Wire Once: Today Analog Video - Tommorro IP Camera
Posted: Fri Feb 03, 2017 2:58 pm
Just putting in this post for individuals dealing with wiring analog cameras. Installing wiring is time expensive - something that you won't want to have to redo if your upgrading later to digitial IP cameras.
Analog video is usually wired using coax cable or siamese coax. The siamese version allows power to be provided all in the same cable. Most will want to use siamese since only one cable needs to be run to the camera. A better approach though is to wire for the future using cat5e and use balum adapters.
The pair of balums are attached to cat5e cabling using standard rj45 connectors. The balums then split out the video signal and power supply. The balums also change (code/decode) the carrier frequency. Of course IP traffic cannot be used over the cat5e cabling while it is being used to carry the analog video signal.
- From cost perspective (siamese versus cat5e+balum) they are about the same. $100 for 1000 ft siamese versus $40 for cat5e, but balum's cost about $5 per camera. However, once the costs of upgrading to ip cameras are considered, there is a huge time savings.
For range perspective, cat5e+balum versus siamese, it is reported that there is no measurable difference at 300 foot and no perceptable difference up to about 700 foot.
