zoneminder running with failure status
Posted: Sun Aug 06, 2017 2:32 pm
Hi, I have another question. Zoneminder suddenly stopped working.
I ran sudo systemctl status zoneminder
why does it show failure?
Process: 16374 ExecStop=/usr/bin/zmpkg.pl stop (code=exited, status=1/FAILURE)
Process: 13126 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
I ran
sudo systemctl start zoneminder
sudo systemctl status zoneminder and it shows the following:
there are still errors in the process but zoneminder was running. Can somebody help explain to me what is written?
2017-08-05 14:50:14.869078 zma_m1 16184 INF Monitor-1: 13016 - Closing event 2903, shutting down zm_monitor.cpp 625
2017-08-05 14:50:14.845582 zma_m2 13264 INF Monitor-2: 123332 - Closing event 2905, shutting down zm_monitor.cpp 625
2017-08-05 14:50:14.571243 zma_m2 13264 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-08-05 14:50:14.570994 zma_m1 16184 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-08-05 14:50:14.560588 zmc_dvideo1 13245 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-08-05 14:50:13.501990 zmpkg 16374 INF Command: stop zmpkg.pl
2017-08-05 14:50:13.300770 zmpkg 16374 INF Sanity checking States table... zmpkg.pl
2017-08-05 14:50:12.332190 zmdc 13160 INF 'zmc -d /dev/video0' crashed, signal 8 zmdc.pl
2017-08-05 14:50:12.121480 zmdc 13160 WAR 'zmc -d /dev/video0' has not stopped at 17/08/05 14:50:12. Sending KILL to pid 16283 zmdc.pl
2017-08-05 14:50:11.081520 zmdc 13160 WAR 'zmc -d /dev/video0' has not stopped at 17/08/05 14:50:11. Sending KILL to pid 16283 zmdc.pl
2017-08-05 14:50:05.080182 zmc_dvideo0 16283 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-08-05 14:50:05.043810 zmdc 13160 INF 'zmc -d /dev/video0' sending stop to pid 16283 at 17/08/05 14:50:05 zmdc.pl
2017-08-05 14:50:04.290450 zmwatch 13303 INF Restarting capture daemon for Monitor-1, time since last capture 10 seconds (1501915804-1501915794) zmwatch.pl
2017-08-05 14:50:00.224969 zma_m2 13264 INF Monitor-2: 123260 - Opening new event 2905, section start zm_monitor.cpp 1541
2017-08-05 14:50:00.106319 zma_m2 13264 INF Monitor-2: 123260 - Closing event 2904, section end
zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sat 2017-08-05 14:50:15 PHT; 7min ago
Main PID: 13160 (code=exited, status=4)
Aug 05 14:50:14 mutestcctv sudo[16391]: pam_unix(sudo:session): session opened for user www-dat
Aug 05 14:50:14 mutestcctv sudo[16391]: pam_unix(sudo:session): session closed for user www-dat
Aug 05 14:50:14 mutestcctv systemd[1]: zoneminder.service: Control process exited, code=exited
Aug 05 14:50:14 mutestcctv zmc_dvideo1[13245]: INF [Got signal 15 (Terminated), exiting]
Aug 05 14:50:14 mutestcctv zma_m2[13264]: INF [Got signal 15 (Terminated), exiting]
Aug 05 14:50:14 mutestcctv zma_m1[16184]: INF [Got signal 15 (Terminated), exiting]
Aug 05 14:50:14 mutestcctv zma_m2[13264]: INF [Monitor-2: 123332 - Closing event 2905, shutting
Aug 05 14:50:14 mutestcctv zma_m1[16184]: INF [Monitor-1: 13016 - Closing event 2903, shutting
Aug 05 14:50:15 mutestcctv systemd[1]: zoneminder.service: Unit entered failed state.
Aug 05 14:50:15 mutestcctv systemd[1]: zoneminder.service: Failed with result 'exit-code'.
I ran
Active: active (running) since Sat 2017-08-05 14:58:03 PHT; 1s ago
Process: 16688 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 16722 (zmdc.pl)
CGroup: /system.slice/zoneminder.service
├─16722 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
├─16771 /usr/bin/zmc -d /dev/video0
├─16777 /usr/bin/zma -m 1
├─16838 /usr/bin/zma -m 2
├─16845 /usr/bin/perl -wT /usr/bin/zmfilter.pl
├─16860 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
├─16877 /usr/bin/perl -wT /usr/bin/zmwatch.pl
├─16895 /usr/bin/perl -w /usr/bin/zmupdate.pl -c
└─16909 /usr/bin/perl -w /usr/bin/zmtelemetry.pl
Aug 05 14:58:02 mutestcctv zmdc[16722]: INF ['zmupdate.pl -c' starting at 17/08/05 14:58:02, pi
Aug 05 14:58:02 mutestcctv sudo[16885]: pam_unix(sudo:session): session closed for user www-dat
Aug 05 14:58:02 mutestcctv sudo[16901]: root : TTY=unknown ; PWD=/usr/share/zoneminder/www
Aug 05 14:58:02 mutestcctv sudo[16901]: pam_unix(sudo:session): session opened for user www-dat
Aug 05 14:58:02 mutestcctv zma_m2[16838]: WAR [Waiting for capture daemon]
Aug 05 14:58:03 mutestcctv zmdc[16909]: INF ['zmtelemetry.pl' started at 17/08/05 14:58:03]
