I realize this looks a lot like a problem with the wired network. The POE is run through a 10/100/1000Mbps 4 port + 1 uplink Gigabit IEEE 802.3af PoE switch and ASUS RT-66U wireless router. Powering the POE switch (and thus the cameras) does not improve the frame rates. Rebooting the router doesn't fix the problem either.
The problem likely is not due to buffers:
~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 2.0G 0 2.0G 0% /dev
tmpfs 396M 5.6M 390M 2% /run
/dev/vda1 26G 18G 6.4G 74% /
tmpfs 2.0G 890M 1.1G 46% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
tmpfs 396M 0 396M 0% /run/user/1000
top - 08:37:02 up 13 min, 1 user, load average: 0.45, 0.62, 0.42
Tasks: 145 total, 2 running, 143 sleeping, 0 stopped, 0 zombie
%Cpu(s): 13.9 us, 0.6 sy, 0.0 ni, 80.3 id, 0.0 wa, 0.0 hi, 1.5 si, 3.8 st
KiB Mem : 4046304 total, 1988800 free, 628724 used, 1428780 buff/cache
KiB Swap: 4191228 total, 4191228 free, 0 used. 2254408 avail Mem
I would like to know if anyone else has seen a similar problem or has any ideas on how to chase this down.
Thanks,
John
