View gapless events in numerical order?
DrJohn999
Post by DrJohn999 »
I have two cameras, one on the driveway and one on the front porch. If someone passes through the driveway active zone and then the porch active zone two events are recorded in sequential order, say 1234 and 1235. Later, the reverse might happen: first an alarm at the porch and then one at the driveway, number 1236 and 1237.
When I stream the events in "gapless" mode from the list of all events I only see events from one camera, not all events from both cameras in sequence. In this example, if I select event 1234 then event 1237 will play immediately afterwards, and events 1235 and 1236 will not play. If I start with 1235 then 1236 plays next, but not 1237. All of the events are listed in sequential order but only events from the camera associated with the first selected event are played.
Is it possible to cause events to play back in the order of their sequence number without regard to which camera was alarmed? Would be nice...
Re: View gapless events in numerical order?
Yeah the next event logic is kinda dumb. It could be made smarter that's for sure.
It's a code change. Very possible, just requires someone to do it.
