I am using ZM authentication and if I understand this thread correctly I am not subject to the Chrome bug unless I am using basic auth.
The Chrome version on my Android is 61.0.3163.98
When I click on the timeline function, nothing is logged in the syslog:
Oct 8 14:43:13 darin-Latitude-E6420 kernel: [ 1727.362310] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:58:8b:f3:3f:75:46:08:00 SRC=192.168.200.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
Oct 8 14:43:14 darin-Latitude-E6420 kernel: [ 1727.993297] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:fb:00:80:77:df:fc:18:08:00 SRC=192.168.200.5 DST=224.0.0.251 LEN=32 TOS=0x12 PREC=0x60 TTL=1 ID=27001 PROTO=2
Oct 8 14:43:26 darin-Latitude-E6420 zmc_m2[2190]: INF [Basement: 5000 - Capturing at 3.00 fps]
Oct 8 14:43:26 darin-Latitude-E6420 zma_m2[2191]: INF [Basement: 5000 - Analysing at 3.00 fps]
Oct 8 14:43:28 darin-Latitude-E6420 zmc_m6[2231]: INF [CatFood: 5000 - Capturing at 2.99 fps]
Oct 8 14:43:28 darin-Latitude-E6420 zmc_m7[2232]: INF [LivingRoom: 5000 - Capturing at 3.00 fps]
Oct 8 14:43:28 darin-Latitude-E6420 zma_m6[2234]: INF [CatFood: 5000 - Analysing at 3.00 fps]
Oct 8 14:43:29 darin-Latitude-E6420 zmc_m3[2238]: INF [Mantle: 5000 - Capturing at 3.00 fps]
Oct 8 14:43:30 darin-Latitude-E6420 zmc_m4[2241]: INF [FrontDoor: 5000 - Capturing at 2.99 fps]
Oct 8 14:43:30 darin-Latitude-E6420 zma_m3[2244]: INF [Mantle: 5000 - Analysing at 3.00 fps]
Oct 8 14:43:31 darin-Latitude-E6420 zma_m7[2256]: INF [LivingRoom: 5000 - Analysing at 2.99 fps]
Oct 8 14:43:31 darin-Latitude-E6420 zma_m4[2253]: INF [FrontDoor: 5000 - Analysing at 3.00 fps]
Oct 8 14:44:54 darin-Latitude-E6420 zma_m1[2250]: INF [FamilyRoom: 5000 - Analysing at 2.41 fps]
Oct 8 14:45:00 darin-Latitude-E6420 zms[2950]: ERR [Frame send time 2800 msec too slow, throttling maxfps to 3.33]
Oct 8 14:45:06 darin-Latitude-E6420 zms[2950]: ERR [Frame send time 4760 msec too slow, throttling maxfps to 2.22]
Oct 8 14:45:18 darin-Latitude-E6420 kernel: [ 1852.377440] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:58:8b:f3:3f:75:46:08:00 SRC=192.168.200.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
Oct 8 14:45:19 darin-Latitude-E6420 kernel: [ 1853.369377] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:fb:00:80:77:df:fc:18:08:00 SRC=192.168.200.5 DST=224.0.0.251 LEN=32 TOS=0x06 PREC=0x40 TTL=1 ID=27002 PROTO=2
Oct 8 14:45:25 darin-Latitude-E6420 zms[2950]: INF [Got signal 15 (Terminated), exiting]
Oct 8 14:47:23 darin-Latitude-E6420 kernel: [ 1977.392282] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:58:8b:f3:3f:75:46:08:00 SRC=192.168.200.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
Oct 8 14:47:24 darin-Latitude-E6420 kernel: [ 1977.995316] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:fb:00:80:77:df:fc:18:08:00 SRC=192.168.200.5 DST=224.0.0.251 LEN=32 TOS=0x14 PREC=0x20 TTL=1 ID=27003 PROTO=2
Oct 8 14:47:33 darin-Latitude-E6420 zmdc[1982]: WAR [Can't find process with command of 'zma -m 8']
Oct 8 14:47:33 darin-Latitude-E6420 zmdc[1982]: WAR [Can't find process with command of 'zmc -m 8']
Oct 8 14:47:34 darin-Latitude-E6420 zmdc[1982]: WAR [Can't find process with command of 'zma -m 9']
Oct 8 14:47:34 darin-Latitude-E6420 zmdc[1982]: WAR [Can't find process with command of 'zmc -m 9']
Oct 8 14:47:35 darin-Latitude-E6420 zmdc[1982]: WAR [Can't find process with command of 'zma -m 10']
Oct 8 14:47:35 darin-Latitude-E6420 zmdc[1982]: WAR [Can't find process with command of 'zmc -m 10']
Oct 8 14:47:44 darin-Latitude-E6420 web_php[1469]: INF [Login successful for user "admin"]
Oct 8 14:48:40 darin-Latitude-E6420 zmc_m1[2931]: INF [FamilyRoom: 1000 - Capturing at 2.53 fps]
Oct 8 14:48:59 darin-Latitude-E6420 zmc_m2[2190]: INF [Basement: 6000 - Capturing at 2.99 fps]
Oct 8 14:49:00 darin-Latitude-E6420 zma_m2[2191]: INF [Basement: 6000 - Analysing at 2.99 fps]
Oct 8 14:49:01 darin-Latitude-E6420 zmc_m6[2231]: INF [CatFood: 6000 - Capturing at 3.00 fps]
Oct 8 14:49:02 darin-Latitude-E6420 zmc_m7[2232]: INF [LivingRoom: 6000 - Capturing at 2.99 fps]
Oct 8 14:49:02 darin-Latitude-E6420 zma_m6[2234]: INF [CatFood: 6000 - Analysing at 2.99 fps]
Oct 8 14:49:03 darin-Latitude-E6420 zmc_m3[2238]: INF [Mantle: 6000 - Capturing at 2.99 fps]
Oct 8 14:49:03 darin-Latitude-E6420 zmc_m4[2241]: INF [FrontDoor: 6000 - Capturing at 3.00 fps]
Oct 8 14:49:03 darin-Latitude-E6420 zma_m3[2244]: INF [Mantle: 6000 - Analysing at 3.00 fps]
Oct 8 14:49:04 darin-Latitude-E6420 zma_m7[2256]: INF [LivingRoom: 6000 - Analysing at 3.00 fps]
Oct 8 14:49:04 darin-Latitude-E6420 zma_m4[2253]: INF [FrontDoor: 6000 - Analysing at 3.00 fps]
Oct 8 14:49:28 darin-Latitude-E6420 kernel: [ 2102.407399] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:58:8b:f3:3f:75:46:08:00 SRC=192.168.200.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
Oct 8 14:49:28 darin-Latitude-E6420 kernel: [ 2102.471346] [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:fb:00:80:77:df:fc:18:08:00 SRC=192.168.200.5 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=27005 PROTO=2
Oct 8 14:50:28 darin-Latitude-E6420 zma_m1[2250]: INF [FamilyRoom: 6000 - Analysing at 2.99 fps]
192.168.200.43 - - [08/Oct/2017:14:47:44 -0400] "GET /zm HTTP/1.1" 301 575 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:44 -0400] "GET /zm/ HTTP/1.1" 200 3388 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:44 -0400] "POST /zm/index.php HTTP/1.1" 200 3388 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:45 -0400] "GET /zm/api/host/getVersion.json HTTP/1.1" 200 263 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:45 -0400] "GET /zm/api/host/getTimeZone.json HTTP/1.1" 404 4942 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:45 -0400] "GET /zm/api/configs/viewByName/ZM_EVENT_IMAGE_DIGITS.json HTTP/1.1" 200 256 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:45 -0400] "GET /zm/api/monitors.json HTTP/1.1" 200 16162 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:45 -0400] "GET /zm/api/servers.json HTTP/1.1" 200 231 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:45 -0400] "GET /zm/index.php?view=watch&mid=1&connkey=398381 HTTP/1.1" 200 2558 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:46 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=2&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488465593 HTTP/1.1" 200 12977 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:46 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=1&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488465593 HTTP/1.1" 200 11681 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:46 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=4&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488465593 HTTP/1.1" 200 9766 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:46 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=3&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488465593 HTTP/1.1" 200 12936 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:46 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=7&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488465593 HTTP/1.1" 200 10253 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:46 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=6&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488465593 HTTP/1.1" 200 12203 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:47 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=1&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488467600 HTTP/1.1" 200 11647 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:47 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=2&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488467600 HTTP/1.1" 200 13010 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:47 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=7&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488467600 HTTP/1.1" 200 10218 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:47 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=4&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488467600 HTTP/1.1" 200 9762 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:47 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=6&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488467600 HTTP/1.1" 200 12203 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
192.168.200.43 - - [08/Oct/2017:14:47:47 -0400] "GET /zm/cgi-bin/nph-zms?mode=single&monitor=3&scale=50&auth=330df37bb9fd2c248808ef51dfef2930&rand=1507488467600 HTTP/1.1" 200 12956 "-" "Mozilla/5.0 (Linux; Android 7.0; SM-G930V Build/NRD90M; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/61.0.3163.98 Mobile Safari/537.36"
[Sun Oct 08 14:16:42.156072 2017] [:error] [pid 1468] [client 192.168.200.43:34258] INF [Login successful for user "admin"]
[Sun Oct 08 14:16:57.557175 2017] [:error] [pid 2270] [client 192.168.200.43:34273] INF [Login successful for user "admin"]
[Sun Oct 08 14:20:32.495438 2017] [:error] [pid 1470] [client 192.168.200.43:34298] INF [Login successful for user "admin"]
[Sun Oct 08 14:20:56.021833 2017] [:error] [pid 1467] [client 192.168.200.43:34316] INF [Login successful for user "admin"]
[Sun Oct 08 14:33:46.003625 2017] [:error] [pid 2404] [client 192.168.200.43:34392] INF [Login successful for user "admin"]
[Sun Oct 08 14:34:25.387288 2017] [:error] [pid 1468] [client 192.168.200.43:34421] INF [Login successful for user "admin"]
[Sun Oct 08 14:37:36.966923 2017] [:error] [pid 2270] [client 192.168.200.43:34481] INF [Login successful for user "admin"]
[Sun Oct 08 14:44:40.968342 2017] [:error] [pid 2503] [client 192.168.200.124:58544] PHP Notice: Undefined index: Enabled in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 537, referer: http://192.168.200.71/zm/index.php?view=monitor&mid=8
[Sun Oct 08 14:45:33.178662 2017] [:error] [pid 2871] [client 192.168.200.124:58603] PHP Notice: Undefined index: Enabled in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 537, referer: http://192.168.200.71/zm/index.php?view=monitor&mid=8
[Sun Oct 08 14:45:59.888465 2017] [:error] [pid 1467] [client 192.168.200.124:58613] PHP Notice: Undefined index: Enabled in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 537, referer: http://192.168.200.71/zm/index.php?view=monitor&mid=8
[Sun Oct 08 14:46:01.263026 2017] [:error] [pid 1466] [client 192.168.200.124:58618] PHP Notice: Undefined index: User in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 589, referer: http://192.168.200.71/zm/index.php
[Sun Oct 08 14:46:01.263053 2017] [:error] [pid 1466] [client 192.168.200.124:58618] PHP Notice: Undefined index: Pass in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 590, referer: http://192.168.200.71/zm/index.php
[Sun Oct 08 14:46:07.530216 2017] [:error] [pid 1466] [client 192.168.200.124:58618] PHP Notice: Undefined index: Exif in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 664, referer: http://192.168.200.71/zm/index.php
[Sun Oct 08 14:46:37.266504 2017] [:error] [pid 2404] [client 192.168.200.124:58628] PHP Notice: Undefined index: Enabled in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 537, referer: http://192.168.200.71/zm/index.php
[Sun Oct 08 14:47:10.562269 2017] [:error] [pid 1469] [client 192.168.200.124:58640] PHP Notice: Undefined index: Enabled in /usr/share/zoneminder/www/skins/classic/views/monitor.php on line 537, referer: http://192.168.200.71/zm/index.php?view=monitor&mid=8
[Sun Oct 08 14:47:44.813517 2017] [:error] [pid 1469] [client 192.168.200.43:34523] INF [Login successful for user "admin"]
