Working 100% and still a log full errors
Posted: Wed Aug 30, 2017 2:29 pm
In my opinion my Zoneminder 1.30.4 is running 100%.under Ubuntu 16.04
I have 10 IP cams running outside my LAN and I got them al working fine I can see the streams, and events.
But the logfiles is still full of errors like below..
2017-08-30 16:26:08.348180 zmwatch 19736 ERR Error getting last capture time for Kinderdijk zmwatch.pl
2017-08-30 16:25:48.469480 zmdc 19592 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2017-08-30 16:19:57.596850 zmwatch 19736 ERR Error getting last capture time for Parkeerplaats zmwatch.pl
2017-08-30 16:19:37.718210 zmdc 19592 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2017-08-30 16:07:46.790590 zmwatch 19736 ERR Error getting last capture time for Salondeur zmwatch.pl
2017-08-30 16:07:31.124570 zmdc 19592 ERR 'zmc -m 4' exited abnormally, exit status 255 zmdc.pl
2017-08-30 16:03:54.018663 web_js 24003 ERR TypeError: e[c] is undefined http://www.camera-connect.nl/zm/tools/m ... ls-more.js 1
2017-08-30 16:03:53.990188 web_js 24003 ERR TypeError: e[c] is undefined http://www.camera-connect.nl/zm/tools/m ... ls-more.js 1
2017-08-30 16:03:51.545115 web_js 24003 ERR TypeError: e[c] is undefined http://www.camera-connect.nl/zm/tools/m ... ls-more.js 1
2017-08-30 16:03:51.513082 web_js 24003 ERR TypeError: e[c] is undefined http://www.camera-connect.nl/zm/tools/m ... ls-more.js 1
2017-08-30 16:03:49.765074 web_js 24363 ERR TypeError: e[c] is undefined http://www.camera-connect.nl/zm/tools/m ... ls-more.js 1
2017-08-30 16:03:48.768360 web_js 24363 ERR TypeError: e[c] is undefined http://www.camera-connect.nl/zm/tools/m ... ls-more.js 1
2017-08-30 15:43:30.849342 zms 23561 ERR Bogus scale factor 0 found zm_image.cpp 2738
2017-08-30 15:42:35.802720 zmdc 19592 ERR 'zmc -m 8' exited abnormally, exit status 255 zmdc.pl
2017-08-30 15:42:35.679440 zmwatch 19736 ERR Memory map file '/dev/shm/zm.mmap.8' does not exist. zmc might not be running. zmwatch.pl
2017-08-30 15:42:35.602152 zmc_m8 22958 ERR Unable to get response, disconnecting zm_remote_camera_http.cpp 1141
2017-08-30 15:42:35.600470 zmc_m8 22958 ERR Unable to extract subheader data zm_remote_camera_http.cpp 451
2017-08-30 15:42:35.591453 zmc_m8 22958 ERR Select error: Interrupted system call zm_remote_camera_http.cpp 175
2017-08-30 15:42:26.218877 web_php 22655 ERR Socket /var/run/zm/zms-376195s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/lat ... window-etc for more information.
