I installed and configured camera module on Raspberry Pi 3 using this page: http://elinux.org/RPi-Cam-Web-Interface. Everything looks good and I can use camera if I go to the webpage: http://192.168.1.5/html/.
When I try to add this camera to my ZoneMinder installation, it gives me the blank page. What am I doing wrong? Can someone help me with this?
Raspberry Pi camera module
- Capture2.JPG (22.22 KiB) Viewed 15968 times
- Capture.JPG (41.42 KiB) Viewed 15968 times
Re: Raspberry Pi camera module
I skimmed down those instructions you followed, with a "TL;DR" feeling about it
Guessing #1: Remote host path of just "html" isn't actually pointing directly at the jpeg/motion-jpeg/h264 stream. Find the real URL that goes directly to the video feed, and use that. You may have to look more closely at the page served up (in a web browser) to find the real address of the video stream.
Guessing #2: Why do you think the camera resolution would be 648 x 486? That's a very specific, and yet odd, number. It needs to be exactly right for Zoneminder to work, so no rounding up/down/guessing allowed
Hi, I am having the exact same issue, did you already find an answer onllize?
thnx in advance!
thnx in advance!
OP didn't come back and say "that worked" or "those suggestions were rubbish", so we'll never know
Unless you try it out and tell us, assuming you have the same settings and problem on a PI
yeah already tried those. it was my first setup. from there I moved on to using MotioneyeOS with Zoneminder, unfortunately both no luck.
I am kinda stuck here
