Unable to connect to ZM db.could not find driver
hotswapster
Post by hotswapster »
After a fresh install on Ubuntu 16.04 following this wiki:
I had an error where this appeared when trying to access the web interface:
After much toking and froing I fixed it by running this command:
apt install php-mysql
I then restarted mysql, apache2 and zoneminder
Maybe this was missed in the wiki? I dunno. I'm not a linux ninja, but I figure others might have this trouble so have posted it.
Happy computing :)
Re: Unable to connect to ZM db.could not find driver
The WIKI does state:
Ubuntu Server Install: When prompted by Tasksel install OpenSSH Server, and LAMP Server.
Had you installed LAMP with tasksel it would have worked the first time!
kb-geez
Post by kb-geez »
I still have this error, and above did not fix it. thoughts?
