Been using zoneminder for years.
I did a fresh install of CentOS 7.3 last Wednesday and installed zoneminder 1.30 from the centos repo.
Has been running fine until today.
Around 12:15 today, I began getting the error: ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone
The timezone is correctly set in php.ini
[Date]
ll /etc/localtime
lrwxrwxrwx. 1 root root 38 Jan 25 19:05 /etc/localtime -> ../usr/share/zoneinfo/America/New_York
Here's where it started:
Jan 31 12:15:19 ts130 zmc_dvideo0[13838]: INF [Den: 57000 - Capturing at 29.41 fps]
Jan 31 12:15:19 ts130 zmc_dvideo1[13864]: INF [Deck: 57000 - Capturing at 30.30 fps]
Jan 31 12:15:19 ts130 zmc_dvideo2[13890]: INF [Front: 57000 - Capturing at 30.30 fps]
Jan 31 12:15:19 ts130 zma_m1[13847]: INF [Den: 57000 - Analysing at 30.30 fps]
Jan 31 12:15:20 ts130 zmc_dvideo3[13917]: INF [Street: 57000 - Capturing at 29.41 fps]
Jan 31 12:15:20 ts130 zma_m2[13873]: INF [Deck: 57000 - Analysing at 29.41 fps]
Jan 31 12:15:20 ts130 zma_m3[13899]: INF [Front: 57000 - Analysing at 29.41 fps]
Jan 31 12:15:20 ts130 zma_m4[13925]: INF [Street: 57000 - Analysing at 30.30 fps]
Jan 31 12:15:41 ts130 web_php[15770]: FAT [ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone]
Jan 31 12:15:46 ts130 web_php[15770]: FAT [ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone]
Jan 31 12:15:47 ts130 web_php[15770]: FAT [ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone]
Jan 31 12:15:52 ts130 zmc_dvideo0[13838]: INF [Den: 58000 - Capturing at 30.30 fps]
Jan 31 12:15:52 ts130 zmc_dvideo1[13864]: INF [Deck: 58000 - Capturing at 30.30 fps]
Jan 31 12:15:53 ts130 zmc_dvideo2[13890]: INF [Front: 58000 - Capturing at 29.41 fps]
Jan 31 12:15:53 ts130 zma_m1[13847]: INF [Den: 58000 - Analysing at 29.41 fps]
Jan 31 12:15:53 ts130 zmc_dvideo3[13917]: INF [Street: 58000 - Capturing at 30.30 fps]
Jan 31 12:15:53 ts130 zma_m2[13873]: INF [Deck: 58000 - Analysing at 30.30 fps]
Jan 31 12:15:53 ts130 zma_m3[13899]: INF [Front: 58000 - Analysing at 30.30 fps]
There is only one version of php installed.
Been working on this since it started. I'm stuck.
Any help would be greatly appreciated.
Re: ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone
/etc/php5/cgi/php.ini
/etc/php5/apache2/php.ini
/etc/php5/fpm/php.ini
/etc/php5/cli/php.ini
You could find more files called php.ini by issuing the command find / -name php.ini (just trying to help here, do not know your linux skills).
On my system, the timezone is set on 3 out of 4 files:
$ grep timezone /etc/php5/apache2/php.ini
date.timezone = "Europe/Madrid"
$ grep timezone /etc/php5/cgi/php.ini
;date.timezone =
$ grep timezone /etc/php5/fpm/php.ini
$ grep timezone /etc/php5/cli/php.ini
So I would do those checks, maybe you need to setup your timezone in more than one file.
Hope it helps,
PacoLM
Are you 100% sure? I have a dedicated server with only the basics packages and I have 4 php.ini files on my computer (Ubuntu 14.04)There is only one version of php installed.
;date.timezone =
Hope it helps,
PacoLM
I ran locate php.ini and didn't find anything except one that is in a backup directory/partition I made after I backed up my old 6.8 system and did a fresh install of 7.3 I extracted the backup to help configure the new system.
phpinfo.php reports its using /etc/php.ini
I ran the command you provided and got the same result.
Something seems to be overridding it.
[SOLVED] Re: ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone
Added
php_value date.timezone "America/New_York"
to /etc/http/conf.modules.d/10-php.conf
Hi I having the same problem with my rasbian installation.
