I'm unsure that my issue is related to my camera but I'll try to explain what I've done. I installed Zoneminder 1.30.0 on a brand new Debian stable. I used the unstable packages (so basically my system is now a mix of stable and unstable but that's not the point as some camera works). I have configured 3 types of camera (Honeywell branded) and 1 model is not working. The other two are OK.
In the one OK, I have a remote in simple mode with a mjpeg accessed in http. It's working exactly like when I open the URL in my firefox.
In the one not OK, I have setup exactly the same (remote / simple / http / mjpeg). When I access the URL in my firefox, i get moving frames. When I open the monitor with Zoneminder, I just see the name of the monitor and log is filling up :
2017-03-04 23:06:56.246548 zms 11111 ERR Terminating, last frame sent time 1488665215.746471 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2017-03-04 23:06:55.601578 web_js 10939 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-923745s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2017-03-04 23:06:55.485929 web_php 10939 ERR socket_sendto( /var/run/zm/zms-923745s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2017-03-04 23:06:44.066008 zms 11110 ERR Terminating, last frame sent time 1488665203.565958 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2017-03-04 23:06:43.497624 web_js 10939 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-923745s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2017-03-04 23:06:43.383788 web_php 10939 ERR socket_sendto( /var/run/zm/zms-923745s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 1993
2017-03-04 23:06:32.993508 zms 11109 ERR Terminating, last frame sent time 1488665192.493443 secs more than maximum of 10.000000 zm_monitor.cpp 4192
2017-03-04 23:08:20.869253 zmc_m2 11133 INF Starting Capture version 1.30.0 zmc.cpp 250
2017-03-04 23:08:15.813640 zmdc 10659 WAR Can't find process with command of 'zma -m 2' zmdc.pl
2017-03-04 23:08:15.683770 zmdc 11133 INF 'zmc -m 2' started at 17/03/04 23:08:15 zmdc.pl
2017-03-04 23:08:15.683770 zmdc 10659 INF 'zmc -m 2' starting at 17/03/04 23:08:15, pid = 11133 zmdc.pl
2017-03-04 23:08:15.555150 zmdc 10659 INF 'zmc -m 2' crashed, signal 8 zmdc.pl
2017-03-04 23:08:15.386220 zmdc 10659 WAR 'zmc -m 2' has not stopped at 17/03/04 23:08:15. Sending KILL to pid 10703 zmdc.pl
2017-03-04 23:08:09.385561 zmc_m2 10703 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-04 23:08:09.373500 zmdc 10659 INF 'zmc -m 2' sending stop to pid 10703 at 17/03/04 23:08:09 zmdc.pl
2017-03-04 23:08:09.243790 zmdc 10659 WAR Can't find process with command of 'zma -m 2' zmdc.pl
My only answer would be that this mjpeg stream is in some way not compatible with what the monitor is able to read ? But how can I know ? This is my only lead as this not working model is the oldest.
Regards,
