Page 1 of 1
Trendnet TV-IP651 PTZ Controls
Posted: Sat Mar 18, 2017 6:30 pm
by gengen
I created a control script for the Trendnet TV-IP651WI (I guess it also works for the other TV-IP651 models).
It is widely inspired by the work done by Art Scheel on the D-Link DCS-5020L script and Vincent Giovannone on the Trendnet TV-IP862 plus a bit of Wireshark to debug the Authentication and the day/night mode.
I tested it in Zoneminder 1.30.0 / Debian 9 Stretch.
Here it is :
# ZoneMinder Trendnet TV-IP651 IP Control Protocol Module, $Date: $, $Revision: $
# Copyright (C) 2017 GenGen
# This module contains the implementation of the Trendnet TV-IP651 IP camera
# control protocol.
# To add the TVIP651 profile, execute the following query :
# INSERT INTO Controls (Name, Type, Protocol, CanWake, CanSleep, CanReset, CanZoom, CanAutoZoom, CanZoomAbs, CanZoomRel, CanZoomCon, MinZoomRange, MaxZoomRange, MinZoomStep, MaxZoomStep, HasZoomSpeed, MinZoomSpeed, MaxZoomSpeed, CanFocus, CanAutoFocus, CanFocusAbs, CanFocusRel, CanFocusCon, MinFocusRange, MaxFocusRange, MinFocusStep, MaxFocusStep, HasFocusSpeed, MinFocusSpeed, MaxFocusSpeed, CanIris, CanAutoIris, CanIrisAbs, CanIrisRel, CanIrisCon, MinIrisRange, MaxIrisRange, MinIrisStep, MaxIrisStep, HasIrisSpeed, MinIrisSpeed, MaxIrisSpeed, CanGain, CanAutoGain, CanGainAbs, CanGainRel, CanGainCon, MinGainRange, MaxGainRange, MinGainStep, MaxGainStep, HasGainSpeed, MinGainSpeed, MaxGainSpeed, CanWhite, CanAutoWhite, CanWhiteAbs, CanWhiteRel, CanWhiteCon, MinWhiteRange, MaxWhiteRange, MinWhiteStep, MaxWhiteStep, HasWhiteSpeed, MinWhiteSpeed, MaxWhiteSpeed, HasPresets, NumPresets, HasHomePreset, CanSetPresets, CanMove, CanMoveDiag, CanMoveMap, CanMoveAbs, CanMoveRel, CanMoveCon, CanPan, MinPanRange, MaxPanRange, MinPanStep, MaxPanStep, HasPanSpeed, MinPanSpeed, MaxPanSpeed, HasTurboPan, TurboPanSpeed, CanTilt, MinTiltRange, MaxTiltRange, MinTiltStep, MaxTiltStep, HasTiltSpeed, MinTiltSpeed, MaxTiltSpeed, HasTurboTilt, TurboTiltSpeed, CanAutoScan, NumScanPaths) VALUES
# ('TVIP651', 'Remote', 'TVIP651', 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 24, 1, 0, 1, 1, 1, 0, 1, 0, 1, 0, 0, 1, 30, 0, 0, 0, 0, 0, 1, 0, 0, 1, 30, 0, 0, 0, 0, 0, 0, 0);
package ZoneMinder::Control::TVIP651;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
#  I have 2 "TV-IP651WI", each of them has its own realm :
#  "TV-IP651WI_" followed by two numbers.
#  Realm will be autodetected if "TV-IP651WI" doesn't match.
#  Username and password are extracted from the control address. It must have
#  the following format : username:password@address[:port]
#  If no port is specified, ":80" will be automatically added.
our $REALM = 'TV-IP651WI';
our $USERNAME = 'admin';
our $PASSWORD = '';
our $ADDRESS = '';
# Trendnet TV-IP651 Control Protocol
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    my ( $protocol, $username, $password, $address )
       = $self->{Monitor}->{ControlAddress} =~ /^(https?:\/\/)?([^:]+):([^\/@]+)@(.*)$/;
    if ( $username ) {
        $USERNAME = $username;
        $PASSWORD = $password;
        $ADDRESS = $address;
    } else {
        Error( "Failed to parse auth from address");
        $ADDRESS = $self->{Monitor}->{ControlAddress};
    if ( $ADDRESS !~ /:/ ) {
        Error( "You generally need to also specify the port.  I will append :80" );
        $ADDRESS .= ':80';
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".$ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
#   credentials:  ("ip:port" (no prefix!), realm (string), username (string), password (string)
    Debug ( "sendCmd credentials control address:'".$ADDRESS
            ."'  realm:'" . $REALM
            . "'  username:'" . $USERNAME
            . "'  password:'".$PASSWORD
    $self->{ua}->credentials($ADDRESS,$REALM,$USERNAME,$PASSWORD);
    # Detect REALM
    my $req = HTTP::Request->new( GET=>"http://".$ADDRESS."/pantiltcontrol.cgi" );
    if ( ! $res->is_success ) {
        Debug("Need newer REALM");
        if ( $res->status_line() eq '401 Authorization Required' ) {
            my $headers = $res->headers();
            foreach my $k ( keys %$headers ) {
                Debug("Initial Header $k => $$headers{$k}");
            }  # end foreach
            if ( $$headers{'www-authenticate'} ) {
                my ( $auth, $tokens ) = $$headers{'www-authenticate'} =~ /^(\w+)\s+(.*)$/;
                if ( $tokens =~ /\w+="([^"]+)"/i ) {
                    $REALM = $1;
                    Debug( "Changing REALM to $REALM" );
                } # end if
            } else {
                Debug("No headers line");
            } # end if headers
        } # end if $res->status_line() eq '401 Authorization Required'
    } # end if ! $res->is_success
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $url = shift;
    my $cmd = shift;
    my $result = undef;
    my $req = HTTP::Request->new(POST => "http://".$self->{Monitor}->{ControlAddress}.$url );
    $req->content_type('application/x-www-form-urlencoded');
    $req->content($cmd);
    Debug ( "sendCmdPost credentials control address:'".$ADDRESS."'  realm:'" . $REALM . "'  username:'" . $USERNAME . "' password:'".$PASSWORD."'");
    if ( $res->is_success )
        $result = !undef;
    else
        Error( "sendCmd Error check failed: '".$res->status_line()."' cmd:'".$cmd."'" );
        Error( "sendCmd Error check failed: username: $USERNAME realm: $REALM password: " . $PASSWORD );
    return( $result );
sub sendCmdPanTilt
    my $self = shift;
    my $cmd = shift;
    $self->sendCmd ("/pantiltcontrol.cgi", $cmd);
sub sendCmdDayNight
    my $self = shift;
    my $cmd = shift;
    $self->sendCmd ("/nightmodecontrol.cgi", $cmd);
sub move
    my $self = shift;
    my $dir = shift;
    my $panSteps = shift;
    my $tiltSteps = shift;
    my $cmd = "PanSingleMoveDegree=$panSteps&TiltSingleMoveDegree=$tiltSteps&PanTiltSingleMove=$dir";
    $self->sendCmdPanTilt( $cmd );
sub moveRelUpLeft
    my $self = shift;
    Debug( "Move Up Left" );
    $self->move( 0, 1, 1 );
sub moveRelUp
    my $self = shift;
    Debug( "Move Up" );
    $self->move( 1, 1, 1 );
sub moveRelUpRight
    my $self = shift;
    Debug( "Move Up" );
    $self->move( 2, 1, 1 );
sub moveRelLeft
    my $self = shift;
    Debug( "Move Left" );
    $self->move( 3, 1, 1 );
sub moveRelRight
    my $self = shift;
    Debug( "Move Right" );
    $self->move( 5, 1, 1 );
sub moveRelDownLeft
    my $self = shift;
    Debug( "Move Down" );
    $self->move( 6, 1, 1 );
sub moveRelDown
    my $self = shift;
    $self->move( 7, 1, 1 );
sub moveRelDownRight
    my $self = shift;
    $self->move( 8, 1, 1 );
# moves the camera to center on the point that the user clicked on in the video image.
# This isn't extremely accurate but good enough for most purposes
sub moveMap
    # if the camera moves too much or too little, try increasing or decreasing this value
    my $f = 11;
    my $self = shift;
    my $params = shift;
    my $xcoord = $self->getParam( $params, 'xcoord' );
    my $ycoord = $self->getParam( $params, 'ycoord' );
    my $hor = $xcoord * 100 / $self->{Monitor}->{Width};
    my $ver = $ycoord * 100 / $self->{Monitor}->{Height};
    my $direction;
    my $horSteps;
    my $verSteps;
    if ($hor < 50 && $ver < 50) {
        # up left
        $horSteps = (50 - $hor) / $f;
        $verSteps = (50 - $ver) / $f;
        $direction = 0;
    } elsif ($hor >= 50 && $ver < 50) {
        # up right
        $horSteps = ($hor - 50) / $f;
        $direction = 2;
    } elsif ($hor < 50 && $ver >= 50) {
        # down left
        $verSteps = ($ver - 50) / $f;
        $direction = 6;
    } elsif ($hor >= 50 && $ver >= 50) {
        # down right
        $direction = 8;
    my $v = int($verSteps + .5);
    my $h = int($horSteps + .5);
    Debug( "Move Map to $xcoord,$ycoord, hor=$h, ver=$v with direction $direction" );
    $self->move( $direction, $h, $v );
# this clear function works, but should probably be disabled because
# it isn't possible to set presets yet.
sub presetClear
    my $self = shift;
    my $params = shift;
    Debug( "Clear Preset $preset" );
    my $cmd = "ClearPosition=$preset";
# not working yet
sub presetSet
    my $self = shift;
    my $params = shift;
    # TODO need to first get current position $horPos and $verPos
    #my $cmd = "PanTiltHorizontal=$horPos&PanTiltVertical=$verPos&SetName=$preset&SetPosition=$preset";
    #$self->sendCmdPanTilt( $cmd );
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $cmd = "PanTiltPresetPositionMove=$preset";
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
    my $cmd = "PanTiltSingleMove=4";
# wake and sleep functions require the day/night mode to be set to "Manual"
sub wake
    my $self = shift;
    Debug( "Wake - IR on" );
    my $cmd = "IRLed=1";
    $self->sendCmdDayNight( $cmd );
sub sleep
    my $self = shift;
    Debug( "Sleep - IR off" );
    my $cmd = "IRLed=0";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for TV-IP651
=head1 SYNOPSIS
use ZoneMinder::Database;
Trendnet TV-IP651
=head1 DESCRIPTION
ZoneMinder driver for the Trendnet consumer camera TV-IP651.
=head2 EXPORT
None by default.
=head1 SEE ALSO
See if there are better instructions for the TV-IP651 at
https://wiki.zoneminder.com/Trendnet#TV-IP651W.28I.29
=head1 AUTHOR
GenGen, based on the work of :
- Art Scheel for D-Link DCS-5020L
- Vincent Giovannone for Trendnet TV-IP862
=head1 COPYRIGHT AND LICENSE
LGPLv3
=cut
Re: Trendnet TV-IP651 PTZ Controls
Posted: Mon Mar 20, 2017 9:29 am
by gengen
In the wiki, it's written (https://wiki.zoneminder.com/Trendnet#TV-IP651W.28I.29) :
The home position of the Trendnet TV-IP651W(I) camera is not settable, and as a result will always return to its default home position upon any reason for a reboot (power failure, crash, etc.). As a result, this camera should be considered unusable for any security use above a simple baby monitor. he wiki
It's true, but you can set a preset for your favorite position (through Trendnet administration webpage, my script can't do this for the moment), and then, call zmcontrol from the command line to set this position :
zmcontrol.pl --id 1 --command=presetGoto --preset=1
You will have to suit "id" and "preset" to your configuration.
This command can be automated trough a cron job, or added to the zoneminder start script.
It may not be fully satisfactory but if it can help...
In the next days, I will try to work on the setPreset and zoom functions...
Posted: Mon Mar 20, 2017 11:35 am
by SteveGilvarry
If their work was a starting point for you file leave any copyright statements in place like Copyright (C) 2014 Vincent Giovannone and add your own to it. Once you are ready let us know and we can help you push it to GitHub so it can become part of zm install.
Posted: Mon Mar 20, 2017 11:12 pm
by gengen
Ok,thank you for the information.
Sorry, I'm not familiar with these considerations.
Posted: Tue Sep 28, 2021 7:20 am
by andronks
Hi. I add setPreset
Sorry my debug.
# control protocol.
package MyAgent;
use base 'LWP::UserAgent';
use IO::Socket;
use MIME::Base64;
use 5.006;
use strict;
use warnings;
my $REALM = 'TV-IP651WI';
my $USERNAME = 'admin';
my $PASSWORD = 'admin';
my $ADDRESS = '192.168.0.20';
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
srand( time() );
return $self;
#our $AUTOLOAD;
#sub AUTOLOAD
# my $self = shift;
# my $class = ref($self) || croak( "$self not object" );
# my $name = $AUTOLOAD;
# $name =~ s/.*://;
# if ( exists($self->{$name}) )
# return( $self->{$name} );
# Fatal( "Can't access $name member of object of class $class" );
sub open
my $self = shift;
= $self->{Monitor}->{ControlAddress} =~ /^(http?:\/\/)?([^:]+):([^\/@]+)@(.*)$/;
if ( $username ) {
} else {
#Error( "You generally need to also specify the port. I will append :80" );
$ADDRESS .= ':80';
use LWP::UserAgent;
# Detect REALM
} # end foreach
$REALM = $1;
} # end if
} else {
} # end if headers
sub close
my $self = shift;
sub printMsg
my $self = shift;
my $msg = shift;
sub sendCmd
my $self = shift;
my $url = shift;
my $cmd = shift;
my $result = undef;
$result = !undef;
else
return( $result );
sub sendCmdPanTilt
my $self = shift;
my $cmd = shift;
sub sendCmdDayNight
my $self = shift;
my $cmd = shift;
sub move
my $self = shift;
my $dir = shift;
sub moveRelUpLeft
my $self = shift;
sub moveRelUp
my $self = shift;
Debug( "Move Up" );
sub moveRelUpRight
my $self = shift;
Debug( "Move Up" );
sub moveRelLeft
my $self = shift;
sub moveRelRight
my $self = shift;
sub moveRelDownLeft
my $self = shift;
sub moveRelDown
my $self = shift;
my $self = shift;
Debug( "Move DownRight" );
sub moveMap
#my $f = 11;
my $f = 5;
my $self = shift;
my $params = shift;
my $direction;
my $horSteps;
my $verSteps;
# up left
$direction = 0;
# up right
$direction = 2;
# down left
$direction = 6;
# down right
$direction = 8;
sub presetClear
my $self = shift;
my $params = shift;
sub presetSet
my $self = shift;
my $params = shift;
#Error( "Set Preset ($preset)." );
use LWP::UserAgent;
#$self->{ua}->agent( "ZoneMinder Control Agent/".$ZoneMinder::Base::ZM_VERSION );
$self->{ua}->agent( "user" );
my $addr = $self->{Monitor}->{ControlAddress};
$addr = substr($addr, index($addr, "@") + 1);
#Error("Address: $addr");
#my $req = HTTP::Request->new( HEAD=>"http://".$self->{Monitor}->{ControlAddress}."/mjpeg.cgi" );
#$req->content_type('application/x-www-form-urlencoded');
#$req->content("text=text&login=admin&passwd=176ce977");
#$req->content("");
#my $reqt = $self->{ua}->request($req)->as_string;
#Error("Set request $reqt");
#my $res = $self->{ua}->request($req);
#die "Hey, I was expecting HTML, not ", $res->content_type
#unless $res->content_type eq 'text/html';
#my $res = $self->{ua}->get("http://10.9.10.6/IOCONTROL.CGI");
#Error("Get http $res");
#if ( ! $res->is_success ) {
# Debug("Need newer REALM");
# if ( $res->status_line() eq '401 Authorization Required' ) {
# my $headers = $res->headers();
# foreach my $k ( keys %$headers ) {
# Error("Initial Header $k => $$headers{$k}");
# } # end foreach
# if ( $$headers{'www-authenticate'} ) {
# my ( $auth, $tokens ) = $$headers{'www-authenticate'} =~ /^(\w+)\s+(.*)$/;
# if ( $tokens =~ /\w+="([^"]+)"/i ) {
# $REALM = $1;
# Debug( "Changing REALM to $REALM" );
# $self->{ua}->credentials($ADDRESS,$REALM,$USERNAME,$PASSWORD);
# } # end if
# } else {
# Debug("No headers line");
# } # end if headers
# } # end if $res->status_line() eq '401 Authorization Required'
#} # end if ! $res->is_success
#Error( "Get success! $res");
#my $headers = $res->headers();
#my $head = $res->headers()->as_string;
#my $r = $res->as_string;
# } # end foreach
#Error("All Headers: $head");
#Error("All Response: $r");
my $sock = IO::Socket::INET->new(PeerAddr=>$addr,Proto=>'tcp',PeerPort=>80,);
#Error("Starting Sock");
return unless defined $sock;
$sock->autoflush(1);
#Error("Start Sock");
print $sock "GET /mjpeg.cgi HTTP/1.0\r\nUser-Agent: user\r\nAuthorization: Basic\r\n\r\n";
my $status = <$sock>;
#Error("Sock status: $status");
#die unless ($status =~ m|HTTP/\S+\s+401|);
my ($grab,$jpeg,$data,$image,$thisbuf,$lastimage);
while (my $nread = sysread($sock, $thisbuf, 4096)) {
$grab .= $thisbuf;
#Error("Sock buff: $grab");
$sock->close();
#my $srch = 'nonce="';
my ($snonce, $srealm);
#my $result = index($grab, $srch);
#if ($result != -1) {
# $snonce = substr($grab, $result + 7 , 42);
if (my $r = index($grab, "WWW-Authenticate") != -1) {
$snonce = substr($grab, index($grab, 'nonce="') + 7, 42);
$srealm = substr($grab, index($grab, 'realm="') + 7, 13);
#my $auth_param = $h->{auth_param};
my @auth_param;
$auth_param['username'] = $USERNAME;
$auth_param['realm'] = $REALM;
$auth_param['uri'] = "/mjpeg.cgi";
$auth_param['algorithm'] = "MD5";
$auth_param['nonce'] = $snonce;
$auth_param['cnonce'] = "";
$auth_param['qop'] = "auth";
$auth_param['nc'] = "1";
$auth_param['response'] = "";
my $cnonce = sprintf "%8x", time;
#my $nc = sprintf "%08X", ++$ua->{authen_md5_nonce_count}{$auth_param->{nonce}};
my $nc = sprintf "%08X", 1;
my $md5 = Digest::MD5->new;
my(@digest);
$md5->add(join(":", $USERNAME, $REALM, $PASSWORD));
my $HA1 = $md5->hexdigest;
push(@digest, $md5->hexdigest);
$md5->reset;
push(@digest, $snonce);
push(@digest, $nc, $cnonce, 'auth');
$md5->add(join(":", "GET", "/mjpeg.cgi"));
my $HA2 = $md5->hexdigest;
$md5->reset;
$md5->add(join(":", @digest));
my($digest) = $md5->hexdigest;
$md5->reset;
$md5->add(join(":", $HA1, $snonce, $nc, $cnonce, "auth", $HA2));
my $digestgen = $md5->hexdigest;
$md5->reset;
#my %resp = map { $auth_param->{$_} } qw(realm nonce opaque);
my %resp;
@resp{qw(realm nonce)} = ($REALM, $snonce);
@resp{qw(username uri response algorithm)} = ($USERNAME, "/mjpeg.cgi", $digestgen, "MD5");
@resp{qw(qop cnonce nc)} = ("auth", $cnonce, $nc);
my(@order) = qw(username realm uri algorithm nonce cnonce qop nc response);
$resp{"message-digest"} = $md5->hexdigest;
my @pairs;
for (@order) {
next unless defined $resp{$_};
# RFC2617 says that qop-value and nc-value should be unquoted.
if ( $_ eq 'qop' || $_ eq 'nc' ) {
push(@pairs, "$_=" . $resp{$_});
else {
push(@pairs, "$_=" . qq("$resp{$_}"));
my $auth_value = "Digest " . join(", ", @pairs);
#my $uspasswd = MIME::Base64::encode('admin:176ce977');
#my $ser = MIME::Base64::encode('YWRtaW46MTc2Y2U5Nzc=');
#my $mdigest = 'Digest username="admin", realm="TV-IP651WI_10", uri="/mjpeg.cgi", algorithm=MD5, nonce="4c8fdb0effd7d60cae43856a85314ab410.9.10.72", cnonce="$cnonce", qop=auth, nc=2, response="YWRtaW46MTc2Y2U5Nzc="';
#print $sock "GET /mjpeg.cgi HTTP/1.0\r\nUser-Agent: user\r\nAuthorization: Basic YWRtaW46MTc2Y2U5Nzc=\r\n\r\n";
#Error("Digest: $auth_value");
#my $status = <$sock>;
my $sockauth = IO::Socket::INET->new(PeerAddr=>$addr,Proto=>'tcp',PeerPort=>80,);
#Error("Starting Sock1");
return unless defined $sockauth;
$sockauth->autoflush(1);
#Error("Start Sock1 $auth_value");
#$sock->open();
print $sockauth "GET /mjpeg.cgi HTTP/1.0\r\nUser-Agent: user\r\nAuthorization: $auth_value\r\n\r\n";
$grab = "";
my $cnt = 0;
while (my $nread = sysread($sockauth, $thisbuf, 4096) && $cnt < 7) {
$grab .= $thisbuf;
$cnt++;
#my $nread1 = sysread($sockauth, $thisbuf, 4096);
#Error("Sock1 buff: $grab");
#$nread1 = sysread($sockauth, $thisbuf, 4096);
#Error("Sock1 buff: $thisbuf");
$sockauth->close();
my ($verPos, $horPos);
my $PO = index($grab, 'PT_');
$horPos = substr($grab, $PO + 3, 3);
$verPos = substr($grab, $PO + 7, 3);
#Error("Address: $addr Pos: $verPos $horPos");
#my $cmd = "PanTiltHorizontal&PanTiltVertical&SetName=$preset&SetPosition=$preset";
sub presetGoto
my $self = shift;
my $params = shift;
sub presetHome
my $self = shift;
sub wake
my $self = shift;
sub sleep
my $self = shift;
1;
__END__
=head1 NAME
=head1 SYNOPSIS
Trendnet TV-IP651
=head1 DESCRIPTION
=head2 EXPORT
None by default.
=head1 SEE ALSO
=head1 AUTHOR
LGPLv3
=cut
