Installation errors installing on Linux Mint
rlw
Post by rlw »
I have spent days trying to install without luck. The installation instructions I followed are Easy Way: Ubuntu 14.x (zoneminder.readthedocs.io/en/stable/installationguide/uabuntu.html#harder-way-build-package-from-source). I have checked these instructions plenty of times so pretty sure that I did everything as mentioned.
I'm using Linux Mint 18 Sarah. myPHPadmin works fine. Apache seems to work. ZM database is created (although all of the tables are empty). Zoneminder will not start.
SYSTEM STATUS ZONEMINDER.SERVICE SHOWS THE FOLLOWING:
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2017-02-13 20:43:25 EST; 19min ago
Process: 17120 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=255)
Feb 13 20:43:15 mintPC sudo[17133]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl startup
Feb 13 20:43:15 mintPC sudo[17133]: pam_unix(sudo:session): session opened for user www-data by (uid=0)
Feb 13 20:43:15 mintPC zmpkg.pl[17120]: Use of uninitialized value $Config{"ZM_PATH_SOCKS"} in concatenation (.) or string at /usr/bin/zmdc.pl line 72.
Feb 13 20:43:15 mintPC zmpkg.pl[17120]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Logger.pm line 155.
Feb 13 20:43:15 mintPC zmpkg.pl[17120]: Use of uninitialized value in concatenation (.) or string at /usr/share/perl5/ZoneMinder/Logger.pm line 205.
Feb 13 20:43:25 mintPC sudo[17133]: pam_unix(sudo:session): session closed for user www-data
Feb 13 20:43:25 mintPC systemd[1]: zoneminder.service: Control process exited, code=exited status=255
Feb 13 20:43:25 mintPC systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Feb 13 20:43:25 mintPC systemd[1]: zoneminder.service: Unit entered failed state.
Feb 13 20:43:25 mintPC systemd[1]: zoneminder.service: Failed with result 'exit-code'.
APPACHE ERROR LOG SHOWS
[Mon Feb 13 19:05:30.483033 2017] [ssl:warn] [pid 1808] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Mon Feb 13 19:05:33.996690 2017] [ssl:warn] [pid 1819] AH01909: 127.0.1.1:443:0 server certificate does NOT include an ID which matches the server name
[Mon Feb 13 19:05:33.999512 2017] [mpm_prefork:notice] [pid 1819] AH00163: Apache/2.4.18 (Ubuntu) OpenSSL/1.0.2g configured -- resuming normal operations
[Mon Feb 13 19:05:33.999544 2017] [core:notice] [pid 1819] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 13 19:10:14.868973 2017] [mpm_prefork:notice] [pid 1819] AH00171: Graceful restart requested, doing restart
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Re: Installation errors installing on Linux Mint
rlw
Post by rlw »
could you please clarify what you mean just a bit. ...
- Are you suggesting I use this 'Lubuntu 14.04 with Zoneminder 1.29.0 pre-configured CD or USB'
- or installing this 'Zoneminder 1.26.5-1 on Ubuntu 14.04 64 BIT' instead of 1.29
or try them both to see if one of them will resolve the issue?
No, I am suggesting you read the recommendations for installing Zoneminder on a desktop system. With a desktop system you need to get LAMP up and running before installing Zoneminder. I recommend you not use a desktop system to run Zoneminder as the GUI can eat up a lot of resources. We do not recommend you build from source unless you are a Linux wiz. The installs included with Ubuntu and the installs from the PPA will work if you follow the steps in the guides. If you want a way to manage the "server" remotely just install Webmin. Of course there are some learning curves to that as well...
rlw
Post by rlw »
thanks. I did go through the lamp installation although it was after installing zoneminder when I was trying to make it work. I will remove zoneminder then focus on lamp to make sure everything was installed and working before re-installing zoneminder.
I hadn't planned on using the desktop for the permanent install but wanted to check out zoneminder first and I do not have another machine where server can be set up at the moment so the resource issue is not really a concern at this point.
