Hi, can somebody help me please I don't know why I can't get this camera to work. I tried IP Cam from android and it is working fine. For some reason I can't get Escam QF002 to work.
Attached are my settings and log file from ZoneMinder 1.30.4. The only difference from the procedure that I've seen is Remote method to be RTP but on my version of ZoneMinder it is not in the selection.
Any suggestion would be much appreciated. Thanks in advance.
Escam QF002 Camera
Escam QF002 Camera
- zm-log.txt
- (605.76 KiB) Downloaded 223 times
- Capture2.JPG (41.56 KiB) Viewed 2933 times
- Capture1.JPG (52.07 KiB) Viewed 2933 times
Re: Escam QF002 Camera
Thanks a lot for the suggestion. I tried it unfortunately I still have a black screen.
I can stream my IP Camera using VLC but still can't make it to work with Zoneminder running on openmediavault.
Somebody kindly look at my zm log and see why it is not running. Sorry I don't understand most of the log details.
- Capture.JPG (365.4 KiB) Viewed 2889 times
Does it create events and record images, and just not stream to a monitor?
If so, find your apache access.log, and see whether calls to nph-zms are 200 or 404, and what the URL is.
