Page 1 of 1
1.30.2 cannot login
Posted: Fri Mar 31, 2017 4:56 pm
by codabiz
Hi. I just upgraded to 1.30.2 (from 1.30.0) running on Ubuntu server 16.04 LTS. Upgrade went fine and zoneminder was working well, except for creating a new user (errors same as below).
I had previously added another user, so I removed the default admin user. When I restarted zoneminder again I got the new login layout, but I could not login with the new user. The error shown is:
SQL-ERR 'SQLSTATE[HY000]: General error: 1267 Illegal mix of collations (latin1_swedish_ci,IMPLICIT) and (utf8mb4_general_ci,COERCIBLE) for operation '='', statement was 'select * from Users where Enabled = 1 AND Username=? AND Password=password(?)'
As I am now locked out, any ideas how to fix it
Re: 1.30.2 cannot login
Posted: Fri Mar 31, 2017 7:26 pm
by jkemp
I also cannot login on a test system.
Posted: Fri Mar 31, 2017 7:30 pm
by jkemp
I had this happen and few weeks ago when this update creped into then main repository. I had to fall back to previous version.
"sudo apt install zoneminder=1.30.0-xenial1" if you are using ubuntu 16.04.1
I noticed it switched the skin to flat on the login screen that I could not log into. Once I fail back to 1.30.0 the classic dark login returned.
James
Posted: Fri Mar 31, 2017 7:40 pm
by codabiz
Ok. I went into zm database checked that user was correct. I removed the password from the db - put blank password. I attempted to log in again, I was prompted for a new password. Got the same error message.
Also removed language setting en-gb. Still the same SQL mixed collations message. I also had the skin change to blue.
I also noticed server/zm/api is no longer authenticated. Everything was OK with version 1.30.0
I am at a loss what to try next?
Posted: Fri Mar 31, 2017 7:47 pm
by jkemp
you can use script I listed to go back to the previous version in my message. Between the quotes.
Posted: Sat Apr 01, 2017 12:12 am
by bbunge
Did not have any issues upgrading Ubuntu 16.04/ZM 1.29.0 with Mariadb server to ZM 1.30.2.
If you are using MySQL 5.7 make sure this is in your my.cnf
I should add that I did a fresh install of ZM 1.30.2 on Ubuntu 16.04/MySQL 5.7 with no issues. See:
Re: 1.30.2 cannot login (Not 1.30.2 specific) fixed
Posted: Sat Apr 01, 2017 4:32 pm
by codabiz
After a bit of research: logged into mysql shell zm database and created a new password with:
> update Users set Password = password( "newpassword" ) where Username="user";
Again I got the SQL-ERR 1267 when trying to login?
My database showed +--------------------+---------+--------------------+
| zm | charset | collation |
| information_schema | utf8 | utf8_general_ci |
| mysql | utf8mb4 | utf8mb4_general_ci |
| performance_schema | utf8 | utf8_general_ci |
| zm | latin1 | latin1_swedish_ci |
But I am using MariaDB version 10.0.29 it shows charset = utf8mb4 , and collation = utf8_general_ci
So I decided to change MariaDB settings to match the ZM. (sudo nano /etc/mysql/my.cnf ) I added the new charset and collation and commented out the existing set, as follows.
character-set-server = latin1
collation-server = latin1_swedish_ci
#character-set-server = utf8mb4
#collation-server = utf8mb4_general_ci
Result - it worked. I can now log in as normal. I think this problem went back a couple of versions when I upgraded to MariaDB.
ZM version 1.30.2 is working great, except for the API issue and 401 error that has been reported elsewhere. I hope this fix helps others with the SQL-ERR 'SQLSTATE[HY000]: General error: 1267
If anyone has more knowledge on this issue, please post.
Posted: Sat Apr 01, 2017 5:13 pm
by bbunge
You may have something new! Why am I not surprised?
May I assume the language you use in Zoneminder is not English? Or is your OS not English?
If this is the case, I should place a note in the Mariadb instructions that "character-set-server = utf8mb4" and "collation-server = utf8mb4_general_ci" may need to be changed to match the language used?
Should this also apply to MySQL?
bb
Posted: Sat Apr 01, 2017 5:46 pm
by codabiz
From MariaDB website:
"In MariaDB, the default character set is latin1, and the default collation is latin1_swedish_ci (however this may differ in some distros, see for example Differences in MariaDB in Debian)"
I used Mysql (latin1 default) on Ubuntu 16.04.01 LTS until a couple of versions ago, then I upgraded to MariaDB on Ubuntu 16.04.01 LTS . Currently my MariaDB version is 10.0.29-0ubuntu0.16.04.1. So presumably on install the character set/collation was set to non-default mode for Debian/Ubuntu, as follows:
Or, should the zm character/collation have been changed to match the Ubuntu OS?
I know no more!
Posted: Sat Apr 01, 2017 7:22 pm
by bbunge
Well, I just upgraded my production server, Ubuntu 16.04, ZM 1.30.2 with Mariadb and ran into the same error when I tried to log in.
Fix was to edit my.cnf as follows:
Guess some more testing is in order... Stay tuned
Posted: Sat Apr 01, 2017 7:54 pm
by bbunge
Here are the changes I made to the WIKI Ubuntu instructions:
Change Mariadb settings:
Make the following changes:
