Hi guys, I'm having a odd issue with zoneminder. I just installed the software today and im using Netcat Ip cameras.
Funny thing was that this was working flawlessly 1 hour ago. The only thing i have done is set the skin in the options and activated ZM Auth. (changed admin user as well).
IPCAM:2000 is the camera in question. (funny enough its connected randomly as you can see in the logs)
I have attachments of the error log.
Another note is that i have setup ZMninja and im able to view the camera through there.
I hoping someone with a little more experience will notice the errors and point me into the right direction.
Thanks guys!!
[Ubuntu 16.4 x64]: Zoneminder
- swindle720
- log.png (81.81 KiB) Viewed 1133 times
- result.png (12.59 KiB) Viewed 1133 times
Re: [Ubuntu 16.4 x64]: Zoneminder
I have also seen this before. If I remember I changed in Options AUTH_RELAY to "none" and the AUTH_TYPE is "built in". There was something with using Hashed or Plain that prevented viewing through the console. Check the stream URL that it contains the the correct parameters that you have selected in the Options. Does un-checking OPT_USE_AUTH allow you to view again as expected?
