Zoneminder on CentOS7 no README.CentOS7
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
girkers
Post by girkers »
I am familiar with CentOS that is why I am using it and I have followed the instructions here: https://zmrepo.zoneminder.com/ for install on CentOS7 however there is no CentOS7 README. The only readmes I have are:
  • README.https
    README.md
    README.Redhat7
Now I have read through the start of the Redhat7 document but I stall at the first command:
sudo dnf install mariadb-server
There is no dnf command and I cannot find one in yum.
Can anyone point me to the correct readme so I can complete my install, thanks.
Cheers
Girkers
girkers
Re: Zoneminder on CentOS7 no README.CentOS7
Post by girkers »
I was able to complete the install by swapping the dnf command for yum however the website listed above may need to be updated or add the README. A little confusing when you want to follow everything to the letter to make sure you don't stuff something up.
Cheers
Girkers
