I can use ONVIF (in Windows) and VLC to view my camera but I cannot workout how to add it to ZM. I have tried FFMEG, RTSP all those type of settings and nothing is working. If I use vlc I can see and hear the camera at url rtsp:192.168.254.220/play1.sdp however as I said I can't get it to work no matter what settings I use.
Could anyone suggest something I could try or point me in the direction of something that may help.
Girkers
Help with adding camera to ZM, got working URL
Re: Help with adding camera to ZM, got working URL
It may be that capture is working, but something else makes you think it isn't.
If the url works in vlc, then it should work in ZM. Please provide some log content, and then maybe we can diagnose what is happening.
This is the problem it appears to work, but I get no picture. As you can see it appears to work:
I am currently using remote settings and when I open to look at the camera picture it shows me FPS and status idle but I get no picture. I try FFMpeg settings and get the exact same results.
2017-04-10 06:17:15.818185 zms 13667 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-04-10 06:16:06.134661 zmc_m1 13069 INF Pantry: 1000 - Capturing at 12.99 fps zm_monitor.cpp 3125
Girkers
Girkers
I'm having the same issue but different logs.
I'm a noob at least i was able to get to the console part. followed all the instruction in ZMREPO.
My system is
Fedora 25, Zm 1.30x
Thank you
Gerald
My system is
Fedora 25, Zm 1.30x
Thank you
Gerald
- Screenshot from 2017-04-18 22-29-36.png (88.37 KiB) Viewed 2433 times
- Screenshot from 2017-04-18 22-26-23.png (370.85 KiB) Viewed 2433 times
