Page 1 of 1
ERR [Failed to set picture attributes: Invalid argument]
Posted: Sun Aug 17, 2003 11:38 am
by will
After fixing everyhting (log files, access, ...), I still get an error message in the /var/log/messages
Does anybody get that as well ? Do you have any clue how to fix it ???
Will
Re: ERR [Failed to set picture attributes: Invalid argument]
Posted: Wed Aug 20, 2003 2:49 pm
by zoneminder
Do you know if you have STRICT_VIDEO_CONFIG set in your options? If so then it might be worth switching it off and seeing if that helps.
Regards,
Phil,
Posted: Wed Aug 20, 2003 6:50 pm
by will
The current value is 0, it is the default value (I never changed that)
Posted: Tue Feb 10, 2004 7:28 am
by gessel
I get something similar
zmc-d0[2309]: ERR [Failed to set window attributes: Invalid argument]
Also STRICT_VIDEO_CONFIG is set to off (unchecked).
-David
Posted: Tue Feb 10, 2004 11:08 am
by zoneminder
You will still get the error even with STRICT_VIDEO_CONFIG off, it just won't treat it as fatal. Does everything else work?
Phil,
