save events as a mp4 file and JPGs
Posted: Fri Jul 07, 2017 1:10 pm
After long time i have found way to deal with my files with zoneminder.
Now I have to archive all events from this videos, which I am putting to ZM via 'ffmpeg' input. Monitor type is "Modect'
I would like to scan big video footage and remove it.
How can I save only parts with motion when the movement is detected ? Material has 24hr and movement is about 3minutes. So, I would expect to trim that moment by ZM and save into it's database.
Would be great if there will be possibility grab all frame to separate jpg file.
And I would like to have access to that through the ZM console.
regards
regards
