Multiserver misc issues
marcopete87
Post by marcopete87 »
Hello all, i've configured an multiserver setup:
both: ubuntu, zoneminder 1.30.4
1) my nuc, plenty of ram, which shares via smb zoneminder folder and let other zm servers to connect on its database.
2) an raspberry pi 3, which try to capture an 15fps 1280x720 h264 stream.
My problems are:
1) at midnight, some events are deleted from disk (both servers are synchronized with ntp), but events persists in DB; i don't think it is an disk related issue, because i use multiple disks, 2-3 cameras for disk, this error appears on 2 disks ok 3, all disks have 30-40% of free space, fschk return ok.
2) raspberry pi 3 throws errors like this: "2017-08-08 18:47:00.682070 zma_m8 PI3 7395 WAR Error stat'ing events/8/17/08, may be fatal. error is Value too large for defined data type zm_event.cpp 130"; event id are greater than 919287 (which was yesterday first event)
3) both servers seems don't want to communicate: montage review shows only current server streams, other servers sources are red; clicking over stream name, show stream correctly on all servers.
4) RPI won't log analysis fps (which is useful to me).
Despite 40-50% per cpu usage, raspberry pi 3 seems to create only 7-8 fps on mocord (with an little zone); is it an normal value?
Thanks to all for every advice!
Re: Multiserver misc issues
#1: odd. zmaudit.pl must be deleting them, but the db records should go as well. You should check the logs.
#2: Apparently it means that the pi's were not compiled with large file support...I guess I will have to install ubuntu on a pi and see what we get.
#3: You may have to turn on AUTH relay, as the different machines don't share session data.
#4: interesting. Can't imagine why not.
marcopete87
#1
this is all logs i have, affected monitor are 1, 5, 2 and 8
human readable datetime, component, server name, message
'2017-08-08 23:57:13.611318','zma_m4','nuc','Retro: 269000 - Analysing at 15.15 fps'
'2017-08-08 23:57:20.981940','zmfilter',NULL,'Deleting event 921398 from Monitor 4'
'2017-08-08 23:57:21.933700','zmfilter',NULL,'Deleting event 921399 from Monitor 3'
'2017-08-08 23:57:21.955180','zmfilter',NULL,'Deleting event 921400 from Monitor 1'
'2017-08-08 23:57:21.979400','zmfilter',NULL,'Deleting event 921401 from Monitor 5'
'2017-08-08 23:57:21.993060','zmfilter',NULL,'Deleting event 921402 from Monitor 6'
'2017-08-08 23:57:22.004160','zmfilter',NULL,'Deleting event 921403 from Monitor 2'
'2017-08-08 23:57:22.085590','zmfilter',NULL,'Deleting event 921404 from Monitor 8'
'2017-08-08 23:57:22.190060','zmfilter',NULL,'Deleting event 921405 from Monitor 6'
'2017-08-08 23:57:22.212930','zmfilter',NULL,'Deleting event 921406 from Monitor 3'
'2017-08-08 23:57:22.223340','zmfilter',NULL,'Deleting event 921407 from Monitor 4'
'2017-08-08 23:57:22.331800','zmfilter',NULL,'Deleting event 921408 from Monitor 5'
'2017-08-08 23:57:22.348170','zmfilter',NULL,'Deleting event 921409 from Monitor 1'
'2017-08-08 23:57:22.365340','zmfilter',NULL,'Deleting event 921410 from Monitor 2'
'2017-08-08 23:57:22.438750','zmfilter',NULL,'Deleting event 921411 from Monitor 8'
'2017-08-08 23:57:22.506500','zmfilter',NULL,'Deleting event 921412 from Monitor 1'
'2017-08-08 23:57:22.519540','zmfilter',NULL,'Deleting event 921413 from Monitor 6'
'2017-08-08 23:57:22.535340','zmfilter',NULL,'Deleting event 921414 from Monitor 3'
'2017-08-08 23:57:22.551820','zmfilter',NULL,'Deleting event 921415 from Monitor 5'
'2017-08-08 23:57:22.568340','zmfilter',NULL,'Deleting event 921416 from Monitor 4'
'2017-08-08 23:57:22.673470','zmfilter',NULL,'Deleting event 921417 from Monitor 2'
'2017-08-08 23:57:22.734660','zmfilter',NULL,'Deleting event 921418 from Monitor 8'
'2017-08-08 23:57:22.790350','zmfilter',NULL,'Deleting event 921419 from Monitor 3'
'2017-08-08 23:57:22.801800','zmfilter',NULL,'Deleting event 921420 from Monitor 4'
'2017-08-08 23:57:22.881810','zmfilter',NULL,'Deleting event 921421 from Monitor 5'
'2017-08-08 23:57:22.896450','zmfilter',NULL,'Deleting event 921422 from Monitor 6'
'2017-08-08 23:57:22.913000','zmfilter',NULL,'Deleting event 921423 from Monitor 1'
'2017-08-08 23:57:22.933040','zmfilter',NULL,'Deleting event 921424 from Monitor 2'
'2017-08-08 23:57:23.001940','zmfilter',NULL,'Deleting event 921425 from Monitor 8'
'2017-08-08 23:57:23.878892','zmc_m3','nuc','Portone: 449000 - Capturing at 25.00 fps'
'2017-08-08 23:57:24.230907','zmc_m1','nuc','Retro_casa: 449000 - Capturing at 25.00 fps'
'2017-08-08 23:57:27.921208','zmc_m8','PI3','Taverna: 268000 - Capturing at 15.15 fps'
'2017-08-08 23:57:36.310460','zma_m8','PI3','Taverna: 118000 - Analysing at 9.43 fps'
'2017-08-08 23:57:38.838075','zmc_m5','nuc','Portico_avanti: 323000 - Capturing at 18.18 fps'
'2017-08-08 23:57:38.868487','zmc_m6','nuc','Vialetto_avanti: 323000 - Capturing at 18.18 fps'
'2017-08-08 23:57:45.147369','zma_m1','nuc','Retro_casa: 449000 - Analysing at 25.00 fps'
'2017-08-08 23:57:49.862772','zma_m5','nuc','Portico_avanti: 311000 - Analysing at 18.18 fps'
'2017-08-08 23:57:50.588852','zma_m3','nuc','Portone: 449000 - Analysing at 25.00 fps'
'2017-08-08 23:58:00.046277','zma_m3','nuc','Portone: 449237 - Closing event 931495, section end'
'2017-08-08 23:58:00.049928','zma_m4','nuc','Retro: 269698 - Closing event 931492, section end'
'2017-08-08 23:58:00.050505','zma_m5','nuc','Portico_avanti: 311183 - Closing event 931494, section end'
'2017-08-08 23:58:00.071054','zma_m5','nuc','Portico_avanti: 311183 - Opening new event 931501, section start'
'2017-08-08 23:58:00.075053','zma_m6','nuc','Vialetto_avanti: 307867 - Closing event 931496, section end'
'2017-08-08 23:58:00.100298','zma_m6','nuc','Vialetto_avanti: 307867 - Opening new event 931502, section start'
'2017-08-08 23:58:00.122620','zma_m2','nuc','Orto: 179871 - Closing event 931497, section end'
'2017-08-08 23:58:00.153006','zma_m2','nuc','Orto: 179871 - Opening new event 931503, section start'
'2017-08-08 23:58:00.166089','zma_m1','nuc','Retro_casa: 449373 - Closing event 931493, section end'
'2017-08-08 23:58:00.194729','zma_m1','nuc','Retro_casa: 449373 - Opening new event 931504, section start'
'2017-08-08 23:58:00.204183','zma_m4','nuc','Retro: 269698 - Opening new event 931500, section start'
'2017-08-08 23:58:00.204329','zma_m3','nuc','Portone: 449237 - Opening new event 931499, section start'
'2017-08-08 23:58:00.607746','zma_m8','PI3','Taverna: 118232 - Closing event 931498, section end'
'2017-08-08 23:58:00.636974','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:58:00.638995','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:58:00.642418','zma_m8','PI3','Error stat\'ing events/8/17/08/08, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:58:00.646056','zma_m8','PI3','Error stat\'ing events/8/17/08/08/23, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:58:00.656396','zma_m8','PI3','Taverna: 118232 - Opening new event 931505, section start'
'2017-08-08 23:58:03.809995','zmc_m3','nuc','Portone: 450000 - Capturing at 25.00 fps'
'2017-08-08 23:58:04.182772','zmc_m1','nuc','Retro_casa: 450000 - Capturing at 25.00 fps'
'2017-08-08 23:58:07.418992','zma_m6','nuc','Vialetto_avanti: 308000 - Analysing at 17.86 fps'
'2017-08-08 23:58:08.434218','zmc_m4','nuc','Retro: 270000 - Capturing at 14.93 fps'
'2017-08-08 23:58:09.193239','zmc_m2','nuc','Orto: 180000 - Capturing at 10.00 fps'
'2017-08-08 23:58:12.986398','zma_m2','nuc','Orto: 180000 - Analysing at 10.10 fps'
'2017-08-08 23:58:20.143984','zma_m4','nuc','Retro: 270000 - Analysing at 14.93 fps'
'2017-08-08 23:58:25.084917','zma_m1','nuc','Retro_casa: 450000 - Analysing at 25.00 fps'
'2017-08-08 23:58:30.536800','zma_m3','nuc','Portone: 450000 - Analysing at 25.00 fps'
'2017-08-08 23:58:34.345713','zmc_m5','nuc','Portico_avanti: 324000 - Capturing at 17.86 fps'
'2017-08-08 23:58:34.395748','zmc_m6','nuc','Vialetto_avanti: 324000 - Capturing at 17.86 fps'
'2017-08-08 23:58:34.468888','zmc_m8','PI3','Taverna: 269000 - Capturing at 14.93 fps'
'2017-08-08 23:58:43.749677','zmc_m3','nuc','Portone: 451000 - Capturing at 25.00 fps'
'2017-08-08 23:58:44.118548','zmc_m1','nuc','Retro_casa: 451000 - Capturing at 25.00 fps'
'2017-08-08 23:58:45.431194','zma_m5','nuc','Portico_avanti: 312000 - Analysing at 17.86 fps'
'2017-08-08 23:58:49.707800','zmaudit',NULL,'Filesystem monitor \'7\' does not exist in database'
'2017-08-08 23:58:49.718830','zmaudit',NULL,'deleting'
'2017-08-08 23:58:53.400154','zma_m1','nuc','Retro_casa: 450709 - Gone into prealarm state'
'2017-08-08 23:58:54.591280','zmfilter',NULL,'Deleting event 921426 from Monitor 5'
'2017-08-08 23:58:54.630610','zmfilter',NULL,'Deleting event 921427 from Monitor 1'
'2017-08-08 23:58:54.648320','zmfilter',NULL,'Deleting event 921428 from Monitor 3'
'2017-08-08 23:58:54.665060','zmfilter',NULL,'Deleting event 921429 from Monitor 4'
'2017-08-08 23:58:56.115780','zmfilter',NULL,'Deleting event 921430 from Monitor 6'
'2017-08-08 23:58:56.137530','zmfilter',NULL,'Deleting event 921431 from Monitor 2'
'2017-08-08 23:58:56.715740','zmfilter',NULL,'Deleting event 921432 from Monitor 8'
'2017-08-08 23:59:00.018808','zma_m5','nuc','Portico_avanti: 312262 - Closing event 931501, section end'
'2017-08-08 23:59:00.032073','zma_m6','nuc','Vialetto_avanti: 308947 - Closing event 931502, section end'
'2017-08-08 23:59:00.033314','zma_m1','nuc','Retro_casa: 450875 - Closing event 931504, section end'
'2017-08-08 23:59:00.042414','zma_m3','nuc','Portone: 450739 - Closing event 931499, section end'
'2017-08-08 23:59:00.053092','zma_m1','nuc','Retro_casa: 450875 - Opening new event 931508, section start'
'2017-08-08 23:59:00.060086','zma_m3','nuc','Portone: 450739 - Opening new event 931509, section start'
'2017-08-08 23:59:00.061252','zma_m4','nuc','Retro: 270600 - Closing event 931500, section end'
'2017-08-08 23:59:00.090495','zma_m4','nuc','Retro: 270600 - Opening new event 931510, section start'
'2017-08-08 23:59:00.127652','zma_m2','nuc','Orto: 180472 - Closing event 931503, section end'
'2017-08-08 23:59:00.140711','zma_m2','nuc','Orto: 180472 - Opening new event 931511, section start'
'2017-08-08 23:59:00.146239','zma_m6','nuc','Vialetto_avanti: 308947 - Opening new event 931507, section start'
'2017-08-08 23:59:00.146257','zma_m5','nuc','Portico_avanti: 312262 - Opening new event 931506, section start'
'2017-08-08 23:59:00.650283','zma_m8','PI3','Taverna: 118798 - Closing event 931505, section end'
'2017-08-08 23:59:00.667176','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:59:00.670583','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:59:00.674848','zma_m8','PI3','Error stat\'ing events/8/17/08/08, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:59:00.680659','zma_m8','PI3','Error stat\'ing events/8/17/08/08/23, may be fatal. error is Value too large for defined data type'
'2017-08-08 23:59:00.696636','zma_m8','PI3','Taverna: 118798 - Opening new event 931512, section start'
'2017-08-08 23:59:02.962093','zma_m6','nuc','Vialetto_avanti: 309000 - Analysing at 18.18 fps'
'2017-08-08 23:59:05.044277','zma_m1','nuc','Retro_casa: 451000 - Analysing at 25.00 fps'
'2017-08-08 23:59:10.451448','zma_m3','nuc','Portone: 451000 - Analysing at 25.00 fps'
'2017-08-08 23:59:14.993646','zmc_m4','nuc','Retro: 271000 - Capturing at 15.15 fps'
'2017-08-08 23:59:22.403771','zma_m8','PI3','Taverna: 119000 - Analysing at 9.43 fps'
'2017-08-08 23:59:23.691465','zmc_m3','nuc','Portone: 452000 - Capturing at 25.00 fps'
'2017-08-08 23:59:24.032196','zmc_m1','nuc','Retro_casa: 452000 - Capturing at 25.00 fps'
'2017-08-08 23:59:26.694472','zma_m4','nuc','Retro: 271000 - Analysing at 15.15 fps'
'2017-08-08 23:59:29.912435','zmc_m5','nuc','Portico_avanti: 325000 - Capturing at 18.18 fps'
'2017-08-08 23:59:29.965837','zmc_m6','nuc','Vialetto_avanti: 325000 - Capturing at 18.18 fps'
'2017-08-08 23:59:36.452175','zma_m1','nuc','Retro_casa: 451787 - Gone into prealarm state'
'2017-08-08 23:59:40.990631','zma_m5','nuc','Portico_avanti: 313000 - Analysing at 18.18 fps'
'2017-08-08 23:59:41.041531','zmc_m8','PI3','Taverna: 270000 - Capturing at 14.93 fps'
'2017-08-08 23:59:44.959716','zma_m1','nuc','Retro_casa: 452000 - Analysing at 25.64 fps'
'2017-08-08 23:59:49.001808','zmc_m2','nuc','Orto: 181000 - Capturing at 10.00 fps'
'2017-08-08 23:59:50.392312','zma_m3','nuc','Portone: 452000 - Analysing at 25.00 fps'
'2017-08-08 23:59:52.820437','zma_m2','nuc','Orto: 181000 - Analysing at 10.00 fps'
'2017-08-08 23:59:58.526177','zma_m6','nuc','Vialetto_avanti: 310000 - Analysing at 17.86 fps'
'2017-08-09 00:00:00.021931','zma_m2','nuc','Orto: 181072 - Closing event 931511, section end'
'2017-08-09 00:00:00.031136','zma_m4','nuc','Retro: 271501 - Closing event 931510, section end'
'2017-08-09 00:00:00.039638','zma_m5','nuc','Portico_avanti: 313342 - Closing event 931506, section end'
'2017-08-09 00:00:00.042003','zma_m3','nuc','Portone: 452242 - Closing event 931509, section end'
'2017-08-09 00:00:00.043164','zma_m1','nuc','Retro_casa: 452378 - Closing event 931508, section end'
'2017-08-09 00:00:00.061072','zma_m4','nuc','Retro: 271501 - Opening new event 931514, section start'
'2017-08-09 00:00:00.066817','zma_m2','nuc','Orto: 181072 - Opening new event 931513, section start'
'2017-08-09 00:00:00.068088','zma_m1','nuc','Retro_casa: 452378 - Opening new event 931516, section start'
'2017-08-09 00:00:00.068593','zma_m3','nuc','Portone: 452242 - Opening new event 931517, section start'
'2017-08-09 00:00:00.073429','zma_m6','nuc','Vialetto_avanti: 310027 - Closing event 931507, section end'
'2017-08-09 00:00:00.194302','zma_m6','nuc','Vialetto_avanti: 310027 - Opening new event 931518, section start'
'2017-08-09 00:00:00.194336','zma_m5','nuc','Portico_avanti: 313342 - Opening new event 931515, section start'
'2017-08-09 00:00:00.627425','zma_m8','PI3','Taverna: 119363 - Closing event 931512, section end'
'2017-08-09 00:00:00.655755','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:00:00.661319','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:00:00.679270','zma_m8','PI3','Taverna: 119363 - Opening new event 931519, section start'
'2017-08-09 00:00:03.622498','zmc_m3','nuc','Portone: 453000 - Capturing at 25.00 fps'
'2017-08-09 00:00:04.004502','zmc_m1','nuc','Retro_casa: 453000 - Capturing at 25.00 fps'
'2017-08-09 00:00:21.545421','zmc_m4','nuc','Retro: 272000 - Capturing at 14.93 fps'
'2017-08-09 00:00:24.888912','zma_m1','nuc','Retro_casa: 453000 - Analysing at 25.00 fps'
'2017-08-09 00:00:25.470903','zmc_m5','nuc','Portico_avanti: 326000 - Capturing at 17.86 fps'
'2017-08-09 00:00:25.518552','zmc_m6','nuc','Vialetto_avanti: 326000 - Capturing at 17.86 fps'
'2017-08-09 00:00:30.312859','zma_m3','nuc','Portone: 453000 - Analysing at 25.00 fps'
'2017-08-09 00:00:33.236088','zma_m4','nuc','Retro: 272000 - Analysing at 14.93 fps'
'2017-08-09 00:00:36.600853','zma_m5','nuc','Portico_avanti: 314000 - Analysing at 17.86 fps'
'2017-08-09 00:00:43.546570','zmc_m3','nuc','Portone: 454000 - Capturing at 25.00 fps'
'2017-08-09 00:00:43.908068','zmc_m1','nuc','Retro_casa: 454000 - Capturing at 25.64 fps'
'2017-08-09 00:00:47.582718','zmc_m8','PI3','Taverna: 271000 - Capturing at 15.15 fps'
'2017-08-09 00:00:54.104123','zma_m6','nuc','Vialetto_avanti: 311000 - Analysing at 17.86 fps'
'2017-08-09 00:01:00.024504','zma_m1','nuc','Retro_casa: 453880 - Closing event 931516, section end'
'2017-08-09 00:01:00.027734','zma_m2','nuc','Orto: 181673 - Closing event 931513, section end'
'2017-08-09 00:01:00.045663','zma_m6','nuc','Vialetto_avanti: 311107 - Closing event 931518, section end'
'2017-08-09 00:01:00.052199','zma_m3','nuc','Portone: 453744 - Closing event 931517, section end'
'2017-08-09 00:01:00.056226','zma_m1','nuc','Retro_casa: 453880 - Opening new event 931520, section start'
'2017-08-09 00:01:00.061108','zma_m2','nuc','Orto: 181673 - Opening new event 931521, section start'
'2017-08-09 00:01:00.063466','zma_m5','nuc','Portico_avanti: 314423 - Closing event 931515, section end'
'2017-08-09 00:01:00.073543','zma_m6','nuc','Vialetto_avanti: 311107 - Opening new event 931522, section start'
'2017-08-09 00:01:00.074122','zma_m4','nuc','Retro: 272403 - Closing event 931514, section end'
'2017-08-09 00:01:00.075973','zma_m3','nuc','Portone: 453744 - Opening new event 931523, section start'
'2017-08-09 00:01:00.081925','zma_m5','nuc','Portico_avanti: 314423 - Opening new event 931524, section start'
'2017-08-09 00:01:00.093967','zma_m4','nuc','Retro: 272403 - Opening new event 931525, section start'
'2017-08-09 00:01:00.646041','zma_m8','PI3','Taverna: 119933 - Closing event 931519, section end'
'2017-08-09 00:01:00.669719','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:01:00.674990','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:01:00.681680','zma_m8','PI3','Error stat\'ing events/8/17/08/09, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:01:00.683904','zma_m8','PI3','Error stat\'ing events/8/17/08/09/00, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:01:00.693682','zma_m8','PI3','Taverna: 119933 - Opening new event 931526, section start'
'2017-08-09 00:01:04.824484','zma_m1','nuc','Retro_casa: 454000 - Analysing at 25.00 fps'
'2017-08-09 00:01:07.784750','zma_m8','PI3','Taverna: 120000 - Analysing at 9.52 fps'
'2017-08-09 00:01:10.241249','zma_m3','nuc','Portone: 454000 - Analysing at 25.00 fps'
'2017-08-09 00:01:21.033455','zmc_m5','nuc','Portico_avanti: 327000 - Capturing at 17.86 fps'
'2017-08-09 00:01:21.074388','zmc_m6','nuc','Vialetto_avanti: 327000 - Capturing at 17.86 fps'
'2017-08-09 00:01:23.486587','zmc_m3','nuc','Portone: 455000 - Capturing at 25.00 fps'
'2017-08-09 00:01:23.837698','zmc_m1','nuc','Retro_casa: 455000 - Capturing at 25.00 fps'
'2017-08-09 00:01:28.084959','zmc_m4','nuc','Retro: 273000 - Capturing at 14.93 fps'
'2017-08-09 00:01:28.830972','zmc_m2','nuc','Orto: 182000 - Capturing at 10.10 fps'
'2017-08-09 00:01:32.113860','zma_m5','nuc','Portico_avanti: 315000 - Analysing at 17.86 fps'
'2017-08-09 00:01:32.631398','zma_m2','nuc','Orto: 182000 - Analysing at 10.00 fps'
'2017-08-09 00:01:32.794251','zma_m5','nuc','Portico_avanti: 315012 - Gone into prealarm state'
'2017-08-09 00:01:32.931523','zma_m5','nuc','Portico_avanti: 315015 - Gone into prealarm state'
'2017-08-09 00:01:39.821539','zma_m4','nuc','Retro: 273000 - Analysing at 15.15 fps'
'2017-08-09 00:01:44.729874','zma_m3','nuc','Portone: 454863 - Gone into prealarm state'
'2017-08-09 00:01:44.768240','zma_m1','nuc','Retro_casa: 455000 - Analysing at 25.00 fps'
'2017-08-09 00:01:49.661079','zma_m6','nuc','Vialetto_avanti: 312000 - Analysing at 18.18 fps'
'2017-08-09 00:01:50.181080','zma_m3','nuc','Portone: 455000 - Analysing at 25.00 fps'
'2017-08-09 00:01:54.152398','zmc_m8','PI3','Taverna: 272000 - Capturing at 14.93 fps'
'2017-08-09 00:02:00.037202','zma_m5','nuc','Portico_avanti: 315502 - Closing event 931524, section end'
'2017-08-09 00:02:00.040450','zma_m3','nuc','Portone: 455247 - Closing event 931523, section end'
'2017-08-09 00:02:00.069911','zma_m5','nuc','Portico_avanti: 315502 - Opening new event 931527, section start'
'2017-08-09 00:02:00.071191','zma_m4','nuc','Retro: 273304 - Closing event 931525, section end'
'2017-08-09 00:02:00.072693','zma_m3','nuc','Portone: 455247 - Opening new event 931528, section start'
'2017-08-09 00:02:00.077362','zma_m1','nuc','Retro_casa: 455383 - Closing event 931520, section end'
'2017-08-09 00:02:00.087106','zma_m6','nuc','Vialetto_avanti: 312187 - Closing event 931522, section end'
'2017-08-09 00:02:00.088525','zma_m4','nuc','Retro: 273304 - Opening new event 931529, section start'
'2017-08-09 00:02:00.095327','zma_m1','nuc','Retro_casa: 455383 - Opening new event 931530, section start'
'2017-08-09 00:02:00.110971','zma_m2','nuc','Orto: 182275 - Closing event 931521, section end'
'2017-08-09 00:02:00.118851','zma_m6','nuc','Vialetto_avanti: 312187 - Opening new event 931531, section start'
'2017-08-09 00:02:00.140810','zma_m2','nuc','Orto: 182275 - Opening new event 931532, section start'
'2017-08-09 00:02:00.641196','zma_m8','PI3','Taverna: 120492 - Closing event 931526, section end'
'2017-08-09 00:02:00.658032','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:02:00.664185','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:02:00.672220','zma_m8','PI3','Error stat\'ing events/8/17/08/09, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:02:00.681383','zma_m8','PI3','Error stat\'ing events/8/17/08/09/00, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:02:00.697201','zma_m8','PI3','Taverna: 120492 - Opening new event 931533, section start'
'2017-08-09 00:02:03.418804','zmc_m3','nuc','Portone: 456000 - Capturing at 25.00 fps'
'2017-08-09 00:02:03.778356','zmc_m1','nuc','Retro_casa: 456000 - Capturing at 25.00 fps'
'2017-08-09 00:02:08.471562','zma_m3','nuc','Portone: 455458 - Gone into prealarm state'
'2017-08-09 00:02:12.066042','zma_m1','nuc','Retro_casa: 455684 - Gone into prealarm state'
'2017-08-09 00:02:16.624445','zmc_m5','nuc','Portico_avanti: 328000 - Capturing at 18.18 fps'
'2017-08-09 00:02:16.688087','zmc_m6','nuc','Vialetto_avanti: 328000 - Capturing at 18.18 fps'
'2017-08-09 00:02:19.385152','zma_m1','nuc','Retro_casa: 455867 - Gone into prealarm state'
'2017-08-09 00:02:23.083740','zmfilter',NULL,'Deleting event 921433 from Monitor 5'
'2017-08-09 00:02:23.103430','zmfilter',NULL,'Deleting event 921434 from Monitor 1'
'2017-08-09 00:02:23.115210','zmfilter',NULL,'Deleting event 921435 from Monitor 3'
'2017-08-09 00:02:23.126140','zmfilter',NULL,'Deleting event 921436 from Monitor 4'
'2017-08-09 00:02:23.860130','zmfilter',NULL,'Deleting event 921437 from Monitor 6'
'2017-08-09 00:02:23.871280','zmfilter',NULL,'Deleting event 921438 from Monitor 8'
'2017-08-09 00:02:24.016130','zmfilter',NULL,'Deleting event 921439 from Monitor 2'
'2017-08-09 00:02:24.181360','zmfilter',NULL,'Deleting event 921440 from Monitor 5'
'2017-08-09 00:02:24.677377','zma_m1','nuc','Retro_casa: 456000 - Analysing at 25.00 fps'
'2017-08-09 00:02:25.620310','zmfilter',NULL,'Deleting event 921441 from Monitor 3'
'2017-08-09 00:02:27.858898','zma_m5','nuc','Portico_avanti: 316000 - Analysing at 18.18 fps'
'2017-08-09 00:02:28.414140','zmfilter',NULL,'Deleting event 921442 from Monitor 1'
'2017-08-09 00:02:28.569320','zmaudit',NULL,'Filesystem monitor \'7\' does not exist in database'
'2017-08-09 00:02:28.584050','zmaudit',NULL,'deleting'
'2017-08-09 00:02:29.595250','zmfilter',NULL,'Deleting event 921443 from Monitor 6'
'2017-08-09 00:02:29.761810','zmfilter',NULL,'Deleting event 921444 from Monitor 4'
'2017-08-09 00:02:30.113518','zma_m3','nuc','Portone: 456000 - Analysing at 25.00 fps'
'2017-08-09 00:02:30.678400','zmfilter',NULL,'Deleting event 921445 from Monitor 2'
'2017-08-09 00:02:30.751310','zmfilter',NULL,'Deleting event 921446 from Monitor 8'
'2017-08-09 00:02:30.899700','zmfilter',NULL,'Deleting event 921447 from Monitor 3'
'2017-08-09 00:02:31.203970','zmfilter',NULL,'Deleting event 921448 from Monitor 4'
'2017-08-09 00:02:31.273390','zmfilter',NULL,'Deleting event 921449 from Monitor 1'
'2017-08-09 00:02:31.405620','zmfilter',NULL,'Deleting event 921450 from Monitor 6'
'2017-08-09 00:02:31.602880','zmfilter',NULL,'Deleting event 921451 from Monitor 5'
'2017-08-09 00:02:31.718780','zmfilter',NULL,'Deleting event 921452 from Monitor 2'
'2017-08-09 00:02:31.786000','zmfilter',NULL,'Deleting event 921453 from Monitor 8'
'2017-08-09 00:02:31.841440','zmfilter',NULL,'Deleting event 921454 from Monitor 3'
'2017-08-09 00:02:31.930440','zmfilter',NULL,'Deleting event 921455 from Monitor 5'
'2017-08-09 00:02:32.109490','zmfilter',NULL,'Deleting event 921456 from Monitor 1'
'2017-08-09 00:02:32.293180','zmfilter',NULL,'Deleting event 921457 from Monitor 4'
'2017-08-09 00:02:32.356950','zmfilter',NULL,'Deleting event 921458 from Monitor 6'
'2017-08-09 00:02:32.460530','zmfilter',NULL,'Deleting event 921459 from Monitor 2'
'2017-08-09 00:02:32.536200','zmfilter',NULL,'Deleting event 921460 from Monitor 8'
'2017-08-09 00:02:34.647390','zmc_m4','nuc','Retro: 274000 - Capturing at 15.15 fps'
'2017-08-09 00:02:43.348421','zmc_m3','nuc','Portone: 457000 - Capturing at 25.00 fps'
'2017-08-09 00:02:43.700905','zmc_m1','nuc','Retro_casa: 457000 - Capturing at 25.00 fps'
'2017-08-09 00:02:45.377086','zma_m6','nuc','Vialetto_avanti: 313000 - Analysing at 17.86 fps'
'2017-08-09 00:02:46.346635','zma_m4','nuc','Retro: 274000 - Analysing at 14.93 fps'
'2017-08-09 00:02:56.211049','zma_m8','PI3','Taverna: 121000 - Analysing at 9.17 fps'
'2017-08-09 00:03:00.008910','zma_m4','nuc','Retro: 274205 - Closing event 931529, section end'
'2017-08-09 00:03:00.010990','zma_m5','nuc','Portico_avanti: 316579 - Closing event 931527, section end'
'2017-08-09 00:03:00.014174','zma_m1','nuc','Retro_casa: 456885 - Closing event 931530, section end'
'2017-08-09 00:03:00.030621','zma_m3','nuc','Portone: 456749 - Closing event 931528, section end'
'2017-08-09 00:03:00.032910','zma_m6','nuc','Vialetto_avanti: 313264 - Closing event 931531, section end'
'2017-08-09 00:03:00.037484','zma_m1','nuc','Retro_casa: 456885 - Opening new event 931534, section start'
'2017-08-09 00:03:00.040310','zma_m4','nuc','Retro: 274205 - Opening new event 931536, section start'
'2017-08-09 00:03:00.053491','zma_m3','nuc','Portone: 456749 - Opening new event 931538, section start'
'2017-08-09 00:03:00.096281','zma_m5','nuc','Portico_avanti: 316579 - Opening new event 931535, section start'
'2017-08-09 00:03:00.096281','zma_m6','nuc','Vialetto_avanti: 313264 - Opening new event 931537, section start'
'2017-08-09 00:03:00.119815','zma_m2','nuc','Orto: 182876 - Closing event 931532, section end'
'2017-08-09 00:03:00.133984','zma_m2','nuc','Orto: 182876 - Opening new event 931539, section start'
'2017-08-09 00:03:00.606135','zma_m8','PI3','Taverna: 121042 - Closing event 931533, section end'
'2017-08-09 00:03:00.634793','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:03:00.641605','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:03:00.657223','zma_m8','PI3','Error stat\'ing events/8/17/08/09, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:03:00.663255','zma_m8','PI3','Error stat\'ing events/8/17/08/09/00, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:03:00.681834','zma_m8','PI3','Taverna: 121042 - Opening new event 931540, section start'
'2017-08-09 00:03:00.687711','zmc_m8','PI3','Taverna: 273000 - Capturing at 15.15 fps'
'2017-08-09 00:03:04.620349','zma_m1','nuc','Retro_casa: 457000 - Analysing at 25.00 fps'
'2017-08-09 00:03:05.842144','zma_m1','nuc','Retro_casa: 457030 - Gone into prealarm state'
'2017-08-09 00:03:08.679493','zmc_m2','nuc','Orto: 183000 - Capturing at 10.00 fps'
'2017-08-09 00:03:10.035378','zma_m3','nuc','Portone: 457000 - Analysing at 25.00 fps'
'2017-08-09 00:03:12.149417','zmc_m5','nuc','Portico_avanti: 329000 - Capturing at 17.86 fps'
'2017-08-09 00:03:12.220430','zmc_m6','nuc','Vialetto_avanti: 329000 - Capturing at 17.86 fps'
'2017-08-09 00:03:12.488146','zma_m2','nuc','Orto: 183000 - Analysing at 10.00 fps'
'2017-08-09 00:03:23.284758','zmc_m3','nuc','Portone: 458000 - Capturing at 25.00 fps'
'2017-08-09 00:03:23.402603','zma_m5','nuc','Portico_avanti: 317000 - Analysing at 17.86 fps'
'2017-08-09 00:03:23.637546','zmc_m1','nuc','Retro_casa: 458000 - Capturing at 25.00 fps'
'2017-08-09 00:03:40.952502','zma_m6','nuc','Vialetto_avanti: 314000 - Analysing at 18.18 fps'
'2017-08-09 00:03:41.199545','zmc_m4','nuc','Retro: 275000 - Capturing at 14.93 fps'
'2017-08-09 00:03:44.547859','zma_m1','nuc','Retro_casa: 458000 - Analysing at 25.00 fps'
'2017-08-09 00:03:49.962078','zma_m3','nuc','Portone: 458000 - Analysing at 25.64 fps'
'2017-08-09 00:03:52.909923','zma_m4','nuc','Retro: 275000 - Analysing at 15.15 fps'
'2017-08-09 00:03:53.511944','zma_m3','nuc','Portone: 458088 - Gone into prealarm state'
'2017-08-09 00:03:57.207210','zmfilter',NULL,'Deleting event 921461 from Monitor 1'
'2017-08-09 00:03:58.497250','zma_m1','nuc','Retro_casa: 458349 - Gone into prealarm state'
'2017-08-09 00:03:58.552760','zmfilter',NULL,'Deleting event 921462 from Monitor 4'
'2017-08-09 00:04:00.028527','zma_m4','nuc','Retro: 275107 - Closing event 931536, section end'
'2017-08-09 00:04:00.045509','zma_m4','nuc','Retro: 275107 - Opening new event 931541, section start'
'2017-08-09 00:04:00.052636','zma_m3','nuc','Portone: 458252 - Closing event 931538, section end'
'2017-08-09 00:04:00.063646','zma_m5','nuc','Portico_avanti: 317660 - Closing event 931535, section end'
'2017-08-09 00:04:00.068038','zma_m6','nuc','Vialetto_avanti: 314343 - Closing event 931537, section end'
'2017-08-09 00:04:00.079983','zma_m3','nuc','Portone: 458252 - Opening new event 931542, section start'
'2017-08-09 00:04:00.093288','zma_m5','nuc','Portico_avanti: 317660 - Opening new event 931543, section start'
'2017-08-09 00:04:00.096043','zma_m6','nuc','Vialetto_avanti: 314343 - Opening new event 931544, section start'
'2017-08-09 00:04:00.099335','zma_m2','nuc','Orto: 183477 - Closing event 931539, section end'
'2017-08-09 00:04:00.100418','zma_m1','nuc','Retro_casa: 458388 - Closing event 931534, section end'
'2017-08-09 00:04:00.129727','zma_m2','nuc','Orto: 183477 - Opening new event 931545, section start'
'2017-08-09 00:04:00.134410','zma_m1','nuc','Retro_casa: 458388 - Opening new event 931546, section start'
'2017-08-09 00:04:00.320940','zmfilter',NULL,'Deleting event 921463 from Monitor 3'
'2017-08-09 00:04:01.324289','zma_m8','PI3','Taverna: 121607 - Closing event 931540, section end'
'2017-08-09 00:04:01.350540','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:04:01.355735','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:04:01.359940','zma_m8','PI3','Error stat\'ing events/8/17/08/09, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:04:01.364143','zma_m8','PI3','Error stat\'ing events/8/17/08/09/00, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:04:01.379747','zma_m8','PI3','Taverna: 121607 - Opening new event 931547, section start'
'2017-08-09 00:04:01.488570','zmfilter',NULL,'Deleting event 921464 from Monitor 5'
'2017-08-09 00:04:02.811370','zmfilter',NULL,'Deleting event 921465 from Monitor 6'
'2017-08-09 00:04:03.212713','zmc_m3','nuc','Portone: 459000 - Capturing at 25.00 fps'
'2017-08-09 00:04:03.635007','zmc_m1','nuc','Retro_casa: 459000 - Capturing at 25.00 fps'
'2017-08-09 00:04:03.941880','zmfilter',NULL,'Deleting event 921466 from Monitor 8'
'2017-08-09 00:04:04.532460','zmfilter',NULL,'Deleting event 921467 from Monitor 2'
'2017-08-09 00:04:07.260300','zmc_m8','PI3','Taverna: 274000 - Capturing at 14.93 fps'
'2017-08-09 00:04:07.705007','zmc_m5','nuc','Portico_avanti: 330000 - Capturing at 18.18 fps'
'2017-08-09 00:04:07.741517','zmc_m6','nuc','Vialetto_avanti: 330000 - Capturing at 18.18 fps'
'2017-08-09 00:04:18.944005','zma_m5','nuc','Portico_avanti: 318000 - Analysing at 18.18 fps'
'2017-08-09 00:04:24.470778','zma_m1','nuc','Retro_casa: 459000 - Analysing at 25.00 fps'
'2017-08-09 00:04:29.899121','zma_m3','nuc','Portone: 459000 - Analysing at 25.00 fps'
'2017-08-09 00:04:35.336379','zma_m6','nuc','Vialetto_avanti: 314979 - Gone into prealarm state'
'2017-08-09 00:04:36.466938','zma_m6','nuc','Vialetto_avanti: 315000 - Analysing at 17.86 fps'
'2017-08-09 00:04:43.131436','zmc_m3','nuc','Portone: 460000 - Capturing at 25.00 fps'
'2017-08-09 00:04:43.489330','zmc_m1','nuc','Retro_casa: 460000 - Capturing at 25.00 fps'
'2017-08-09 00:04:43.625038','zma_m8','PI3','Taverna: 122000 - Analysing at 9.35 fps'
'2017-08-09 00:04:47.769818','zmc_m4','nuc','Retro: 276000 - Capturing at 15.15 fps'
'2017-08-09 00:04:48.499030','zmc_m2','nuc','Orto: 184000 - Capturing at 10.00 fps'
'2017-08-09 00:04:52.299526','zma_m2','nuc','Orto: 184000 - Analysing at 10.00 fps'
'2017-08-09 00:04:59.465325','zma_m4','nuc','Retro: 276000 - Analysing at 14.93 fps'
'2017-08-09 00:05:00.012923','zma_m5','nuc','Portico_avanti: 318739 - Closing event 931543, section end'
'2017-08-09 00:05:00.033302','zma_m5','nuc','Portico_avanti: 318739 - Opening new event 931548, section start'
'2017-08-09 00:05:00.038893','zma_m3','nuc','Portone: 459754 - Closing event 931542, section end'
'2017-08-09 00:05:00.041432','zma_m1','nuc','Retro_casa: 459891 - Closing event 931546, section end'
'2017-08-09 00:05:00.057210','zma_m3','nuc','Portone: 459754 - Opening new event 931549, section start'
'2017-08-09 00:05:00.060106','zma_m6','nuc','Vialetto_avanti: 315424 - Closing event 931544, section end'
'2017-08-09 00:05:00.060373','zma_m1','nuc','Retro_casa: 459891 - Opening new event 931550, section start'
'2017-08-09 00:05:00.061629','zma_m4','nuc','Retro: 276009 - Closing event 931541, section end'
'2017-08-09 00:05:00.094350','zma_m6','nuc','Vialetto_avanti: 315424 - Opening new event 931551, section start'
'2017-08-09 00:05:00.098927','zma_m4','nuc','Retro: 276009 - Opening new event 931552, section start'
'2017-08-09 00:05:00.113335','zma_m2','nuc','Orto: 184078 - Closing event 931545, section end'
'2017-08-09 00:05:00.129621','zma_m2','nuc','Orto: 184078 - Opening new event 931553, section start'
'2017-08-09 00:05:00.591694','zma_m8','PI3','Taverna: 122162 - Closing event 931547, section end'
'2017-08-09 00:05:00.617064','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:05:00.622841','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:05:00.626505','zma_m8','PI3','Error stat\'ing events/8/17/08/09, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:05:00.628744','zma_m8','PI3','Error stat\'ing events/8/17/08/09/00, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:05:00.638286','zma_m8','PI3','Taverna: 122162 - Opening new event 931554, section start'
'2017-08-09 00:05:03.263959','zmc_m5','nuc','Portico_avanti: 331000 - Capturing at 17.86 fps'
'2017-08-09 00:05:03.319841','zmc_m6','nuc','Vialetto_avanti: 331000 - Capturing at 17.86 fps'
'2017-08-09 00:05:04.405852','zma_m1','nuc','Retro_casa: 460000 - Analysing at 25.00 fps'
'2017-08-09 00:05:09.848716','zma_m3','nuc','Portone: 460000 - Analysing at 25.00 fps'
'2017-08-09 00:05:13.797464','zmc_m8','PI3','Taverna: 275000 - Capturing at 15.15 fps'
'2017-08-09 00:05:14.502148','zma_m5','nuc','Portico_avanti: 319000 - Analysing at 17.86 fps'
'2017-08-09 00:05:18.329098','zma_m1','nuc','Retro_casa: 460348 - Gone into prealarm state'
'2017-08-09 00:05:23.086622','zmc_m3','nuc','Portone: 461000 - Capturing at 25.00 fps'
'2017-08-09 00:05:23.421273','zmc_m1','nuc','Retro_casa: 461000 - Capturing at 25.00 fps'
'2017-08-09 00:05:32.060802','zma_m6','nuc','Vialetto_avanti: 316000 - Analysing at 17.86 fps'
'2017-08-09 00:05:44.331701','zma_m1','nuc','Retro_casa: 461000 - Analysing at 25.00 fps'
'2017-08-09 00:05:49.773693','zma_m3','nuc','Portone: 461000 - Analysing at 25.00 fps'
'2017-08-09 00:05:54.307983','zmc_m4','nuc','Retro: 277000 - Capturing at 14.93 fps'
'2017-08-09 00:05:58.818573','zmc_m5','nuc','Portico_avanti: 332000 - Capturing at 18.18 fps'
'2017-08-09 00:05:58.871882','zmc_m6','nuc','Vialetto_avanti: 332000 - Capturing at 18.18 fps'
'2017-08-09 00:06:00.018902','zma_m6','nuc','Vialetto_avanti: 316504 - Closing event 931551, section end'
'2017-08-09 00:06:00.030395','zma_m4','nuc','Retro: 276910 - Closing event 931552, section end'
'2017-08-09 00:06:00.033258','zma_m3','nuc','Portone: 461257 - Closing event 931549, section end'
'2017-08-09 00:06:00.059583','zma_m1','nuc','Retro_casa: 461393 - Closing event 931550, section end'
'2017-08-09 00:06:00.063321','zma_m5','nuc','Portico_avanti: 319820 - Closing event 931548, section end'
'2017-08-09 00:06:00.075879','zma_m6','nuc','Vialetto_avanti: 316504 - Opening new event 931555, section start'
'2017-08-09 00:06:00.079156','zma_m1','nuc','Retro_casa: 461393 - Opening new event 931558, section start'
'2017-08-09 00:06:00.087008','zma_m2','nuc','Orto: 184679 - Closing event 931553, section end'
'2017-08-09 00:06:00.097461','zma_m5','nuc','Portico_avanti: 319820 - Opening new event 931559, section start'
'2017-08-09 00:06:00.112772','zma_m2','nuc','Orto: 184679 - Opening new event 931560, section start'
'2017-08-09 00:06:00.200768','zma_m3','nuc','Portone: 461257 - Opening new event 931557, section start'
'2017-08-09 00:06:00.201161','zma_m4','nuc','Retro: 276910 - Opening new event 931556, section start'
'2017-08-09 00:06:00.651209','zma_m8','PI3','Taverna: 122734 - Closing event 931554, section end'
'2017-08-09 00:06:00.676932','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:06:00.685993','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:06:00.689369','zma_m8','PI3','Error stat\'ing events/8/17/08/09, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:06:00.692817','zma_m8','PI3','Error stat\'ing events/8/17/08/09/00, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:06:00.705868','zma_m8','PI3','Taverna: 122734 - Opening new event 931561, section start'
'2017-08-09 00:06:03.007515','zmc_m3','nuc','Portone: 462000 - Capturing at 25.00 fps'
'2017-08-09 00:06:03.385179','zmc_m1','nuc','Retro_casa: 462000 - Capturing at 25.00 fps'
'2017-08-09 00:06:06.019119','zma_m4','nuc','Retro: 277000 - Analysing at 14.93 fps'
'2017-08-09 00:06:10.064895','zma_m5','nuc','Portico_avanti: 320000 - Analysing at 17.86 fps'
'2017-08-09 00:06:20.360001','zmc_m8','PI3','Taverna: 276000 - Capturing at 14.93 fps'
'2017-08-09 00:06:24.287254','zma_m1','nuc','Retro_casa: 462000 - Analysing at 25.00 fps'
'2017-08-09 00:06:27.636455','zma_m6','nuc','Vialetto_avanti: 317000 - Analysing at 18.18 fps'
'2017-08-09 00:06:28.325377','zmc_m2','nuc','Orto: 185000 - Capturing at 10.00 fps'
'2017-08-09 00:06:28.838941','zma_m8','PI3','Taverna: 123000 - Analysing at 9.52 fps'
'2017-08-09 00:06:29.722392','zma_m3','nuc','Portone: 462000 - Analysing at 25.00 fps'
'2017-08-09 00:06:32.111826','zma_m2','nuc','Orto: 185000 - Analysing at 10.00 fps'
'2017-08-09 00:06:42.942613','zmc_m3','nuc','Portone: 463000 - Capturing at 25.64 fps'
'2017-08-09 00:06:43.285584','zmc_m1','nuc','Retro_casa: 463000 - Capturing at 25.00 fps'
'2017-08-09 00:06:54.411692','zmc_m5','nuc','Portico_avanti: 333000 - Capturing at 17.86 fps'
'2017-08-09 00:06:54.431682','zmc_m6','nuc','Vialetto_avanti: 333000 - Capturing at 17.86 fps'
'2017-08-09 00:07:00.018570','zma_m3','nuc','Portone: 462758 - Closing event 931557, section end'
'2017-08-09 00:07:00.029402','zma_m3','nuc','Portone: 462758 - Opening new event 931562, section start'
'2017-08-09 00:07:00.036150','zma_m5','nuc','Portico_avanti: 320899 - Closing event 931559, section end'
'2017-08-09 00:07:00.054995','zma_m6','nuc','Vialetto_avanti: 317584 - Closing event 931555, section end'
'2017-08-09 00:07:00.056439','zma_m5','nuc','Portico_avanti: 320899 - Opening new event 931563, section start'
'2017-08-09 00:07:00.059236','zma_m1','nuc','Retro_casa: 462896 - Closing event 931558, section end'
'2017-08-09 00:07:00.073363','zma_m4','nuc','Retro: 277812 - Closing event 931556, section end'
'2017-08-09 00:07:00.087430','zma_m6','nuc','Vialetto_avanti: 317584 - Opening new event 931564, section start'
'2017-08-09 00:07:00.089373','zma_m2','nuc','Orto: 185280 - Closing event 931560, section end'
'2017-08-09 00:07:00.090383','zma_m1','nuc','Retro_casa: 462896 - Opening new event 931565, section start'
'2017-08-09 00:07:00.098044','zma_m4','nuc','Retro: 277812 - Opening new event 931566, section start'
'2017-08-09 00:07:00.105089','zma_m2','nuc','Orto: 185280 - Opening new event 931567, section start'
'2017-08-09 00:07:00.585897','zma_m8','PI3','Taverna: 123300 - Closing event 931561, section end'
'2017-08-09 00:07:00.604928','zma_m8','PI3','Error stat\'ing events/8/17, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:07:00.609311','zma_m8','PI3','Error stat\'ing events/8/17/08, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:07:00.614107','zma_m8','PI3','Error stat\'ing events/8/17/08/09, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:07:00.621484','zma_m8','PI3','Error stat\'ing events/8/17/08/09/00, may be fatal. error is Value too large for defined data type'
'2017-08-09 00:07:00.634259','zma_m8','PI3','Taverna: 123300 - Opening new event 931568, section start'
'2017-08-09 00:07:00.868225','zmc_m4','nuc','Retro: 278000 - Capturing at 15.15 fps'
'2017-08-09 00:07:03.431212','zma_m3','nuc','Portone: 462845 - Gone into prealarm state'
'2017-08-09 00:07:04.244809','zma_m1','nuc','Retro_casa: 463000 - Analysing at 25.00 fps'
'2017-08-09 00:07:05.626226','zma_m5','nuc','Portico_avanti: 321000 - Analysing at 18.18 fps'
'2017-08-09 00:07:06.507573','zma_m6','nuc','Vialetto_avanti: 317700 - Gone into prealarm state'
'2017-08-09 00:07:09.650535','zma_m3','nuc','Portone: 463000 - Analysing at 25.00 fps'
'2017-08-09 00:07:12.561920','zma_m4','nuc','Retro: 278000 - Analysing at 15.15 fps'
'2017-08-09 00:07:19.996620','web_php',NULL,'Login successful for user \"Marco\"'
'2017-08-09 00:07:20.257626','zma_m3','nuc','Portone: 463266 - Gone into prealarm state'
'2017-08-09 00:07:22.877715','zmc_m3','nuc','Portone: 464000 - Capturing at 25.00 fps'
'2017-08-09 00:07:23.178313','zma_m6','nuc','Vialetto_avanti: 318000 - Analysing at 17.86 fps'
'2017-08-09 00:07:23.218935','zmc_m1','nuc','Retro_casa: 464000 - Capturing at 25.00 fps'
'2017-08-09 00:07:25.154096','zma_m1','nuc','Retro_casa: 463525 - Gone into prealarm state'
'2017-08-09 00:07:26.900304','zmc_m8','PI3','Taverna: 277000 - Capturing at 15.15 fps'
'2017-08-09 00:07:28.662921','zma_m6','nuc','Vialetto_avanti: 318099 - Gone into prealarm state'
'2017-08-09 00:07:32.627730','zmfilter',NULL,'Deleting event 921468 from Monitor 5'
'2017-08-09 00:07:34.506550','zmfilter',NULL,'Deleting event 921469 from Monitor 1'
'2017-08-09 00:07:34.867060','zmfilter',NULL,'Deleting event 921470 from Monitor 4'
'2017-08-09 00:07:34.995420','zmfilter',NULL,'Deleting event 921471 from Monitor 6'
'2017-08-09 00:07:35.123620','zmfilter',NULL,'Deleting event 921472 from Monitor 8'
'2017-08-09 00:07:35.228370','zmfilter',NULL,'Deleting event 921473 from Monitor 2'
'2017-08-09 00:07:35.358480','zmfilter',NULL,'Deleting event 921474 from Monitor 3'
'2017-08-09 00:07:35.467780','zmfilter',NULL,'Deleting event 921475 from Monitor 1'
'2017-08-09 00:07:35.578650','zmfilter',NULL,'Deleting event 921476 from Monitor 4'
'2017-08-09 00:07:35.639540','zmfilter',NULL,'Deleting event 921477 from Monitor 3'
'2017-08-09 00:07:35.730190','zmfilter',NULL,'Deleting event 921478 from Monitor 5'
'2017-08-09 00:07:35.890860','zmfilter',NULL,'Deleting event 921479 from Monitor 8'
'2017-08-09 00:07:35.963350','zmfilter',NULL,'Deleting event 921480 from Monitor 6'
'2017-08-09 00:07:36.042310','zmfilter',NULL,'Deleting event 921481 from Monitor 2'
'2017-08-09 00:07:36.224780','zmfilter',NULL,'Deleting event 921482 from Monitor 5'
'2017-08-09 00:07:36.414770','zmfilter',NULL,'Deleting event 921483 from Monitor 1'
'2017-08-09 00:07:36.574320','zmfilter',NULL,'Deleting event 921484 from Monitor 4'
'2017-08-09 00:07:36.669290','zmfilter',NULL,'Deleting event 921485 from Monitor 6'
'2017-08-09 00:07:36.814600','zmfilter',NULL,'Deleting event 921486 from Monitor 3'
'2017-08-09 00:07:36.890070','zmfilter',NULL,'Deleting event 921487 from Monitor 2'
'2017-08-09 00:07:36.945840','zmfilter',NULL,'Deleting event 921488 from Monitor 8'
'2017-08-09 00:07:37.130800','zmfilter',NULL,'Deleting event 921489 from Monitor 4'
'2017-08-09 00:07:37.221570','zmfilter',NULL,'Deleting event 921490 from Monitor 1'
'2017-08-09 00:07:37.414920','zmfilter',NULL,'Deleting event 921491 from Monitor 5'
'2017-08-09 00:07:37.623280','zmfilter',NULL,'Deleting event 921492 from Monitor 3'
'2017-08-09 00:07:37.762780','zmfilter',NULL,'Deleting event 921493 from Monitor 6'
'2017-08-09 00:07:37.877090','zmfilter',NULL,'Deleting event 921494 from Monitor 2'
'2017-08-09 00:07:37.974910','zmfilter',NULL,'Deleting event 921495 from Monitor 8'
'2017-08-09 00:07:44.137699','zma_m1','nuc','Retro_casa: 464000 - Analysing at 25.00 fps'
2# thank you if you can check.
3# i tried turn on auth relay without success.
Here are images:
may be an broken version causing all this trouble?
marcopete87
Update: after renaming zmfilter.pl on raspberry pi, event issues ceased.
Can it be an ntp updating related issue?
