Digoo DG-M1Z
geraldbrandt
Digoo DG-M1Z
Post by geraldbrandt »
Has anyone tried the Digoo DG-M1Z camera? I know the M1Q works.
Gerald
shanebekker
Re: Digoo DG-M1Z
Post by shanebekker »
HI,
How did you get your M1q working as mine does not display any feed as I get this error
Unable to open input rtsp://admin:20160404@xxx.xxx.xxx.xxx:554/onvif1 due to: Operation now in progress
I have checked to see if any other applications are using this rtsp but none. The feed does work in VLC.
benThijssen
Re: Digoo DG-M1Z
Post by benThijssen »
I have the same settings.
On the first tab (General)
Source type: ffmpeg
On the second tab (source)
source path: rtsp://admin:20160404@digoofixed.localnamar.nu/onvif1
Remote method: UDP
Capture width: 1920
Capture height: 1080
Adapt source type to your own settings.
I changed the source type from <ffmpeg> to <Libvlc> and
Remote method from <UDP> to TCP. That even seems to work better. Less error and warnings.
