ZoneMinder failed to start
jkousholt
Post by jkousholt »
Hi guys
I'm having some trouble starting ZoneMinder 1.29
Linux version 3.16.0-4-amd64 (debian-kernel@lists.debian.org) (gcc version 4.8.4 (Debian 4.8.4-1) ) #1 SMP Debian 3.16.43-2 (2017-04-30)
I followed this guide https://wiki.zoneminder.com/Debian_8_64 ... e_Easy_Way
start zoneminder.service
root@debianserver:/home/jan# systemctl start zoneminder.service
Job for zoneminder.service failed. See 'systemctl status zoneminder.service' and 'journalctl -xn' for details.
But when i run
I get this result:
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
   Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled)
   Active: failed (Result: exit-code) since Fri 2017-06-16 22:38:19 CEST; 1h 13min ago
Jun 16 22:38:19 debianserver zmpkg.pl[15666]: Insecure directory in $ENV{PATH} while running with -T switch at /usr/share/perl5/ZoneMinder/Memory.pm line 140.
Jun 16 22:38:19 debianserver zmpkg.pl[15666]: Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 37.
Jun 16 22:38:19 debianserver zmpkg.pl[15666]: BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 37.
Jun 16 22:38:19 debianserver zmpkg.pl[15666]: Compilation failed in require at /usr/bin/zmpkg.pl line 48.
Jun 16 22:38:19 debianserver zmpkg.pl[15666]: BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 48.
Jun 16 22:38:19 debianserver systemd[1]: zoneminder.service: control process exited, code=exited status=2
Jun 16 22:38:19 debianserver systemd[1]: Failed to start ZoneMinder CCTV recording and surveillance system.
Jun 16 22:38:19 debianserver systemd[1]: Unit zoneminder.service entered failed state.
our $arch = 32 + 32*( qx(uname -m) =~ /64/ );
use ZoneMinder::Memory qw(:all);
use ZoneMinder;
logs
root@debianserver:/home/jan# tail -f /var/log/messages /var/log/httpd/error_log /var/log/zm/zm*.log
==> /var/log/messages <==
Jun 15 23:04:37 debianserver org.a11y.Bus[1033]: Reloaded configuration
Jun 16 06:25:03 debianserver rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="763" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Jun 16 06:30:01 debianserver rsyslogd0: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/0 ]
Jun 16 06:30:01 debianserver rsyslogd-2359: action 'action 17' resumed (module 'builtin:ompipe') [try http://www.rsyslog.com/e/2359 ]
Jun 16 07:01:52 debianserver rsyslogd-2007: action 'action 17' suspended, next retry is Fri Jun 16 07:02:22 2017 [try http://www.rsyslog.com/e/2007 ]
Jun 16 20:24:53 debianserver undef[7108]: INF [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
Jun 16 20:24:53 debianserver web_php[6812]: WAR [Unable to determine path for arp command, type -p arp returned '127' output is: -p: not found#012arp is /usr/sbin/arp]
Jun 16 20:25:38 debianserver undef[7336]: INF [No Server ID or Name specified in config.  Not using Multi-Server Mode.]
Jun 16 20:25:38 debianserver web_php[6856]: WAR [Unable to determine path for arp command, type -p arp returned '127' output is: -p: not found#012arp is /usr/sbin/arp]
tail: cannot open ‘/var/log/httpd/error_log’ for reading: No such file or directory
tail: cannot open ‘/var/log/zm/zm*.log’ for reading: No such file or directory
I can't change the status to "Start". It's keeps saying "Stopped".
The php page is "working", but why does it say "Failed to start ZoneMinder CCTV recording and surveillance system." when i view the service status?
I couldn't find anything regarding the "status=2" code.
Btw I'm toying around with to old webcams, which both appear when using Cheese. But I can't set them as monitors. Properly related to the error above.
Does anyone have some thoughts about this issue?
Re: ZoneMinder failed to start
I ran that install a week ago and it worked perfectly. Recommend you start over with a clean Debian 8.8 minimal install and try again. It is possible that something has changed in Debian 8.8. Am setting up to get Debian 9 so I will not take the time to review the install for Debian 8 until I am satisfied with the new version.
jkousholt
Post by jkousholt »
I'm running several services on the current server. Therefore I'm not keen on doing a clean Debian install.
How about running ZM on a VirtualBox?
How does it perform when using USB webcams?
