# Copyright (C) 2016 Chris Swertfeger
# This module contains the first implementation of the Reolink IP camera control
# protocol
package ZoneMinder::Control::Reolink;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
our %CamParams = ();
# Reolink IP Control Protocol
# This script sends ONVIF compliant commands and may work with other cameras
# that require authentication
# The script was developed against a RLC-423 and RLC-411.
# Basic preset functions are supported, but more advanced features, which make
# use of abnormally high preset numbers (ir lamp control, tours, pan speed, etc)
# may or may not work.
# On ControlAddress use the format :
# USERNAME:PASSWORD@ADDRESS:PORT
# eg : admin:pass@10.1.2.1:8899
# admin:password@10.0.100.1:8899
# Use port 8000 by default for Reolink cameras
# Make sure and place a value in the Auto Stop Timeout field.
# Recommend starting with a value of 1 second, and adjust accordingly.
use Time::HiRes qw( usleep );
use MIME::Base64;
use Digest::SHA;
use DateTime;
my ($username,$password,$host,$port);
sub new
my $class = shift;
my $id = shift;
my $logindetails = "";
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $class = ref( ) || croak( "$self not object" );
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
sub open
my $self = shift;
$self->loadMonitor();
# Extract the username/password host/port from ControlAddress
if( $self->{Monitor}{ControlAddress} =~ /^([^:]+):([^@]+)@(.+)/ )
{ # user:pass@host...
$username = $1;
$password = $2;
$host = $3;
elsif( $self->{Monitor}{ControlAddress} =~ /^([^@]+)@(.+)/ )
{ # user@host...
$username = $1;
$host = $2;
else { # Just a host
$host = $self->{Monitor}{ControlAddress};
# Check if it is a host and port or just a host
if( $host =~ /([^:]+):(.+)/ )
$host = $1;
$port = $2;
else
$port = 80;
use LWP::UserAgent;
$self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $msg = shift;
my $content_type = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
my $server_endpoint = "http://".$host.":".$port."/$cmd";
my $req = HTTP::Request->new( POST => $server_endpoint );
$req->header('content-type' => $content_type);
$req->header('Host' => $host.":".$port);
$req->header('content-length' => length($msg));
$req->header('accept-encoding' => 'gzip, deflate');
$req->header('connection' => 'close');
$req->content($msg);
if ( $res->is_success ) {
$result = !undef;
} else {
Error( "After sending PTZ command, camera returned the following error:'".$res->status_line()."'" );
return( $result );
sub getCamParams
my $self = shift;
my $nonce;
for (0..20){$nonce .= chr(int(rand(254)));}
my $mydate = DateTime->now()->iso8601().'Z';
my $sha = Digest::SHA->new(1);
$sha->add($nonce.$mydate.$password);
my $digest = encode_base64($sha->digest,"");
my $msg = '<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GetImagingSettings xmlns="http://www.onvif.org/ver20/imaging/wsdl"><VideoSourceToken>000</VideoSourceToken></GetImagingSettings></s:Body></s:Envelope>';
my $server_endpoint = "http://".$self->{Monitor}->{ControlAddress}."/onvif/imaging";
$req->header('content-type' => 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/imaging/wsdl/GetImagingSettings"');
$req->header('connection' => 'Close');
# We should really use an xml or soap library to parse the xml tags
my $content = $res->decoded_content;
if ($content =~ /.*<tt:(Brightness)>(.+)<\/tt:Brightness>.*/) {
$CamParams{$1} = $2;
if ($content =~ /.*<tt:(Contrast)>(.+)<\/tt:Contrast>.*/) {
else
Error( "Unable to retrieve camera image settings:'".$res->status_line()."'" );
#autoStop
#This makes use of the ZoneMinder Auto Stop Timeout on the Control Tab
sub autoStop
my $self = shift;
my $autostop = shift;
if( $autostop ) {
Debug( "Auto Stop" );
my $cmd = 'onvif/PTZ';
my $nonce;
my $msg = '<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><Stop xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PanTilt>true</PanTilt><Zoom>false</Zoom></Stop></s:Body></s:Envelope>';
my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/ContinuousMove"';
usleep( $autostop );
$self->sendCmd( $cmd, $msg, $content_type );
# Reset the Camera
sub reset
Debug( "Camera Reset" );
my $self = shift;
my $nonce;
my $cmd = "";
my $msg = '<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SystemReboot xmlns="http://www.onvif.org/ver10/device/wsdl"/></s:Body></s:Envelope>';
my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver10/device/wsdl/SystemReboot"';
#Up Arrow
sub moveConUp
Debug( "Move Up" );
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0" y="0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
$self->autoStop( $self->{Monitor}->{AutoStopTimeout} );
#Down Arrow
sub moveConDown
Debug( "Move Down" );
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0" y="-0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Left Arrow
sub moveConLeft
Debug( "Move Left" );
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="-0.49" y="0" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Right Arrow
sub moveConRight
Debug( "Move Right" );
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0.49" y="0" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Zoom In
sub zoomConTele
Debug( "Zoom Tele" );
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><Zoom x="0.49" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Zoom Out
sub zoomConWide
Debug( "Zoom Wide" );
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><Zoom x="-0.49" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Up Right Arrow
#This camera does not have builtin diagonal commands so we emulate them
sub moveConUpRight
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0.5" y="0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Down Right Arrow
sub moveConDownRight
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0.5" y="-0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Up Left Arrow
sub moveConUpLeft
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="-0.5" y="0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Down Left Arrow
sub moveConDownLeft
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="-0.5" y="-0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Stop
sub moveStop
Debug( "Move Stop" );
my $self = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><Stop xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PanTilt>true</PanTilt><Zoom>false</Zoom></Stop></s:Body></s:Envelope>';
#Set Camera Preset
sub presetSet
my $self = shift;
my $params = shift;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SetPreset xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PresetToken>'.$preset.'</PresetToken></SetPreset></s:Body></s:Envelope>';
my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/SetPreset"';
#Recall Camera Preset
sub presetGoto
my $self = shift;
my $params = shift;
my $num = sprintf("%03d", $preset);
$num=~ tr/ /0/;
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GotoPreset xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PresetToken>'.$num.'</PresetToken></GotoPreset></s:Body></s:Envelope>';
my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/GotoPreset"';
#Horizontal Patrol
#To be determined if this camera supports this feature
sub horizontalPatrol
Debug( "Horizontal Patrol" );
my $self = shift;
my $cmd = '';
my $msg ='';
my $content_type = '';
# $self->sendCmd( $cmd, $msg, $content_type );
Error( "PTZ Command not implemented in control script." );
#Horizontal Patrol Stop
sub horizontalPatrolStop
Debug( "Horizontal Patrol Stop" );
my $self = shift;
my $cmd = '';
my $msg ='';
# Increase Brightness
sub irisAbsOpen
Debug( "Iris $CamParams{'Brightness'}" );
my $self = shift;
my $params = shift;
$self->getCamParams() unless($CamParams{'Brightness'});
my $step = $self->getParam( $params, 'step' );
my $max = 100;
$CamParams{'Brightness'} += $step;
$CamParams{'Brightness'} = $max if ($CamParams{'Brightness'} > $max);
my $cmd = 'onvif/imaging';
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SetImagingSettings xmlns="http://www.onvif.org/ver20/imaging/wsdl"><VideoSourceToken>000</VideoSourceToken><ImagingSettings><Brightness xmlns="http://www.onvif.org/ver10/schema">'.$CamParams{'Brightness'}.'</Brightness></ImagingSettings><ForcePersistence>true</ForcePersistence></SetImagingSettings></s:Body></s:Envelope>';
my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/imaging/wsdl/SetImagingSettings"';
# Decrease Brightness
sub irisAbsClose
my $self = shift;
my $params = shift;
$self->getCamParams() unless($CamParams{'brightness'});
my $min = 0;
$CamParams{'Brightness'} -= $step;
$CamParams{'Brightness'} = $min if ($CamParams{'Brightness'} < $min);
my $nonce;
# Increase Contrast
sub whiteAbsIn
Debug( "Iris $CamParams{'Contrast'}" );
my $self = shift;
my $params = shift;
$self->getCamParams() unless($CamParams{'Contrast'});
my $max = 100;
$CamParams{'Contrast'} += $step;
$CamParams{'Contrast'} = $max if ($CamParams{'Contrast'} > $max);
my $nonce;
my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SetImagingSettings xmlns="http://www.onvif.org/ver20/imaging/wsdl"><VideoSourceToken>000</VideoSourceToken><ImagingSettings><Contrast xmlns="http://www.onvif.org/ver10/schema">'.$CamParams{'Contrast'}.'</Contrast></ImagingSettings><ForcePersistence>true</ForcePersistence></SetImagingSettings></s:Body></s:Envelope>';
# Decrease Contrast
sub whiteAbsOut
my $self = shift;
my $params = shift;
my $min = 0;
$CamParams{'Contrast'} -= $step;
$CamParams{'Contrast'} = $min if ($CamParams{'Contrast'} < $min);
my $nonce;
1;
