Newbie trying to install
paulkruger
Post by paulkruger »
I have to assume I want the most recent distribution.
There does not appear to be any forum section for new users to get started so I will start here.
I am having problems just finding packages to install. I am using Ubuntu 16x recent updated to latest. It is running on an Intel Atom IX.
I have tried the apt-get and while it seems to be installing I cannot find it anywhere.
I looked for distros and even though I added the package library when I search in packages for zoneminder it says not found?
Nothing in the zoneminder packages information seems to have a place to just download the package? It's all written for a linux guru not an novice.
Is there a clear set of instructions to download, install and configure zoneminder that a novice linux guy can use?
Is there a better option than Ubuntu? I have no problem wiping the HDD and starting from scratch since I am not planning on using this box for anything other than zoneminder. I actually prefer the most basic installation with GUI I can have and don't need word processors, email programs or anything of that kind. Just video system.
Any help appreciated.
Re: Newbie trying to install
There is a WIKI area with install instructions for Ubuntu:
https://wiki.zoneminder.com/Ubuntu
While the "latest" is not covered there you can use https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
If you want to use the development version use add-apt-repository ppa:iconnor/zoneminder-master
in lieu of add-apt-repository ppa:iconnor/zoneminder
Stick with a Ubuntu server or minimal install and run the install process from another PC via a client like Putty. The instructions are written so you can copy and paste commands into a Putty or other client window. I have done these installs from a Windows, OSX and Linux desktop. The choice is yours!
Also, there is a pre-configured setup you can download and run or install: https://wiki.zoneminder.com/Lubuntu_16. ... DVD_or_USB
