The website for cambozola.jar is dead/down... http://www.andywilcock.com/code/cambozo ... 931.tar.gz
I thought I read that it was being distributed with ZM 1.30.x, but I'm checking the last couple of systems I install and it's nowhere in the system.
What did I miss?
What happened to cambozola.jar
Re: What happened to cambozola.jar
Nothing. You have always had to download it.
site is up...I just downloaded cambozola.jar.
- knight-of-ni
The cambozola site seems to be working fine for me at the moment.
Here is an alternative download link:
http://www.charliemouse.com:8080/code/c ... est.tar.gz
What I did to solve the cambozola problem on the Redhat side is to become a package maintainer for Fedora:
https://admin.fedoraproject.org/pkgdb/p ... cambozola/
In this case, I am a co-maintainer for this particular package.
Once cambozola becomes a package and gets hosted by the distro repositories, we can simply make the zoneminder package depend on cambozola, and then it will get installed automatically every time.
My assumption is that those involved in this conversation are all using a Debian based distro of some kind. All it would take is for one of you to go down the same path on the Debian side. Become a new package maintainer for your distro and then go through the peer review process of adding cambozola as a package.
Hah! Oh, sure, now it's working.... :/
I tried a couple time over the course of 2 days before I posted... Oh well.
FWIW, I tried the OPs link when he posted it, and he's not nuts: it timed out for me as well.
please not that the website listed above is actually up just not on the port listed... It is up on the Standard HTTP port 80 not 8080. So the link should be:
http://www.charliemouse.com/code/camboz ... est.tar.gz
