which variable I need to modify in order to get ZM recording my events (modect) till there is no change in pixel/percentage anymore plus some extra seconds e.g. 3s.
I'm facing the problem that an event is often split into lots of events as ZM thinks it is over (no change for 1-2 seconds), while it is not and so creating another event shortly.
thx
How can I define, that ZM is recording an event + some extra seconds before closing the event?
Re: How can I define, that ZM is recording an event + some extra seconds before closing the event?
viewtopic.php?f=34&t=25813
Post event capture on the monitor buffer tab. Plus tuning motion better.
