ZM Vulnerability
apbb2
ZM Vulnerability
Post by apbb2 »
Has anyone seen this:
http://www.securityfocus.com/bid/96120/info
Any thing end users can do to mitigate?
alabamatoy
Re: ZM Vulnerability
Post by alabamatoy »
alabamatoy wrote:This is bad. More info: http://seclists.org/bugtraq/2017/Feb/6
My router reported this site as malicious.
More harmful than Zoneminder, at least.
bb
Looks like this has been fixed in 1.30.2. At least my test machine will not let me browse http://ipaddr/zm/events
Here is a "fix" to block the directory browsing. I must admit it is partly my fault..
For Ubuntu
Undo my "Fix to allow API to work" (back to the original configuration)
nano /etc/apache2/apache2.conf
Change All to None in two places as shown below
<Directory /usr/share>
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/>
AllowOverride None
Require all granted
</Directory>
Ctrl+o Enter to save
CTRL+x to exit
Edit zoneminder.conf
Add a - before Indexes and a + before FollowSymLinks
Make sure the following is at the bottom of the file
AllowOverride All
</Directory>
CTRL+x to exit
Restart Apache
service apache2 reload
http://ip-addr/zm/events should now give you a Forbidden 403 error
alexo
Post by alexo »
Same is valid for 1.29 as I posted here -> viewtopic.php?f=34&t=25784
alexo wrote:Same is valid for 1.29 as I posted here -> viewtopic.php?f=34&t=25784
Yes, I know. The fix will be the same. Just did not have the time to do all that yesterday.
alabamatoy
bb
Seclists is only bad because it lists things like router vulnerabilities, that your router manufacturer probably doesn't want you to see. :-)
