Page 1 of 1
Ubuntu 16.04 with ZM 1.30.3
Posted: Wed May 03, 2017 11:33 pm
by bbunge
The earlier issue of the API not working has been fixed for Ubuntu 16.04. For a fresh install see:
If you have upgraded and the API does not work you can add the "missing link" php-apcu-bc which has been added to the iconnor PPA
apt update
apt install php-apcu-bc
Restart Apache
service apache2 reload
Re: Ubuntu 16.04 with ZM 1.30.3
Posted: Thu May 04, 2017 5:46 am
by fennec
nothing to do last update
zm 1.30.3 xenia8
but no api access
PHP Warning: include(Cake/bootstrap.php): failed to open stream: No such file or directory in /usr/share/zoneminder/www/api/app/webroot/index.php on line 90
[Thu May 04 07:43:16.360207 2017] [:error] [pid 24441] [client 10.0.0.1:42130] PHP Warning: include(): Failed opening 'Cake/bootstrap.php' for inclusion (include_path='/usr/share/zoneminder/www/api/lib:.:/usr/share/php') in /usr/share/zoneminder/www/api/app/webroot/index.php on line 90
[Thu May 04 07:43:16.360219 2017] [:error] [pid 24441] [client 10.0.0.1:42130] PHP Fatal error: CakePHP core could not be found. Check the value of CAKE_CORE_INCLUDE_PATH in APP/webroot/index.php. It should point to the directory containing your /cake core directory and your /vendors root directory. in /usr/share/zoneminder/www/api/app/webroot/index.php on line 99
[Thu May 04 07:43:46.317024 2017] [:error] [pid 24739] [client 10.0.0.186:52980] PHP Warning: include(Cake/bootstrap.php): failed to open stream: No such file or directory in /usr/share/zoneminder/www/api/app/webroot/index.php on line 90
[Thu May 04 07:43:46.317049 2017] [:error] [pid 24739] [client 10.0.0.186:52980] PHP Warning: include(): Failed opening 'Cake/bootstrap.php' for inclusion (include_path='/usr/share/zoneminder/www/api/lib:.:/usr/share/php') in /usr/share/zoneminder/www/api/app/webroot/index.php on line 90
[Thu May 04 07:43:46.317061 2017] [:error] [pid 24739] [client 10.0.0.186:52980] PHP Fatal error: CakePHP core could not be found. Check the value of CAKE_CORE_INCLUDE_PATH in APP/webroot/index.php. It should point to the directory containing your /cake core directory and your /vendors root directory. in /usr/share/zoneminder/www/api/app/webroot/index.php on line 99
Posted: Thu May 04, 2017 6:05 am
by fennec
ok after
sudo apt-get install cakephp
api ok
Posted: Thu May 04, 2017 3:29 pm
by jeffh
Thank you so much for the post!! I updated my Ubuntu 16.04LTS to zm 1.30.3 and my API stopped working (no zmNinja), until I grabbed the two packages and reloaded apache2.
Now the API is working fine again.
That's what I get for updating right away.
Posted: Thu May 04, 2017 6:48 pm
by bbunge
You do not need to add cakephp
Posted: Sun May 07, 2017 2:31 pm
by freff
Sadly, I also lost API access with Ubuntu 16.04 and ZM 1.30.3
I successfully performed the following but API still doesn't work
apt update
sudo service apache2 reload
sudo service zoneminder reload
rebooted zoneminder server
The following error continues to appear in the apache2 error.log
PHP Fatal error: Call to undefined function apc_fetch() in /usr/share/zoneminder/www/api/lib/Cake/Cache/Engine/ApcEngine.php on line 78
Can anyone please help?
Posted: Sun May 07, 2017 3:38 pm
by rockedge
I tried php5-apcu-bc and had no success but I after I installed php5-apcu and restarted the API worked again.
