new install Ubuntu 16.04.2 LTS a2enmod zoneminder.conf issue
revmarkp
Post by revmarkp »
A new install on ubunutu server 16.04.02 for ZM 1.30.2; LAMP and SSH installed.
I opted for the MariahDB
All goes fine on the install, following the guide until:
a2enconf zoneminder
then:
ERROR: Module zoneminder does not exist!
I see the module here (is this the right place?)
markp@zoneminder:~$ ls /etc/apache2/conf-available/
charset.conf            localized-error-pages.conf    security.conf       zoneminder.conf
javascript-common.conf  other-vhosts-access-log.conf  serve-cgi-bin.conf
No symlink to /etc/apache2/conf-enabled so I create one myself (mistake??)so then:
markp@zoneminder:~$ ls /etc/apache2/conf-enabled
retry: a2enconf zoneminder
same error.
Now stumped! (apache is running, but not zm). Guidance for a noob much appreciated.
revmarkp
Re: new install Ubuntu 16.04.2 LTS a2enmod zoneminder.conf issue
Post by revmarkp »
Do I need to offer more info here for some help? Happy to do so, given a steer...
the symlink and position of the zoneminder.conf is correct. Did you restart Apache? Then try zoneminder again.
revmarkp
Post by revmarkp »
Sure, restarted everything and retried the 'a2enmod zoneminder.conf' again, always same error.
try this :
sudo ln -s /etc/zm/apache.conf /etc/apache2/conf-enabled/zoneminder.conf
restart Apache then try to start zoneminder.
the command is:
a2enconf zoneminder
bbunge wrote: Thu Apr 27, 2017 1:56 pm the command is:
a2enconf zoneminder
apparently this command has been tried and fails...
revmarkp
Post by revmarkp »
Solved! Thanks folks.
My stupid mistake was to confuse the apache enable commands: I was trying to
a2enmod zoneminder
when I should have been trying to
a2enconf zoneminder
In future I shall attempt to read the fine manual more carefully
My clue was
yea, that'll be because I needed to reference a config file not a module - even then i didn't get it. grrrr.
Thanks again.
Nice! that is the way to stick with it....slight mix up solved.
revmarkp
Post by revmarkp »
Thanks for the encouragement rockedge. I had a play with zoneminder several years ago, but at that time wifi IP cameras were v. expensive. I now have a real zoneminder running in one of my churches and was amazed at how easy it was to setup the network cameras. This system will complement (and eventually supersede I suspect) our Swann DVRs with analogue cameras. Loving the android app too (though not the adverts, lol).
Thanks Zoneminder and the OpenSource community!
Rev Mark
You may be interested to know that we use Zoneminder as the sole security system in Mission Central, an outreach of the UMC.
