Browser Display gone (Solved)
ov10fac
Post by ov10fac »
I had to re-install zoneminder on my RaspberryPi yesterday. All went well until I opened the console this morning. I went to options as I have done in the past to change the appearance, selected a new screen and immediately received an error message that it doesn't exist and now I have a console that is completely useless.
How do I return to the default console and what do I need to do to make the display a little larger.
ov10fac
Re: Browser Display gone
Post by ov10fac »
Ok,
I think what I did was to change the zm_skin to mobile for my laptop. My bad, but now I have no idea how to change it back. Any suggestions? Thanks
OK, solved the problem. Cleared the cookies and the old display came back. The index.php searches cookies for the css that it should load. So figured if I cleared cookies it should resolve the issue, and it did.
