Recordings cut off early
Posted: Wed Feb 08, 2017 7:47 pm
I'm new to ZM and installed 1.29 on Debian a few days ago. I have it configured with three IP cams set to modect operation mode.
In general, things work but I've noticed a few issues.
First, when motion is detected, it seems like >50% of the time the recording ends before the motion stops. As an example, I have a camera in my garage pointed at the garage door. When the door opens a recording starts, but only continues until the door is about 60-70% open. The last bit of motion is not recorded.
Second, I've noticed that in some circumstances recordings occur back to back. In other words, a recording will start due to a motion alarm, the recording will be a few seconds in duration, and then a second (and sometimes third, fourth, etc) recording will start immediately after the previous recording stops. This is such that if you took the frames from all recordings and stitched them together you wouldn't know they came from separate events.
What I've already done to try to solve the problem:
Set the presets for each camera zone to 'Best - High sensitivity'
Increased the post event image count buffer to 100 frames (these cameras record at ~20 FPS)
Neither of these changes has seemed to make much of a difference.
The ZM server has plenty of available disk / cpu / memory.
Any suggestions on how I can address these issues?
