hi everyone,
i installed ZM 1.30.2 on Ubuntu 16.04
ZM i installed with h264 ppa below :
deb http://ppa.launchpad.net/iconnor/zonemi ... age/ubuntu xenial main
# deb-src http://ppa.launchpad.net/iconnor/zonemi ... age/ubuntu xenial main
sudo add-apt-repository ppa:iconnor/zoneminder-feature-h264-videostorage
my server is xeon x5650 , 12 CPU , 24GB ram
i run 25 camera IP with property : ffmpeg , fps 5 , record mode , h264 passthrough , buffer size 100 25 25 25
ZM only run about 10' then stop so CPU and RAM not use all , tmp file is not full
i attached file log so everyone help me check error why
thanks everyone very much
ZM only run 10' and change to "stop state"
- zm-log (2).txt
- (213.12 KiB) Downloaded 129 times
Re: ZM only run 10' and change to "stop state"
Check that your /dev/shm or /run/shm partition is not full.
this is my ubuntu server run :PacoLM wrote:Check that your /dev/shm or /run/shm partition is not full.
this is log when ZM was stopped :
2017-03-09 09:22:53.184438 zmc_m14 10416 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:53.184428 zmc_m10 10325 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:53.184419 zmc_m8 10273 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:53.184353 zmc_m7 10234 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:53.184314 zmc_m6 10207 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:53.184302 zmc_m4 10168 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:52.826200 zmpkg 12487 INF Command: stop zmpkg.pl
2017-03-09 09:22:52.727400 zmpkg 12487 INF Sanity checking States table... zmpkg.pl
2017-03-09 09:22:52.464120 zmdc 10124 INF 'zma -m 10' exited normally zmdc.pl
2017-03-09 09:22:52.022480 zmdc 10124 WAR 'zma -m 10' has not stopped at 17/03/09 09:22:52. Sending KILL to pid 12235 zmdc.pl
2017-03-09 09:22:51.781986 zma_m10 12235 INF 215: 526 - Closing event 1295, shutting down zm_monitor.cpp 625
2017-03-09 09:22:50.940535 zmc_m14 10416 INF 219: 46000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2017-03-09 09:22:46.157084 zma_m10 12235 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:45.868660 zmdc 10124 INF 'zma -m 10' sending stop to pid 12235 at 17/03/09 09:22:45 zmdc.pl
2017-03-09 09:22:45.631970 zmwatch 10779 INF Restarting analysis daemon for 215 zmwatch.pl
2017-03-09 09:22:45.590980 zmwatch 10779 INF Analysis daemon for 215 needs restarting, time since last analysis 6 seconds (1489026164-1489026158) zmwatch.pl
2017-03-09 09:22:45.404520 zmdc 10124 INF 'zma -m 6' exited normally zmdc.pl
2017-03-09 09:22:45.241773 zma_m6 12481 INF 211: 039 - Closing event 1303, shutting down zm_monitor.cpp 625
2017-03-09 09:22:45.062160 zma_m6 12481 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-03-09 09:22:44.906489 zmc_m13 10390 INF 218: 46000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2017-03-09 09:22:44.866010 zmdc 10124 INF 'zma -m 6' sending stop to pid 12481 at 17/03/09 09:22:44 zmdc.pl
2017-03-09 09:22:44.605500 zmwatch 10779 INF Restarting analysis daemon for 211 zmwatch.pl
2017-03-09 09:22:44.465270 zmwatch 10779 INF Analysis daemon for 211 needs restarting, time since last analysis 6 seconds (1489026164-1489026158) zmwatch.pl
2017-03-09 09:22:41.920652 zmc_m6 10207 INF 211: 47000 - Capturing at 8.00 fps zm_monitor.cpp 3125
2017-03-09 09:22:41.915968 zmc_m12 10364 INF 217: 46000 - Capturing at 8.00 fps zm_monitor.cpp 3125
