chinesee CAMERA IP
Loocar
chinesee CAMERA IP
Post by Loocar »
I`v bough chinesee CAMERA IP info form ONIVF Device Manager:
Locatin: country/china
Manufacturer: H264
Model: 53H20L_S39
Firmware: V4.02.R11.00002532.10010.240100..ONVIF 2.4
and through ONIVF Device Manager and VLC - there is no problem with striming
adress:rtsp://192.168.XX.XX:554/user=XXX_password=XXXX_channel=1_stream=0.sdp?real_stream
but I cant figure out how to set this "piece of art" in ZoneMinder
Remote RSTP - dont work
Libvls - dont work
FfMpeg - dont work
Do you have any idea ? how to set this ?
LOG:
ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
FAT Unable to create libvlc instance due to: (null)
Regards
Jack
Banderaz
Re: chinesee CAMERA IP
Post by Banderaz »
Bought something similar, so I'll follow this post.
One tip: On the ebay-page I bought mine, it was a review stating:
"It works in ZoneMinder
To make this camera working in zoneminder you need to use model preset.
Choose "Foscam FI8908W" and enter correct source path."
But no luck for me :(
Banderaz
Post by Banderaz »
Got the camera videofeed to show in VLC.
rtsp://192.168.0.xxx/user=admin&password=mypassword&channel=1&stream=1.sdp
But not any feed on zm. I also used the height/with that VLC reports.
Anyone got theese xmeye cameras to work in ZM?
