Segfault when using VLC
Posted: Tue Oct 10, 2017 9:27 am
I am running a fresh install of Zoneminder on Debian Stretch, installed using the guide and Debian's multimedia packages.
I have a camera setup on Ethernet and finding that VLC is the only source type that gives a reliably clear picture. I have smearing issues with ffmpeg which seems to be a common problem when searching the forum.
Unfortunately, after around 24 hours, the zmc_m1 component crashes with a segfault mentioning /usr/lib/x86_64-linux-gnu/libvlccore.so.8 in the backtrace. I've searched the forum and can see this was an issue in the past but has been fixed before zoneminder 1.30. Is this a regression?
Is there a fix for this issue?
Many thanks,
James
Many thanks,
James
