zmninja and h.264(stotagelocations) branch
Posted: Sun Feb 19, 2017 3:40 pm
Just to say firstoff, use zmninja pro to keep an eye on my wee garage and it works like a champ.
I have set up a second server to experiment with the experimental branches of zoneminder (both servers being fed by the same cameras)
I have it set up so the low resolution camera feeds are set up normally in modect(or mocord cant remember) and the high resolution feeds are set to record and passthro (H.264) with no analysis, jsut dump to disk.
zmninja works straight out the box and perfectly with the low res feeds, and can monitor the high res feeds just fine in montage. the only thing it cant seem to do is playback the stored recordings from the high res feeds. no an issue really as I can see low res events just fine. Im wondering if this is likely to be supprted in future as ( I hope) the h264/storageareas features will be merged with the main branch as it really is awesome.
Am not asking for a feature request, as it relating to an experimental branch and frankly thatd just be cheeky, but this branch is proving stable enough i may migrate my main server over to it and would be nice to have it all working in zmninja if its on the horizon.
