Ubuntu 16 crete monitor error
yonubear
Post by yonubear »
when i try to create a monitor i get the following error any advice would be great
SQL-ERR 'SQLSTATE[HY000]: General error: 1366 Incorrect integer value: '' for column 'ServerId' at row 1', statement was 'insert into Monitors set LinkedMonitors = '', Name = 'Monitor-1', ServerId = '', Type = 'Remote', Function = 'Monitor', Enabled = '1', RefBlendPerc = '6', AlarmRefBlendPerc = '6', AnalysisFPS = '', MaxFPS = '', AlarmMaxFPS = '', Device = '/dev/video0', Channel = '0', Format = '255', Palette = '0', V4LMultiBuffer = '', V4LCapturesPerFrame = '1', Options = '', LabelFormat = '%N - %Y-%m-%d %H:%M:%S %z', LabelX = '0', LabelY = '0', LabelSize = '1', ImageBufferCount = '50', WarmupCount = '25', PreEventCount = '25', PostEventCount = '25', StreamReplayBuffer = '1000', AlarmFrameCount = '1', EventPrefix = 'Event-', SectionLength = '600', FrameSkip = '0', MotionFrameSkip = '0', AnalysisUpdateDelay = '0', FPSReportInterval = '1000', DefaultView = 'Events', DefaultRate = '100', DefaultScale = '100', WebColour = 'red', Exif = '0', SignalCheckColour = '#0000c0', Protocol = 'rtsp', Method = 'rtpRtsp', Host = '192.168.1.152', Port = '554', Path = '/user=admin&password=&channel=2&stream=0.sdp', Colours = '3', Width = '320', Height = '240', Orientation = '0', Deinterlacing = '0', Sequence = 1'
thanks,
Yonu
yonubear
Re: Ubuntu 16 crete monitor error
Post by yonubear »
oh and i am sorry i was thinking of the wrong server when i typoed that i am running mint cinimmon on this setup
Did you do the fix to MySQL? See the ubuntu Zoneminder WIKI
