No image in Monitor window
Posted: Tue May 16, 2017 3:36 pm
Hello everybody,
I can't see the video stream when I'm clicking on the monitor view (called "Cuisine").
To make it happen until now, I just followed the useful Installation Guide "Easy Way: Ubuntu 16.04" and the install went perfectly.
I'm running Ubuntu 16.04.2 LTS with ZM 1.30.4
Here is the camera settings (model is ESCAM QD520 1/4" CMOS 720P):
I'm getting the following errors:
So I tried to change the PATH_ZMS to "/usr/lib/zoneminder/cgi-bin/nph-zms" or ""/usr/lib/zoneminder/cgi-bin/zms" (was /cgi-bin/nph-zms by default) but same error
My zoneminder.conf file:
And cgi seems enabled:
Do you have any idea?
Thank you very much!
Source type: Ffmpeg
Analysis FPS:
Maximum FPS:
Alarm Maximum FPS:
Source Path: rtsp://192.168.1.11:554/user=admin_password=tlJwpbo6_channel=1_stream=0.sdp?real_stream
Remote Method: TCP
Options:
Target colorspace: 32bit colour
Capture Width (pixels): 1280
Capture Height (pixels): 720
2017-05-16 17:25:37.106924 web_js[787].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-154899s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2017-05-16 17:25:36.976569 web_php[787].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [Socket /var/run/zm/zms-154899s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2017-05-16 17:25:26.700386 zmc_m2[875].INF-zm_monitor.cpp/3125 [Cuisine: 15000 - Capturing at 14.08 fps]
2017-05-16 17:25:24.975216 web_js[786].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-154899s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2017-05-16 17:25:24.848354 web_php[786].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [Socket /var/run/zm/zms-154899s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2017-05-16 17:25:12.842112 web_js[786].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-154899s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
2017-05-16 17:25:12.737665 web_php[786].ERR-/usr/share/zoneminder/www/includes/functions.php/2033 [Socket /var/run/zm/zms-154899s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.]
2017-05-16 17:25:00.739149 web_js[788].ERR-?view=watch [getStreamCmdResponse stream error: Socket /var/run/zm/zms-154899s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()]
AllowOverride All
Require all granted
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
AllowOverride All
</Directory>
newtof@linda:/etc/apache2/conf-enabled$ sudo a2enmod cgi
Module cgi already enabled
